Just joined the Tundra bed rust community.....
Discussion in 'New Member Introductions' started by TechWrench, Feb 27, 2020.
  1. Feb 27, 2020 at 8:14 AM
    TechWrench
    TechWrench [OP] New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    Well, I just got my '08 back from body shop yesterday (towing incident back in November), and had a good news/bad news day.
    Good news was the repair shop did a great job replacing right side fender and bumper on bed (along with other associated stuff). Also good news, they found a magnetic key box under bed that held spare valet key, which I didn't know was there. Previous owner must have hid it and dealer that sold it to me also wasn't aware of it. So, I now have all three original keys for truck.
    Bad news: When they started to remove box to replace fender, they found extensive rust to the bed supports and mounting bolts areas I wasn't aware of. Truck came with factory bed liner, and I hadn't had the chance to remove it to check under it. There isn't a lot of surface rust visible inside the bed, all the damage is to the supporting elements underneath. Other 'good' news is they said the main frame rails are in good shape. Apparently the PO did have the frame undercoated.
    The body shop was able to reinstall the box, but suggested that I not put any heavy loads in it. They said it is only a matter of time before the existing mounts will no longer be able to support the bed in place. Not what I wanted to hear.
    They suggested I think about replacing the box, if I intend to keep the truck, with either a new one or try to find a good used one. They also indicated that trying to repair the damage to the bed supporting supports wouldn't be easy to do.
    I did some quick searching, and there doesn't appear to be many used bed assemblies in my area.
    I guess my question to the forum is, can the bed supports be replaced, or am I looking at a new bed? I haven't, because of current weather, been able to get underneath to look at the damage myself, so not sure how extensive it really is.
    I really like the truck, and replacing it at this time is not financially feasible for me. I have owned two 4th gen 4Runners prior to the Tundra, and am fully aware of the frame rust issues they have. I had to take the last one off the road a year ago, when it would no longer pass a safety inspection because of the extensive frame rust.
    Bummed out in NEPA.
    Mcoop, Prostar 190 and Pinay like this.
  2. Feb 27, 2020 at 8:15 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal!
    Mcoop and TechWrench[OP] like this.
  3. Feb 27, 2020 at 8:18 AM
    V8Tundra4x4
    V8Tundra4x4 New Member
    NY
    Pics?
    Was it a drop-in liner?
    I bought an old Dodge Dakota that was used as a service truck. It had a drop in liner. When I removed it I found both wheel arches rotted out. Kind of a bummer since the rest of the truck is relatively rust free. I plan to patch it with sheet metal and epoxy, then do a spray-in liner since there's only paint on there now.
    On yours, are the bed supports part of the frame? Pics would help for sure.
  4. Feb 27, 2020 at 8:54 AM
    TechWrench
    Gary
    Hawley, PA
    Yes, it is a drop in bed liner. But from what I see, and from others reporting on their vehicles with same issues, the bed liner is not the problem. These beds and underneath supports are rotting from below. There are also multiple owners reporting that they had similar rust issues with spray-in liners. In my case, the PO installed a rigid bed cover which completely covers the bed, and the edges, so any rain just runs down the outside of the fenders and tailgate, not into the bed itself. I only have a few pics from the body shop, which are difficult to see the problem. I will take some pics of my own, once I get some decent weather.
  5. Feb 27, 2020 at 9:29 AM
    15whtrd
    15whtrd Mr. Blonde
    You could put a newer body style bed on there! You could then even update your fenders and grill and hood and make it look like a brand new truck. Find a couple of donors in the junkyard.
    I do imagine a good fabricator could remake the mounts underneath the bed. Not sure if they sell them separately.
    BENWALES and TheBeast like this.
  6. Feb 27, 2020 at 9:32 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Bummer, but welcome from CO
    TechWrench[OP] likes this.
  7. Feb 27, 2020 at 9:45 AM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    Yep...It's an issue. I had my box replaced on my 2008 under warranty several years ago. I live in MN, so it didn't take long for the rust to show up. It was a design flaw that rusted from the bottom up. If you use a bed liner or spray-in liner, you wouldn't catch it until it was too late. I believe it was redesigned for the 2011 model year. I have the new re-designed box now.
