Who has subwoofers?
Discussion in '1st Gen Tundras (2000-2006)' started by TX-TRD1stGEN, May 16, 2019.
  1. Jun 8, 2019 at 11:48 AM
    NMTundra
    NMTundra New Member
    Yep those look like the ones. As far as reusing the existing mounts, you might as well. After the ones I bought didn't actually fit despite saying they would, I just drilled new holes for them but it would have been cleaner had I retrofitted the existing mounts versus doing that.
  2. Feb 29, 2020 at 9:04 PM
    joshnixtape
    joshnixtape New Member
    josh
    2002 Toyota Tundra
    Here is a link to my video on how I installed my sub! It turned out pretty good and its out of the way. https://youtu.be/q0in_KFrcnQ
  3. Mar 1, 2020 at 3:32 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I have a shallow Rockford Fosgate 12 in a truck wedge box. I added a woofer grill to protect the woofer and lay it facing down in the back between the passenger front and rear seats. Gets plenty loud.
    The box was a little bigger so its now upright wedged between the front and rear passenger seats. Still plenty of cow bell for me though. More is not needed.
    TX-TRD1stGEN[OP] likes this.
  4. Aug 6, 2020 at 8:51 PM
    TheTundy
    TheTundy New Member
    Brandon
    06 tundra built for adventure and braaap
    2” Old Man Emu kit Rite rite air bag system with compressor Add a leaf Touch screen Topper with false floor and drawers Coming Fallen at3 Stealth customs ray 10 16” Custom leafs for lift and cargo (slide in)
    For people who want audiophile quality without the price.
    CDT AUDIO
    CDT AUDIO
    AMAZING SOUND
  5. Aug 7, 2020 at 12:53 PM
    shifty` Goons of Hazzard
    That's an interesting first post there, Bran. What separates CDT from other low-dollar absolute crap like BOSS, Pyramid, SSL, etc.?
    Darkness and Elduder like this.
  6. Aug 7, 2020 at 1:34 PM
    Elduder
    Elduder New Member
    There are some manufacturers out there that do have a better quality to price ratio than most of the popular brands. Dayton is one that always comes up in home audio use, theyre relatively cheap for components and will typically out perform the generic car app stuff like Kicker, JL, etc at least on the entry level end. Not sure about CDT though.
    shifty`[QUOTED] likes this.
  7. Aug 7, 2020 at 2:07 PM
    TheTundy
    TheTundy New Member
    Brandon
    I had my first pair 6 years ago. The HD series. I could hear the door steps of someone moving on the stage. I only paid $150. Put 100watts to them and wow. Bout to order my second set.
    I’ve tried some others, I feel like I’m getting a thousand dollar speaker for hundreds.
  8. Aug 8, 2020 at 6:33 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    sub under rear driver pass seat, amp under rear of driver seat
  9. May 9, 2021 at 8:10 AM
    Viclow
    Viclow New Member
    Victor
    05 white 4 Dr.
    18 in. Black rhino wheels, aftermarket stereo 12in. Slim sub box 5 channel JBL amp.
    20210508_141445.jpg 20210508_141504.jpgWell I've been going through it with the design of my box for my truck just like everybody else here I had an idea for a box that would have been awesome but then they said it wouldn't be legal because I wanted to make my backseat the box itself and make it down facing slim sub box and you know in bed the seatbelts and cushion and everything like a real seat but after saying it wouldn't be illegal that idea went out the window so I actually have a custom built 8-in single sub box that I might end up putting for sale with a punch sub at 2 ohms because I did this.
  10. May 26, 2021 at 10:23 AM
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    1305AFD3-D724-477E-BB09-189B63F4004B.jpg 25E6C062-01BD-4B01-A818-1C589F9EA193.jpg BD4E6EE7-092D-41E9-89B6-36250FE58497.jpg
    It’s not much of a clean install but here’s my 10” sub with a custom box and swapped out the center console for the sub. The center console was really bulky with not much use so I quite like the sub in the middle instead. I have it bolted down to the truck and I also have a top over it so I can use it as an armrest and to put whatever else on top of the sub as if it’s my center console.
    bmf4069, Elduder and Darkness like this.
  11. May 26, 2021 at 10:26 AM
    Snaz
    Snaz I <3 explosions
    SE CO
    '20 Limited Quicksand
    I have the JL Stealth Box w/2×10TW3 IIRC and the JL VX1000w/1i amp. My only complaint is that I don't have room for more.
    Door and Dash speakers are JLs powered by JL VX800/8i.
    Using a Fix 82 atm, but I'll be putting in a JVC head unit in it mid June.
    ETA: My bad, didn't realize this was in Gen 1 when I posted.
    potoghi likes this.
  12. May 26, 2021 at 10:33 AM
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    I feel you haha, I really would want a 12” but there’s absolutely no space for it unless I remove a seat or something.
  13. May 26, 2021 at 11:33 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That setup is scary. When I was younger I drove around with boxes in my cab but soon realized they should be bolted down securely.
    I would build a box into the floor if I had a double cab and run 8s. Its easy to do and you don't lose any valuable space. Plus if you're in an accident its secured and won't kill anybody.
    potoghi likes this.
  14. May 26, 2021 at 11:39 AM
    Snaz
    SE CO
    There's so much leg room in the backseat area, if I was a fabricator I'd figure out a mount to move the seat forward a few inches for a bigger box.
    potoghi[QUOTED] likes this.
  15. May 26, 2021 at 12:08 PM
    AWilliams
    AWilliams New Member
    In my 2003 Access cab I have a 10 inch sub in a wedge box behind the passenger seat and a 3-channel amp under the seat. I don't have any kids and don't haul anything in the back so I don't mind giving up a little bit of room for better sound.
    potoghi and Darkness like this.
  16. May 26, 2021 at 12:25 PM
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    Before my current setup, my sub was exactly like yours with the wedge box. But I had mines horizontal and wedged between the driver seat and back seat. Then I had my driver seat as far back as it could go so the box wouldn’t budge.
  17. May 26, 2021 at 1:52 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
  18. May 26, 2021 at 2:55 PM
    Viclow
    Viclow New Member
    Victor
    05 white 4 Dr.
    I wish I had room for something like that
  19. May 26, 2021 at 7:56 PM
    AWilliams
  20. May 27, 2021 at 7:40 PM
    #50
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Here’s what I’ve got. Shallow mount 8” Pioneer in a crappy little box. Sounds pretty good. The rubber bumpers are key to holding the plastic covering up so the sub doesn’t contact it. I want to put a 6.5” JL in it too. We’ll see.
    bmf4069, potoghi and Darkness like this.
  21. May 27, 2021 at 8:14 PM
    #51
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    That looks good. I wanted to do exactly that for my truck but with 2 subs instead. The rubber bumps is a smart idea. I have my own 3d printer so I just print spacers whenever I need it for things like this.
