  1. Feb 24, 2020 at 4:28 PM
    Ditbwc
    Ditbwc New Member
    2014 Tundra SR5
    So I installed the TRD OEM LED headlights. Got them safe and fast from @Roman and used @iHacker harness. That is one quality harness. I had trouble with the grommet. Had to figure out how to get it through since it is in a awkward spot and made of really tuff rubber. It involved a 14 gauge copper wire, electrical tape and lube.
  2. Feb 24, 2020 at 4:32 PM
    twistedcricket
    twistedcricket New Member
    Paul
    Omahell, NE
    2014 SR5
    TRD rear sway bar, power fold tow mirrors, Firestone airbags, LED OEM fogs
    New "summer" tires went on today and went with Michelin Defender LTX M/S.
    NAFlash, Rustyscrew and Deafmate like this.
  3. Feb 24, 2020 at 5:07 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Update....
    I WON! IT DIDNT SNOW!
    GODZILLA, Ostrich, Deafmate and 3 others like this.
  4. Feb 24, 2020 at 5:23 PM
    Blue Thunder
    Washington
    She was dirty...
    After a wash I always check the fluids. This little area in the washer fluid reservoir drives me nuts. It's open at the bottom, but sealed at the top. So when you fill it up, you get this area that doesn't fill because the air is trapped. Drive a few miles and it all evens out, but then it looks like you've already used 20% of the capacity. It's wasted space that you cannot fill and this kind of stuff tweaks my brain...
    So today I fixed that problem. Drilled a small hole at the top and cleaned off the shavings. It's a little low. I'll drill a larger hole higher up this spring when it's warm and I have time to pull the reservoir out
    Now things are balanced...you're welcome World.
    kbark, NAFlash, superdenk and 18 others like this.
  5. Feb 24, 2020 at 6:05 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    Upgraded the Cooper STT PRO’s to nice and quiet Nitto Ridge Grapplers. Remounted the Cooper’s onto the stock TRD OR wheels.
    Cement4WD, kbark, NAFlash and 27 others like this.
  6. Feb 24, 2020 at 6:08 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Did TRD front sway bar and installed center console wireless charger kit.
  7. Feb 24, 2020 at 6:16 PM
    What about drilling a hole in the black cap? Less chance of the bottle cracking down the road and the cap is cheaper to replace.
    Deafmate likes this.
  8. Feb 24, 2020 at 6:19 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Nice set up. I have a tonneu cover, but I am trying to figure out a rack to go with it. Like your set up.
    sea_weathered[QUOTED] likes this.
  9. Feb 24, 2020 at 6:49 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Took it to dealer (yeah I know...) for oil change, tire rotation, cabin filter change. Waited 2 hours, I'm super close to just doing it myself, but with no pull in garage kind of sucks in WI winters.
    Proceeded to throw it in sequential, turn on tow/haul mode and took 'the long way home' with no music on. Just the sweet sweet sound of that V8 through my bamf exhaust.
    :burnrubber:
    Currently drinkin some beers while crankin tunes making dinner. :oldglory:
    Mcoop, Deafmate, Fotnot and 4 others like this.
  10. Feb 24, 2020 at 7:00 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Little more audio work today. Taking it slow. Only one door left! Lol
  11. Feb 24, 2020 at 7:42 PM
    tdiantonio
    tdiantonio New Member
    Looks Awesome..love the height and stance
  12. Feb 24, 2020 at 7:56 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thank you!...new wheels/tires are ordered and on the way, can’t wait!...I’ll be doing an update on my YouTube channel of the fitment and possible trimming if any is needed!...they should be here in a few days!
  13. Feb 24, 2020 at 8:20 PM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    At least you have good taste in beer
    Flyinryank[QUOTED] likes this.
  14. Feb 24, 2020 at 8:34 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Installed new rotors, painted the calipers while I was at it.
    Dgjman, kbark, NAFlash and 17 others like this.
  15. Feb 24, 2020 at 8:53 PM
    Blue Thunder
    Washington
    The cavity isn't under the black cap, it's another chamber. Have to drill thru the main chamber to let the air escape as you fill and so the waterline can rise. I can't imagine the hole will create a crack, the reservoir is built like a tank..
