growling noise
Discussion in '1st Gen Tundras (2000-2006)' started by CYMRU, Feb 25, 2020.
  1. Feb 25, 2020 at 9:37 AM
    CYMRU
    CYMRU [OP] New Member
    2006tundraext.cabv6
    My 2006 tundra has a growling noise coming from under the dash near the glove box. Any idea what could be causing it ? It sounds sort of like an electric motor running, and is not continous.
  2. Feb 25, 2020 at 10:33 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Heater fan motor is located under the GB....lubrication time ?
    TX-TRD1stGEN likes this.
  3. Feb 26, 2020 at 4:50 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Like bubba said. Heater fan or pissed off animal hiding under there.
    Turn off your heater and see if it stops
    BubbaW likes this.
  4. Feb 27, 2020 at 7:54 AM
    CYMRU
    2006tundraext.cabv6
    The heater is not on when the noise is present, and it is not a constant noise. Most times it stops when you accelerate. Everyone who replied seems to think I know nothing about autos or that this is a good time to make jokes. The thing is I've never owned a Tundra and thought maybe some of the owners out there had heard of the same problem.
  5. Feb 27, 2020 at 8:01 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  6. Feb 27, 2020 at 8:09 AM
    Linuxmale
    Linuxmale 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
  7. Feb 27, 2020 at 8:18 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    You really have to understand that most of us are "Good-ol-boys" and bust stones.
    You will get the help you need but you are going to pay a little for it with smart asses being smart asses.
    If your truck is white I will tell you that your reason is because it is not black. Then come in with something to check.
    So lets say you know your way around a truck.
    When did it start. what were you doing, did you change anything?
    If you have the heater off and it does it is it set to defrost?
    Change it to anything other than a defrost setting like cabin or floor only. Does it still do it?
  8. Feb 27, 2020 at 8:28 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Won’t speak for @TX-TRD1stGEN but if only 2 responses represents “everyone” to you, so be it. Given the info given, both suggestions had a possibility of being correct.
    Suggest next time you drop by, leave your damn horse at home so it won’t be so high when stepping off.
    Oh....Welcome to Tundras. com
    T
  9. Feb 27, 2020 at 9:26 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Did you check for a cat yet??
    bmf4069 and BubbaW like this.
  10. Feb 27, 2020 at 9:38 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Well, if happens when the blower fan isn't running, then there are some reptiles around here that would make a similar noise when disturbed. Maybe you've got vipers hibernating in your heater duct.
    Happens only with the engine running? Might need to purge the air out of your cooling system (air trapped in heater core?).
  11. Feb 27, 2020 at 10:17 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Is Nancy in the house?:D
    Lets hear the conditions when the noise presents itself.
    You already said the fan is not on and noise still happens. Disappears when accelerating.
    Maybe you can crawl up under the truck when you hear the noise and see where/if its coming from underneath. Sounds can be hard to pin point sometimes.
    Make sure your parking brake is applied. Have someone accelerate in Park and let it come back to idle.
    BubbaW likes this.
