skid plate w/filter hole Found RCI COUPON CODE
Discussion in '2.5 Gen Tundras (2014-2021)' started by Quartermeter, Jan 14, 2017.
  1. Jan 14, 2017 at 3:29 PM
    Quartermeter
    Quartermeter [OP] New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Allright i changed my oil today. PITA. So who makes a better SP with filter hole and cover thats not $3-$400? Dont say TRD.
    I read that Lexus makes an aluminum filter piece to replace the plastic one.
    Also why did toyota use a plastic intake on the Tundra?? Lots of plastic on my 2014.
  2. Jan 14, 2017 at 3:45 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    Replacement filter housing As for your first good luck with that I've done mine twice already and feel you pain. Probably not so much as I have a lift to do my oil changes on.
  3. Jan 14, 2017 at 3:46 PM
    trainracer
    trainracer New Member
  4. Jan 14, 2017 at 7:13 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
  5. Jan 14, 2017 at 7:45 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  6. Jan 14, 2017 at 8:15 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    RCI just finished the install of mine today.
    T-Rex266 likes this.
  7. Jan 14, 2017 at 8:53 PM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    RCI lists that their plate fits 07-17. Does the same plate fit all years? I know where a trd plate listed as 07-13. If so it should fit
  8. Jan 14, 2017 at 8:57 PM
    If it says 07-17, it should...
    Quartermeter[OP] likes this.
  9. Jan 14, 2017 at 9:31 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    IcI magnum makes one for like 130$ not sure about the filter thing tho
  10. Jan 18, 2017 at 4:14 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    It makes sense to consider the aluminum TRD Pro skid plate that has the oil filter door...
    MotoTundra likes this.
  11. Jan 18, 2017 at 7:36 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    This is my planned route. Until then, I think I will be taking it to the dealer.
  12. Jan 18, 2017 at 7:40 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I think the RCI (steel) is less expensive than the trd and protects more of the under carriage. I love mine, it's not flimsy.
  13. Jan 18, 2017 at 8:11 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Great info, I considered RCI but I'm not sure how the steel would hold up in the North with all the salt and chemicals they treat the roads with up here. Powdercoated steel nerf bars rust pretty quick. I take off my steel Iron Cross HD steps in winter to avoid the headache.
    RCI also offers powdercoated aluminum but it's $390, the same ballpark as a TRD Pro skid plate. I haven't seen the two side by side, I would love to see the comparison.
  14. Jan 20, 2017 at 7:53 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    RIDET4R 5% OFF coupon for RCI OFF ROAD.
    Just bought the steel front skid with oil filter hole for $275 shipped w/C Code.
    Not much but it helped. Labor day was 15% off but I didn't have a Tundra in September.