  8. Feb 27, 2020 at 10:36 AM
    Welcome from TEXAS
  9. Feb 27, 2020 at 10:47 AM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    I found a white used bed online and had it shipped from Texas to NY for around $2k. Had the bottom and bed shot with Line-X and installed. Quick polish and the paint was almost a perfect match so I didn’t incur paint costs. I also just had the frame replaced so it made sense to get rid of all of the cancer. If it makes sense replace it. If it doesn’t make sense, trade it in on something in better shape (if feasible) before it becomes a real problem.
  10. Feb 27, 2020 at 10:58 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    It's posts like this that remind me how good it is to live in California, and not have to worry about rust as much.
    Welcome from SoCal!
  11. Feb 27, 2020 at 6:25 PM
    Welcome from Ohio
  12. Feb 27, 2020 at 6:29 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  13. Feb 27, 2020 at 7:02 PM
    TechWrench
    Gary
    Hawley, PA
    Ok, so when they replaced the box on your '08, they installed a newer 2011 box. Did they have to replace the tail lights along with the new bed, or did the ones from '08 fit the newer box? I also wonder about the fitment for the '08 tailgate on the newer box.
  14. Feb 27, 2020 at 7:04 PM
    Mattyc
    Matthew
    NY
    Not stock
    it all fits from 2007-2013.
  15. Feb 27, 2020 at 7:08 PM
    TechWrench
    Gary
    Hawley, PA
    I am not sure that a 12 year old truck would warrant that much work. And, except for the rust under the bed, the truck is in very good shape. From 20 ft, you would be hard pressed to find any imperfections in the body, it is that good.
    15whtrd[QUOTED] likes this.
  16. Feb 27, 2020 at 7:10 PM
    TechWrench
    Gary
    Hawley, PA
    Wow, I did not know that. I guess that will widen my search possibilities quite a bit.
    Thanks.
  17. Feb 27, 2020 at 7:21 PM
    TechWrench
    Gary
    Hawley, PA
    I gotta say that I am very surprised, and glad to find the amount of participation from members in my short time here. When I first bought the truck, I searched for some Tundra specific forums, and joined a few, but none of them have come close to the level of activity that I see here. I, as I mentioned earlier, was a 4Runner owner since '03 when I bought an SR5 new. I tried several forums at that time, and finally settled on TR4.org. I have been an active member there since then, even after I traded my last 4Runner in on this Tundra, I still check in regularly. I liked TR4.org because the community was ready to welcome new members, and always ready to offer help and advice to those who asked. So far, I get the same feeling here, and i like it.
    Boerseun, ToyoMafia, kparrow and 2 others like this.
  18. Feb 27, 2020 at 8:10 PM
    TechWrench
    Gary
    Hawley, PA
    As long as I am on a roll, I have another question about the truck beds. While looking up parts to repair my bed, or replacement beds, I keep seeing two different bed options. One with a 'Sport Package' option, and one without. How does one know what you have? Since I didn't buy the truck new, I am not sure what options I actually have. All I know for sure is that it is an '08 SR5 Double Cab, with the 5.7 engine and the 6.5' bed, and a chrome trim rear bumper. Thee are TRD Off Road stickers on the rear bed fenders.
    Is there a vin decode site that will give you the original equipment as delivered information based on the vin #?
    Thanks again.
    PS: I did a search for the '08 Tundra sales brochure, and now have the answer I was looking for. Thanks again.
  19. Feb 28, 2020 at 1:03 AM
    Mattyc
    Matthew
    NY
    Not stock
    Doesn’t matter. All of the beds are the same for Gen 2 Tundras
    TechWrench[OP] and 15whtrd like this.
  20. Feb 28, 2020 at 2:58 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Welcome from Florida!
    The truck bed are sold in section from the dealer, you can probably order just the bottom part and have the body shop remove and replace it from your old one. But it might still cost you the same as getting a used complete bed. But it will be new without the risk of getting shipped with a rusted mounting points.
  21. Feb 28, 2020 at 8:29 AM
    duerrs
    duerrs Semper Fi!
    My original '08 lights fit in the new box. As for the tailgate...I seem to remember that being new as well, but can't recall.
  22. Feb 28, 2020 at 8:45 AM
    TechWrench
    Gary
    Hawley, PA
    Thanks;
    I gather, from what info others have posted, that the beds from '07-'13 are interchangable, as long as they are from the same model configuration.
