VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Feb 27, 2020 at 6:40 AM
    #2851
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Ooo, I didn't know the tire size could be adjusted in our ECU. That's good news!
    Wynnded likes this.
  2. Feb 27, 2020 at 6:40 AM
    #2852
    Seuqoia11
    Seuqoia11 New Member
    Looks like you also received the unreasonable customer trophy.
    NoMoTaco and MTRock like this.
  3. Feb 27, 2020 at 1:48 PM
    #2853
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I like pie.
  4. Feb 27, 2020 at 2:27 PM
    #2854
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Are the 19's able to be OVtuned yet???????
  5. Feb 27, 2020 at 2:31 PM
    #2855
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There is at least one test tune out there, maybe others. But, your ECU version may (likely) be different. So, yes and no....
  6. Feb 27, 2020 at 2:36 PM
    #2856
    19PlatinumCrew
    Dave
    Yes because Mat is working on it ….No because codes haven't been released from Toyota?
  7. Feb 27, 2020 at 2:49 PM
    #2857
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    ¯\(°_o)/¯ Dunno...
  8. Feb 27, 2020 at 3:17 PM
    #2858
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Where you seeing this? I thought it was gears only?
  9. Feb 27, 2020 at 4:57 PM
    #2859
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When non-OEM tire sizes and/or non-OEM final drive ratios are fit to our trucks, it can make the shifting really wonky. As I understand it, this can be adjusted in the Tacomas and potentially with the Tundras. I would speculate, but not assume that the speedometer could then be made to give a corrected indication as well. The discussion is over at Tacoma World.
  10. Feb 27, 2020 at 5:03 PM
    #2860
    4Runner
    4Runner New Member
    Columbia, SC
    Got it. My shifting is fine although on the way home after larger tire install it was weird. Anyway, speedo is really what I’m looking for. Seems like that should be an out of the box Toyota option... certainly Toyota could anticipate folks lifting and replacing the crappy tire/wheel stock combo.
  11. Feb 27, 2020 at 5:28 PM
    #2861
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    What size and what gears.
  12. Feb 27, 2020 at 5:35 PM
    #2862
    TruckyTruck
    Gary
    This was the first I've heard of it.
  13. Feb 27, 2020 at 5:39 PM
    #2863
    4Runner
    4Runner New Member
    Columbia, SC
    Stock gears and running 295/70/18. Last I heard from Mat there was nothing in his wheelhouse at the moment to compensate for speed.
  14. Feb 27, 2020 at 5:45 PM
    #2864
    TruckyTruck
    Gary
    Hmmm, yeah I'm realizing I may have interpreted that wrong now.
  15. Feb 27, 2020 at 6:51 PM
    #2865
    NWATundra
    NWATundra New Member
    2013 White Tundra DC
    Mat, through the Tacoma has found where he can change gear ratio and tire size to correct shifting. He did so on mine with with 5.29’s and 37’s. It did not, for me at least, change the speedometer reading. Only the vehicle speed in the ecu when read by the data logger was changed.
    Wynnded likes this.
  16. Feb 27, 2020 at 6:53 PM
    #2866
    ZPMAN
    Minnesota
    I have the hypertech and installed it for the 35" tires then took it out when went to 4.88s , but had to reinstall it agian for the gears. It was like +4 mph at 60mph, took a bit to dial in because the sensors are on each wheel and the hypertech program would not recognize the 4.88 gears. As I remember I had to put in my tire size in as 32.60 for size to get the speedo corrected.
    Toyotoholic likes this.
  17. Feb 27, 2020 at 6:59 PM
    #2867
    NWATundra
    For me the gear change didn’t affect Speedo reading at all. I assume the truck uses wheel speed sensors and not a transmission speed sensor for the Speedo.
  18. Feb 27, 2020 at 7:20 PM
    #2868
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I would guess that it would be necessary to use wheel speed sensors for Vehicle Stability Control data. I know that via Techstream individual wheel speed data is displayed.
  19. Feb 27, 2020 at 7:33 PM
    #2869
    ZPMAN
    Minnesota
    Yes that is correct, my tires are 34.7 and as I remember I think 4.60s would have put me back to stock.
  20. Feb 28, 2020 at 4:51 AM
    #2870
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    This is correct. Changing gears does not affect the speedo. The ECU reads wheel revolutions to calculate speed
    Its more complicated than that when talking about a tune. The weird shifting is a result of the ECU reading the wheel speed and calculating load. if you put bigger tires on like 37s and then gears like 4.88, you are essentially stock final drive ratio (32s and 4.30). So the ecu reads an engine load it expects to see, but the wheel revolutions are slower than it expects.
    HOWEVER, with 37s/4.88 on my truck and the first OV base tune, it shifted fine. I was happy with the shifting. The only reason I had @OVTune send me an updated base tune for tires/gears is because he said he has one for my combo which leads me to believe he did something different to make it drive better. We'll see what happens
    831Tun likes this.
  21. Feb 28, 2020 at 6:24 AM
    #2871
    coTony
    Tony
    Montrose, CO
    The change for gear and tire size was an improvement for sure (once the tune took, I had to do it twice but I am sure it was something on my end) and got rid of the premature downshifting. This is in the early stage and we will not see any of this until it is gone through more thoroughly. Matt has his hands full and trying to keep everyone happy regardless of his sanity.
