Antenna base replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by Roscoe56, Feb 22, 2020.
  1. Feb 22, 2020 at 8:48 PM
    Roscoe56
    Roscoe56 [OP] New Member
    2015 Tundra SR5
    Need to replace antenna base.
  2. Feb 22, 2020 at 8:52 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    PM @Roman he's the forum parts guy.
    Roman and NewImprovedRon like this.
  3. Feb 22, 2020 at 8:56 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Nice opening post
  4. Feb 22, 2020 at 9:09 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    What did you do?
    Break the antenna off or strip out the threads in the hole?
    If you broke the threaded mast shaft off in the hole, you can get it out with a left handed/twist drill bit and a lot of patience and precision.
    https://www.amazon.com/gp/product/B0014WH9AC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    A replacement mast is a lot cheaper than replacing the base.
    Mast.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-radio-antenna-mast-863090c020?c=Zz1lbGVjdHJpY2FsJnM9YW50ZW5uYS1hbmQtcmFkaW8mbD0zJm49U2VhcmNoIFJlc3VsdHMmYT10b3lvdGEmbz10dW5kcmEmeT0yMDE0JnQ9c3I1JmU9NS03bC12OC1nYXM=
    Base.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-antenna-assembly-863000c090
    These may not be the correct parts, I'm running on an assumption and a beer buzz..
    @Roman will hopefully chime in Monday.
    BTW, he is my Toyota Tundra hero..:thumbsup:
    No kidding...
    Welcome to the forum?:eek2:
  5. Feb 24, 2020 at 8:50 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  6. Nov 19, 2020 at 8:22 PM
    TXTundra2722
    2015 Black Tundra
    And just like that.........Roscoe was never seen again! I really hate when people join the site just to ask a question and they aren't even nice about it.... what a dick!
    :burp:
    tightywhitey likes this.
  7. Nov 21, 2020 at 2:46 AM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    I hear you. Look at all the information he was provided and not even the common courtesy to acknowledge it.
  8. Feb 4, 2021 at 3:41 PM
    TanasiRob
    TanasiRob New Member
    Williamson County TN
    T3 Black - 2018
    Well sheeeeit- I'll take his place on the gratitude train, but the links Roman provided won't open for me.....
    My threads are stripped BTW... 2018 SR
  9. May 2, 2021 at 12:50 PM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    What did you do to fix the problem?
    Mine broke off.
  10. May 2, 2021 at 12:59 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    I got it out.
    Looked at my drill bits and there was one with a flat tip and reversed it right out.
