Dees 2018 Cement SR5 Crewmax Family (Adventure) Vehicle
Discussion in '2.5 Gen Builds (2014-2021)' started by DeesCrewMax, Jun 14, 2018.
  1. Jun 14, 2018 at 9:14 PM
    DeesCrewMax
    DeesCrewMax [OP] New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    2018 Tundra Crewmax (purchased 4/30/2018)
    SR5
    Cement
    SR5 Upgrade Package​
    Upgrades:
    SnugTop Rebel Topper
    Flip up front window
    Pet Screens
    Pro-lock
    Rhino Rack Roof rack (59" Vortex bars)
    (Removed) LED Bulbs from Amazon
    H4 low/hi beam LED Bulbs with a nice cut-off (Removed due to wierd eye strain when driving at night)
    H11 LED Bulbs
    Yakima RocketBox 16
    Yakima Sup-Pup Board Carrier
    Yakima King-Pin 4 Bike Rack
    Rhino Rack Batwing Awning:
    DeeZee Custom-Fit Truck Bed Mat
    Toyota OEM LED Light Housings (with Retrofit Source adapters)
    Tint (3M Premium 15% Front + 30% Rear)
    RB20 Running Boards (mounted backward)
    Alpine Amp
    6112 / 5160 (Shims (1 / 1) + Shackle at top settings w/carrier drop)
  2. Jun 14, 2018 at 9:22 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Congrats on the new truck! Any pictures of the canopy set-up?
  3. Jun 14, 2018 at 9:43 PM
    DeesCrewMax
    Deric
    Thank you! We are loving it so far. The Batwing Awning / Canopy was great, but i was reluctant to leave it up when the wind really picked up. Seemed stable when it was staked down, but didn't want it to break and we did have tree cover at this particular site so it wasn't really an issue. Setup is quick and easy and everyone who has seen it has been really impressed with the design.
  4. Jun 14, 2018 at 9:46 PM
    DeesCrewMax
    Deric
    SR5
    Cement
    SR5 Upgrade Package
    Winning8 likes this.
  5. Jun 14, 2018 at 9:48 PM
    DeesCrewMax
    Deric
    Pet Screens
    Pro-lock
  6. Jun 14, 2018 at 9:51 PM
    DeesCrewMax
    Deric
    H4 low/hi beam LED Bulbs with a nice cut-off (Removed due to tremendous eye strain when driving with headlights on (day or night))
    These were 40 dollar LED bulbs from Amazon so i wasn't really surprised. Some people might have better luck with a higher quality LED bulb, but ultimately the halogen housing is not meant for LEDs so i placed an order with Roman / Cool Springs Toyota for the real deal OEM LED Housings
    H11 LED Bulbs
  7. Jun 14, 2018 at 10:02 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Nice rig. I’m planning to get this canopy, but will need a garage with an 8’ door first, lol
  8. Jun 14, 2018 at 10:13 PM
    DeesCrewMax
    Deric
    You may need closer to an 8' door with your lift/tires/etc, but at stock height (my fender well is 38.5ish off the ground) the top of my awning is just about 81" off the ground (just measured (twice) based on your comment). I did mount the awning in the "lower" position (its a 90degree angle that comes off the rhino rack and it can either go UP or DOWN. I mounted it DOWN and i still have enough clearance to open the rear doors on the cab without issue. I'm only 5'9" though, so if you are taller you may want it mounted UP (above) the cross bar.
    gosolo[QUOTED] likes this.
  9. Jun 15, 2018 at 2:44 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @DeesCrewMax
    I’m barely able to slip into my garage now, with the towers and bars removed from the rack. So even mounted below the bars it would not fit. If you have a chance, I would love to see some more pictures of your rack and canopy, both in the stowed and extended position. We’re leaving (permanently) for Oregon in a few weeks and I believe the canopy will be a perfect accessory for mushroom hunting
    Winning8, TXMiamiFan and Black Wolf like this.
  10. Jun 15, 2018 at 4:06 AM
    Welcome from CO!
  11. Jun 15, 2018 at 5:27 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Awesome truck!
  12. Jun 15, 2018 at 6:39 AM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon!
  13. Jun 15, 2018 at 6:56 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Lookin' good! Do you have any pics of how far you Vortex bars stick out from your canopy? I'm debating between the 59" and 65" myself...
    Edit: Never mind, I just didn't look down far enough in your post! Looks like those 59" bars fit well.
  14. Jun 15, 2018 at 6:59 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Nice looking set up.
  15. Jun 15, 2018 at 8:16 AM
    DeesCrewMax
    Deric
    I will try to get some additional pics later today of the rack/canopy as it sits as another user requested so maybe those will be of additional help to you. The 59" bars are pretty close to the width of the truck at the TOP, but certainly narrower than the widest part of the truck. Initially i felt i had gone too narrow, but i think it really depends on which attachments you plan to use with it. My SUP carrier extends beyond the edge of the cross bars (the mounts are not on the outermost edge of the attachment so it extends out a few inches) and the Batwing awning/canopy also lives beyond the width of the rack. I think if i had gone 65" it might be a bit wide. However with my SUP rack + Yakima box + awning i don't have much additional room for anything like a roadshower or mounting tractionboards or whatever. I'll try to get some pics up that show the width with my attachments incase that helps anyone make the decision.
    For what its worth, my subaru had Vortex bars on it and the car was totaled in a hail storm last may. The rack emerged unscathed from the battle and was used on another vehicle for the past 10 months without issue. I'm a big fan of Rhino products at this point and especially the 2500 Vortex bars.
    BuckWallace[QUOTED] likes this.
  16. Jun 15, 2018 at 10:40 AM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Thanks, I appreciate it. But yeah, the Rhino stuff looks pretty solid, and it's relatively cheap compared to a similar setup from Thule or Yakima. After you add all the feet, towers, crossbars, and lock cylinders you're well over $500 from those guys...
  17. Jun 16, 2018 at 4:11 PM
    DeesCrewMax
    Deric
    Sorry for the delay. Had a long day at the office yesterday. Hopefully these pics help:
    Winning8 and gosolo[QUOTED] like this.
  18. Feb 23, 2020 at 7:00 PM
    DeesCrewMax
    Deric
    6112 / 5160
    Front @ 1.9 + Boss4x4 Shim
    Rear Boss4x4 Shackle at top setting with bushing
    C88D1720-C053-40AF-B527-BA707C859AC4.jpg FB40CE66-B91C-4F2A-B387-DCD0517B12CD.jpg D9C9634E-BFAC-4DE3-8EDB-00BC15D7D502.jpg DD02BCBD-2C55-40CD-ADC8-6F235311CCEE.jpg47D79129-D6A4-4BC7-8AC7-84C481BA8A4A.jpg
  19. Feb 23, 2020 at 7:04 PM
    DeesCrewMax
    Deric
    RCI Skids:
    Aluminum Package (Front Engine Skid + Transmission/Transfer Case Skid)
    2F7F5C26-DD0D-41AF-8403-B5F383CD0884.jpg 0D02401C-3071-480C-ABF2-E5A235056E7A.jpg
  20. Feb 23, 2020 at 7:23 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Welcome from NCal
    DeesCrewMax[OP] likes this.
  21. Feb 23, 2020 at 7:35 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    OOOO dat a nice!!!!!