  16. Feb 24, 2020 at 9:05 PM
    ostm282
    ostm282 New Member
    Stock 2018 Tundra Limited Silver
    2" leveling kit installed up front
    So this isn't anything directly related to my truck, but I repurposed something that's been in my garage forever. I used to ride this thing on the street but I'm old now and would probably kill myself if I tried using it. I wanted something that made mounting up the tires a little easier so I tried using my skateboard as a rolling lever to lift the tire up and roll it onto the studs without struggling. I can't be the first to discover this but good lord does it make things easier. Give it a try!!IMG_20200223_161836.jpg
    kbark, NAFlash, mgm16trdpro and 24 others like this.
  17. Feb 25, 2020 at 3:39 AM
    :thumbsup:
    Blue Thunder[QUOTED] likes this.
  18. Feb 25, 2020 at 4:32 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm about to need to make something similiar to this with my new tires/wheels being 110#'s each. *think smarter, not harder* lol
    Blue Thunder, Deafmate and dpast88 like this.
  19. Feb 25, 2020 at 4:34 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Going with the 6" on 325/60R20(35.5x12.8R20) BFG KO2's 20X10 with -18 offset HardRock Painkillers
  20. Feb 25, 2020 at 6:13 AM
    Deafmate
    Deafmate The Deaf Guy
    Houston. TX.
    2018 Cement SR5 4x4 Crewmax
    UnderCover Flex bedcover NSV Nightrider Lightbar
    Damn that looks good.
  21. Feb 25, 2020 at 7:15 AM
    thrustmaster
    thrustmaster New Member
    Joel
    dallas
    2016 Tundra Crewmax MGM 2WD
    Installed my TRD skid plate
  22. Feb 25, 2020 at 7:56 AM
    AZTundra
    Paul
    Phoenix, AZ
    Got any pictures of the CV angles by chance? I'm at 3.5" on the front and would like to see how mine compare. Thanks!
    Dgjman[QUOTED] likes this.
  23. Feb 25, 2020 at 8:08 AM
    AZTundra
    Paul
    Phoenix, AZ
    I've heard others struggled with the grommet as well. That was a piece of cake for me compared to trying to depin the wire under the dash. No matter what I couldn't get it to release - ended up winning the battle in the end, but that step wasn't easy for me.
    War_Wagon312 likes this.
  24. Feb 25, 2020 at 8:18 AM
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    What light bar mounting system is behind the grill and do you like the output? I’ve got a “bull bar” type mount for a 30” I’m not happy with.
  25. Feb 25, 2020 at 9:59 AM
    rdrasher
    rdrasher New Member
    2020 sr5 dbl cab
    I got this truck for Christmas from my wife, so these "upgrades" have been over the past several weeks (rims mounted today). But nobody wants 7 or 8 individual posts about the same truck! :D
    wireless charger
    large cup holder (because the regular ones are too dang small)
    console tray organizer
    Bak Industries Revolver x4 bed cover
    TRD rear sway bar
    Husky floor mats all the way 'round
    N-Fab Podium steps
    KMC 544 Mesa wheels(black machined w/ grey tint)
    Now I think it's time to give the bank acct. a break! Until I need new tires..........;)
    kbark, NAFlash, mgm16trdpro and 18 others like this.
  26. Feb 25, 2020 at 10:21 AM
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    JBA UCAS, AJT Interior trim pieces. received_1158268934504976.jpg 20200225_084934.jpg 20200216_154320.jpg 20200102_153319.jpg
  27. Feb 25, 2020 at 10:48 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    https://heiseled.com/product/HE-HDR32
    Silly bright and I'm happy with it. Pricy too but worth it
  28. Feb 25, 2020 at 10:54 AM
    Had some free time today for a change.
    AJT climate control knobs and trim rings
    Meso 4x4 trim ring
    TRD PRO dash pad with AJT vent rings
    AJT vent ring & Tuffskinz instrument cluster trim.
    Didn't do the radio bezel vent rings yet because I want to paint it black when it warms up.
  29. Feb 25, 2020 at 11:41 AM
    Part_time
    Oregon
    Well look at you, Genius
    GODZILLA likes this.
  30. Feb 25, 2020 at 11:43 AM
    Part_time
    Oregon
    Like the gauge trim were did you find that