    Thanks for all you do @OVTune !!
    Ericsopa, edwardg and HulkSmurf14 like this.
  22. Feb 28, 2020 at 7:54 AM
    #2872
    AZTundra
    Paul
    Phoenix, AZ
    Just throwing this out there for some feedback as I know many of you guys are supercharged as well. I just got the Magnuson installed 1 week ago, I'm heading back to the install shop today to see if they can ride along and confirm I have something that should be looked into or tell me it's nothing to be concerned about.
    The truck (2017 FFV, Magnuson with HP Tuners) seems to run great and power is smooth and responsive. There is a small amount of possible pinging, although I'm not sure that's what it is. This only seems to happen when I'm in a higher gear and lower RPM and give it some throttle to accelerate, but not enough that it will downshift. I can hear a very faint sound just for a couple seconds until the RPM's pick up then it's gone or at least I no longer hear it. I don't have any prior supercharger experience, so I don't really have anything to compare it to. I'm running 91 octane which is the best we have out here, maybe it's from that?
    If the shop does confirm it's slightly pinging in that scenario would this be something that can be tuned to correct? Are you guys having this happen as well? I know @OVTune is very busy, so I hate to throw another tune onto his pile, just trying to figure out where to go from here. I'll post up the feedback I get from the shop later today. Thanks guys!
    YotaMan likes this.
  23. Feb 28, 2020 at 10:09 AM
    #2873
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    I have the same thing in my N/A 5.7. It pings when I accelerate hard but not necessarily WOT. It doesn’t last long but still concerns me.
    I emailed Mat about it and included my logs so I’m just waiting for a reply or updated tune that corrects it.
    AZTundra[QUOTED] likes this.
  24. Feb 28, 2020 at 10:40 AM
    #2874
    AZTundra
    Paul
    Phoenix, AZ
    Just got back from the test drive with the shop owner, luckily they are only about a mile down the street from me. We were able to duplicate it and he confirmed it is detonation. Seems to be a little more consistent after the supercharger is warmed up. We added a 32oz can of Torco to the tank and I filled up right after with Shell V-Power 91 Octane. I'm going to drive it for the next week and monitor. He thinks it may just be some bad gas in my tank (91 Octane from Chevron). I'm going to follow up with him next week and see how it goes. He said we can always have Magnuson pull some timing from the tune, but that would also rob me of some HP. I'm not really concerned with lost HP, just want my truck to run right as it's my daily driver that sees about 20k miles a year and I need it to last for many years. He called the Magnuson tech while we were on the drive and told him what it's doing and he seemed to think this was a good approach as well. I was told if it's detonating now it will only get worse when the AZ heat comes.
    jc153[QUOTED] likes this.
  25. Feb 28, 2020 at 10:40 AM
    #2875
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Its happened to me a couple of times...once was due to sub par premium fuel in the middle of nowhere towing my toyhauler. The second time was starting up a hill towing a heavy boat and the truck didn't want to downshift...
    The first one was rectified by stopping and dumping some good octane booster in and limping along until I could add another 1/3 tank of brand name premium. Second was in the earlier stages of the OVTune when the gearlocking feature was bleeding over into the regular tow/haul tune and not shifting regularly under load.
    Word of advice now that you are required to run premium only...Always have some good octane booster onboard...esspecially along on trips to unfamiliar places. Avoid the parts store junk and stick with Boostane, Torco or Race Gas Fuel Concentrate. Boostane is 30% higher in cost, but the dose rate is 1/6 of the others.
  26. Feb 28, 2020 at 10:42 AM
    #2876
    AZTundra
    Paul
    Phoenix, AZ
    Are there any long term side effects of running the additives? I've heard they can cause an orange discoloration on plugs, O2 sensors, etc.
  27. Feb 28, 2020 at 10:44 AM
    #2877
    MrMax
    Rob
    Eastern Iowa, USA
    Torco always turned my plugs red in the mustangs...I switched to Boostane a few years ago and have not had any issues.
  28. Feb 28, 2020 at 10:45 AM
    #2878
    AZTundra
    Paul
    Phoenix, AZ
    I will definitely be grabbing a couple cans of Torco next week when I stop in again for these exact reasons.
  29. Feb 28, 2020 at 10:53 AM
    #2879
    MrMax
    Rob
    Eastern Iowa, USA
    For tuning I would log and have Matt revise the tune based upon good name brand premium only. I usually only add a little Boostane to the first fill come spring to compensate for last years fuel in the tank. That and If I know I will be pulling very heavy in high heat in the hills. Also If I know I am going to be running one of the car's or bikes hard. Again I prefer Boostane as it only requires 0.13oz/gal to bump 89 back up to 91. Torco if I recall requires 0.8oz/gal to achieve the same result
  30. Feb 28, 2020 at 11:13 AM
    #2880
    Midway
    Midway New Member
    Are there any fuel stations around you that carry unleaded 100 octane,? Maybe a drag/race track? Sometimes, I'll mix 100 with 91, cheaper than dumping cans in..
    AZTundra[QUOTED] and YotaMan like this.
Thread Status:
