Steering wheel off center after alignment!
Discussion in 'General Tundra Discussion' started by MTRock, Feb 28, 2020.
  1. Feb 28, 2020 at 11:04 AM
    MTRock
    MTRock [OP] 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    We installed the ToyTec Boss kit. Did a crude alignment and drove it about 50-75 miles then re torqued. Steering wheel was perfect before and after kit installation. After the tire shop aligned the steering wheel is now about 5 degrees to the left! 2 trips said they can’t fix it! Has to get hooked up to a Toyota computer! WTF!!! Called BS! Shitty alignment or??!184571D1-0753-4EEE-AECA-468CB5A2E315.jpg
    Mountun Goat likes this.
  2. Feb 28, 2020 at 11:19 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    They can definitely fix it. Just needs to adjust the tie rod ends. =bad alignment
    Toyokuhl and Black Wolf like this.
  3. Feb 28, 2020 at 11:21 AM
    MTRock
    MTRock [OP] 1889
    Montana
    Exact what I told them....took it back in the shop for 30mins then said he can’t fix it!
  4. Feb 28, 2020 at 11:24 AM
    MTRock
    MTRock [OP] 1889
    Montana
    Small town only 2 tire shops. I’ll be going to the other one Monday!
  5. Feb 28, 2020 at 12:38 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Brutal! Sorry to hear that. Hopefully the other gets it for you
  6. Feb 28, 2020 at 12:51 PM
    MTRock
    MTRock [OP] 1889
    Montana
    Thanx man! Just had to vent a little?
    Mountun Goat[QUOTED] likes this.
  7. Feb 28, 2020 at 1:11 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    The fact he couldnt center the wheel is enough to warrant having someone else check the alignment specs. Also, check how the truck handles a road crown. Sometimes these shops just set it and never test it against road crown pull and brake pull.
    frichco228 and Mountun Goat like this.
  8. Feb 28, 2020 at 1:24 PM
    MTRock
    MTRock [OP] 1889
    Montana
    Crown is good slight brake pull to the right. Can’t say I’m impressed! Blamed it on the new coil overs! I guess if the other place can’t fix it we do have A WalMart here!!!
  9. Mar 3, 2020 at 3:48 PM
    MTRock
    MTRock [OP] 1889
    Montana
    Took it to the other shop fixed in 20 mins!
  10. Mar 3, 2020 at 4:29 PM
    jtwags
    League City, TX
    2018 Tundra CM
    Not sure if the guy that did the first alignment is the owner or not but if not it might be worth an email to the owner to let them know they have an incompetent alignment technician under their employment that forced you to go to another alignment shop to fix his work. Maybe they'll refund you the cost of your proper alignment.
  11. Mar 3, 2020 at 5:23 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Full on!
  12. Mar 3, 2020 at 5:25 PM
    RCdadfor2
    RCdadfor2 New Member
    Jeff
    2008 Tundra DC
    none yet
    Hopefully you paid with a CC and have some recourse.
  13. Mar 3, 2020 at 5:27 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    Yeah that's like 20 degrees...my wheel is off by 5 degrees depending on road crown and it drives me crazy at a fraction of that angle. If that's the best they could do...well they suck.
  14. Mar 3, 2020 at 7:22 PM
    MTRock
    MTRock [OP] 1889
    Montana
    I’m the owner. Will be going there in the AM for my $85!
    jtwags[QUOTED] and YsoSeRiouS! like this.
  15. Mar 3, 2020 at 8:35 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    That’s good it got fixed.
  16. Mar 4, 2020 at 1:32 PM
    MTRock
    MTRock [OP] 1889
    Montana
    Refund $85 is in the mail..
    SomeGuy4, Ely010606 and jtwags like this.