  23. Feb 28, 2020 at 8:54 AM
    duerrs
    duerrs Semper Fi!
    I believe that is correct as they didn't redesign the box until 2014. Thanks!
  24. Feb 29, 2020 at 11:06 AM
    Cjcanu01
    Cjcanu01 New Member
    11777C1B-B679-4D46-BD2C-9C7F11CE63C8.jpg 3AA48335-5CFF-40AF-8040-979920D24AB1.jpg 83291056-E0EB-4ECC-AA28-2BB228840ED9.jpg D941D5B1-DDDF-4107-8992-C3D195F471C0.jpg 6DC788CA-7D99-4939-ADC8-EA83FA0ECDB8.jpg My 08’ 5.7...current status
    As you can see, severe rust issues in 3 spots all near bed mounting fasteners. Rust initiated from underside of the bed and started bubbling up under the Line-x which was applied when I bought the truck new. Started cutting away so damage could be viewed. This is just 1 of 3 problem area’s. Bed cross members are trashed and will be replaced with available kit or new ones will be engineered. Holes will be capped with new matching metal bed pans sectioned out and welded. New Rhino liner will then be applied including underside of bed.
    As for the truck frame itself, I was fortunate. Mainly just surface corrosion with a couple of areas on the cross members suffering from more extensive damage but no perforations and structurally sound. Frame was cleaned up with some grinding and mostly wire brushed. A good quality industrial rust inhibitor was then applied. The frame and other various parts will also be getting Rhino lined. Approximately six weeks with truck being out of commission. 3AA48335-5CFF-40AF-8040-979920D24AB1.jpg83291056-E0EB-4ECC-AA28-2BB228840ED9.jpgD941D5B1-DDDF-4107-8992-C3D195F471C0.jpg6DC788CA-7D99-4939-ADC8-EA83FA0ECDB8.jpg
  25. Feb 29, 2020 at 11:43 AM
    Mattyc
    Matthew
    NY
    Not stock
    Super clean truck otherwise! Mine was the same situation except the frame was rotted bad enough to warrant a replacement care of Toyota. I footed the bill for the replacement bed and linexed everything top and bottom to hopefully mitigate or at least slow the rust looking forward.
    Cjcanu01 likes this.
  26. Feb 29, 2020 at 1:37 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Yep, Toyota "quality". :rolleyes:
    I didn't know about nor notice the rust in my bed until after I bought the truck. Not All of these trucks are bad but after spending so time here on the forum I've learned a lot. Tundra's have a serious rust issue that Toyota appears to not want to own up to at least if you're out of warranty. Buyers really need to be educated before buying a used one. I didn't think a truck that spent most of it's life in Portland Oregon could be so rusty.
    I have some buyers remorse with my truck. I'm just hoping my bed won't collapse any time soon. I just can't justify putting any money into repairing the rust.
    I'm really hoping for a class action law suit to address it.
  27. Mar 9, 2020 at 9:44 PM
    offroadlife
    offroadlife New Member
    2011 Rock Warrior
    New here... First post. Thank you all for great info and cjcanu01 for the picture update. I recently bought a 2011 dbl cab Rock Warrior. I took off the plastic Toyota bed liner yesterday and discovered massive rust at the joints similar to the pictures shared above. Looked under and it’s bad too.
    Main question(s) is where can I find reliable info on TOYOTA warranty. Truck only has 64k miles but lived in upstate New York the past 9yrs. Rust is bad in other places near rear bumper.
    Also looking for diy on removing the box so I can better assess undercarriage damage.
    Cheers!
  28. Mar 10, 2020 at 12:36 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    If you have any frame issues you may be covered for 12 years after date it was put in service.
    The bed rust, AFAIK, is SOL after 5 years.
  29. Mar 10, 2020 at 1:07 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    @TechWrench I'm also in NEPA, I will keep my eyes open for beds on Facebook and Craigslist for ya
  30. Mar 10, 2020 at 1:24 PM
    TechWrench
    Gary
    Hawley, PA
    Thanks, I took a quick look underneath, while working on installing a backup camera, the other day, and it doesn't look as bad as the body shop led me to believe. Once the weather warms up a bit more, I will get it up on jackstands, and take a closer look and see what is going on.
    MotoTundra[QUOTED] likes this.
