reno_tundra's super fast white CM 4x4 build
Discussion in '2.5 Gen Builds (2014-2021)' started by reno_tundra, Jun 11, 2019.
  1. Jun 11, 2019 at 10:57 PM
    reno_tundra
    reno_tundra [OP] New Member
    2019 White Tundra CM SR5
    Current Mods
    - Toytec Radflo/BOSS hybrid lift
    - SPC UCAs
    - Icon rebounds
    - 315/70's falken wildpeaks
    - RCI Rock Sliders
    - RCI Engine/Transmission skid plates
    - Bakflip MX4
    Plans
    - CMC
    - Get rid of the chrome
    - Smaller antenna
    - Remote start
    As she sits today:
    9F8415E9-C122-4392-B164-9021D1175959.jpg A974E34E-C756-4381-84F1-A818926817BD.jpg
  2. Jun 11, 2019 at 11:06 PM
    reno_tundra
    Some goodies waiting for other parts or a day to get installed
  3. Jun 12, 2019 at 12:49 AM
    reno_tundra
    No way!! But I appreciate you MGM-ers...White wouldn’t be the fastest color if MGM wasn’t so slow :burnrubber:
  4. Jul 20, 2019 at 10:10 AM
    reno_tundra
    More goodies coming in!
    eccracer104, Rica25 and Blueknights75 like this.
  5. Jul 23, 2019 at 7:56 PM
    reno_tundra
    they keep trickling in...one more left!
    Rica25 likes this.
  6. Jul 23, 2019 at 8:00 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Thats very true. MGM is terrible. Black or White are the only real acceptable colors for a truck.
  7. Jul 23, 2019 at 8:03 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
  8. Jul 23, 2019 at 8:08 PM
    reno_tundra
    Lol, I can accept that from a fellow northern nevadan :fistbump:
    TundraLaw[QUOTED] likes this.
  9. Jul 29, 2019 at 7:20 PM
    reno_tundra
    Got the lift all done and aligned with new shoes!! Updated pics in the OP!
    eccracer104 and AZTundra like this.
  10. Sep 6, 2019 at 8:22 PM
    reno_tundra
  11. Oct 13, 2019 at 7:57 PM
    reno_tundra
    Thanks to @eccracer104 for helping me get an mx4 sorted out!! newest addition to the build:
    Rica25 and eccracer104 like this.
  12. Jan 11, 2020 at 7:22 PM
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    Stock uca? If not who did your alignment? Not really fond of most shops out in Fallon when it comes to UCAs that change things.
    Rica25 likes this.
  13. Jan 11, 2020 at 8:25 PM
    reno_tundra
    @Predator Tundra I have the SPC UCAs. I got my alignment done at Ayres Muffler Brake & Alignment off Shaber Ave in sparks. Those guys are awesome! Highly recommend them. They hit the numbers I brought them dead on, then I went back to push the caster more to avoid the body mount and they did the second round quick and cheap. All in all great experience.
  14. Jan 11, 2020 at 8:27 PM
    reno_tundra
    Once I get done moving back in these bad boys are going on!
    Flyinryank likes this.
  15. Jan 12, 2020 at 9:32 AM
    Overisland
    Overisland New Member
    Tony
    Polson, MT
    2020 Tundra Voodoo Blue Sport
    Love the build! I have some Icon Rebounds on order, was nice to see them on your truck to get a reference of how my tires will look.
  16. Jan 12, 2020 at 12:21 PM
    reno_tundra
    Thanks @Overisland ! Yea they are sweet! One caution about them is with the 17s make sure they put the balancing weights as close to the inner spoke as possible to clear the brakes otherwise you’ll hear a little rub on the caliper and it’ll drive you nuts! lol
  17. Jan 13, 2020 at 9:56 AM
    Overisland
    Tony
    Polson, MT
    @reno_tundra thanks for the pro-tip, I wrote that down in my notes to make sure I cover when I get them installed. I have a cab mount chop scheduled, do you rub on your at all or the front inner fender liner?
  18. Jan 13, 2020 at 11:18 AM
    Fishin RGV-Trd Pro
    Fishin RGV-Trd Pro White is faster
    Alex
    RGV Texas
    2011 White Toyota Tundra Limited
    Sweet ride. Looking at getting same size tires. What is the offset on those rims?
    :thumbsup:
  19. Jan 13, 2020 at 12:07 PM
    reno_tundra
    @Overisland I do not rub on my body mount day to day, but if I articulate the suspension a lot i will a little so I have a CMC coming at some point too. I did have to push my caster to about 6* to avoid the mount (so when I do get the chop I will pull that back closer to spec). I also did rub on the front (especially with all the caster), so I had to grind away the bottom of the bumper a little and heat/push the fender liner forward to avoid it. All in all I didn’t have to chop/manipulate it *too* much, but some was needed. I can snap an after pic if you’d like
  20. Jan 13, 2020 at 12:08 PM
    reno_tundra
    @Fishin RGV-Trd Pro Thanks man! I almost went a little smaller to avoid rub but I’m really happy I didn’t! They are Icon Rebounds, 25mm offset
    Fishin RGV-Trd Pro likes this.
  21. Jan 13, 2020 at 4:13 PM
    Fishin RGV-Trd Pro
    Alex
    RGV Texas
    Looks great. Thanks.
    reno_tundra[OP] likes this.
  22. Jan 18, 2020 at 2:38 PM
    reno_tundra
    Decided to lay on the cold cement and get those @RCIoffroad skids installed today!
    salmonfacesalad and drobb like this.
  23. Feb 21, 2020 at 12:25 PM
    ohmyheck
    ohmyheck New Member
    2016 DC SR 5 w/ sweet valve stems
    Driver side handle, Shift knob, sway bar tonneau cover, leveled, 2018 OEM fogs, 275/70 KO 2's and sweet valvestems
    I Love Reno. Raised in Fernley. Nice truck, for a white one!
