Who's in?...
Discussion in '1st Gen Tundras (2000-2006)' started by Baller, Mar 3, 2020.
  1. Mar 3, 2020 at 5:05 PM
    Baller
    Baller [OP] New Member
    '05 Tundra SR5 DC
  2. Mar 3, 2020 at 5:24 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  3. Mar 3, 2020 at 5:27 PM
    I saw that thread last year. Not a chance I could pull that off and I don't have half the tools necessary. I'd rather just pay Vagabond but I admire anyone that has the skills to do it themselves.
    speedtre and Squatting Pigeon like this.
  4. Mar 3, 2020 at 5:34 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Cool write up! That guy did some nice work for DIY. I skimmed the article and couldn’t find the total cost of materials and labor. Saw he was selling the design for $20? which is good.
    Total weight at 375lbs is nice.
    My mantra: Go in light. Come out lighter.
    Translation: Sleep in a 5lb. tent on the ground. Shiver and starve. Come home to domestic life and have a greater appreciation of things. :D
    chrisb and Sunnier like this.
  5. Mar 3, 2020 at 5:51 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
  6. Mar 3, 2020 at 8:57 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I've been thinking about it recently since i stumbled upon a sweet aluminum shell that had a similar design. I'm torn because my practical side just says buy the softopper and build a rack if I want a tent later, but my cheap-ass side says make a friggin shell because you can. I bet I could build a shell for maybe $500-700 in material and then just have to pay someone to sew up the tent for me.
  7. Mar 4, 2020 at 3:00 AM
    foxtrapper
    foxtrapper New Member
    2003 SR5
    Realistically you could build this for $3,000.
    This is assuming you do EVERYTHING yourself. You will need access to a welder & sewing machine at a minimum. Having a router, mill and laser cutter helps a lot as i’ll show, but isn’t necessary.
  8. Mar 4, 2020 at 6:19 AM
    KarmaKannon
    Utah
    Some junk
    That much 8020 and hardware is expensive by itself. I understand the applications for it and why it was probably chosen, but there are less expensive ways of making a hinge and gasketed sealing surface. I like extrusion, but it's spendy stuff.
    There's also a possibility that someone could minimize the amount of zippered areas and repurpose a premade tent for some sections. This is a hunch, but seems possible.
  9. Mar 4, 2020 at 8:21 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    That’s cool. I’d rather sleep in the FERD though.
    :crapstorm:
  10. Mar 4, 2020 at 8:52 AM
    you gonna overland that thing?
  11. Mar 4, 2020 at 9:48 AM
    Fred
    Hand Protectors
    Probably gets better MPG than our trucks. :ohsnap:
  12. Mar 4, 2020 at 1:05 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    12-15 highway, so...
    almost.
    KarmaKannon likes this.
  13. Mar 4, 2020 at 1:06 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Totally could 4x4 swap it , but that’s a TON of work.
