F'ing Bushwacker Fender Flares!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Buster1, Feb 16, 2020.
  1. Feb 21, 2020 at 8:59 AM
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    That sucks! I have had people ask me why I don't have them with my wheels that poke. You just answered why. I believe they (can) do more damage in a shorter period of time then the wheels will do in 10 years. Just my opinion. I do commonly like they way they look & I have been pulled over for not having them. :mudding:
  2. Feb 21, 2020 at 9:06 AM
    Stig
    Stig New Member
    That's awesome.
    Might want to rethink towing the Tundra though.
    Tundyfundy likes this.
  3. Feb 21, 2020 at 10:05 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    weird, i have the bushwacker extenda flares (ones without the lame fake bolts) on 3 tundras now and have never had an issue with the gasket coming off or loosening. My 14 tundra had very minimal paint marks when i took them off for trade in, my 16 thought they had worn grooves into the meta on the front- that was mostly based on how the local shop cut them to fit my aftermarket bumper before we noticed the insane noise and destruction they were causing.
  4. Feb 21, 2020 at 10:12 AM
    coTony
    Tony
    Montrose, CO
    Why is that with towing the Tundra? My LandCruiser had a reason not to tow and I am relatively new to the Tundra. Do tell... :boink:
  5. Feb 21, 2020 at 10:50 AM
    Stig
    Stig New Member
    Wheels off the ground
  6. Feb 21, 2020 at 11:22 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    Before we install any flares we clean the the backside of the flare (where the double side tape goes) with alcohol and then use a 3M adhesive promoter wipe.
    https://www.amazon.com/3M-Adhesion-Promoter-Sponge-Applicators/dp/B01G2BHLG6
    We prep the truck by applying X-Pel door edging where the black rubber rides.
    https://www.amazon.com/XPEL-XPF0375U100-Door-Edge-Guard/dp/B00NPMCASA
    It’s pretty straight forward, just have to be patient and clean.
    I have fender flares on my personal truck that I painted and I applied the weather stripping. I promise I could remove the flares and have no damage to my paint and I doubt the weather stripping will be coming loose any time soon. The flare weather stripping is a PIA, that’s where patients comes in.
  7. Feb 21, 2020 at 11:33 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    which width edge guard did you go with>?
  8. Feb 21, 2020 at 11:36 AM
    Omohundro
    Jody
    McMinnville TN
    1/2” works really well.
  9. Feb 21, 2020 at 11:40 AM
    Omohundro
    Jody
    McMinnville TN
    Mine have been on for 6-7 months now. F2FB3407-D7A0-46E2-B219-634CA2C619A2.jpg
    Tundra1078 and mech_engineer09 like this.
  10. Feb 21, 2020 at 11:52 AM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    Yep! That's what I did and they are good so far. You cannot stop dirt from getting between the paint and the rubber strip so you need protection to keep them from rubbing the paint. Especially if you intend to use it off road. Hopefully you can buff it out and restore the paint.
    15whtrd[QUOTED] likes this.
  11. Jun 3, 2020 at 9:53 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Did you ever get the marks buffed out? I’m in the same boat, took mine off and I have marks.
  12. Jun 3, 2020 at 12:28 PM
    Kung
    KG, VA
    Naah. I once told my wife "I love you more than life itself, but sometimes I just need some 'me' time." She thinks the same way. :)
  13. Jun 4, 2020 at 11:54 AM
    Buster1
    Buster1 [OP] New Member
    Oregon
    2019 Cavalry Blue Limited TRD Off Road Double Cab
    Ended up putting them back on to cover the damage. There was no way I could fix it myself. They were on the truck when I bought it and I'd never have them again.
  14. Jun 4, 2020 at 12:54 PM
    canadianguy
    Kevin
    So they rubbed through the clear and through the paint? If it was just scuff marks into the clear it should buff out.
  15. Jun 4, 2020 at 9:47 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I was wondering bro.
    Mountun Goat[QUOTED] likes this.
  16. Jun 4, 2020 at 10:15 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    It’s a bummer. Don’t worry it shall be fixed soon :)
    Tundyfundy[QUOTED] likes this.
  17. Jun 4, 2020 at 10:58 PM
    Tundyfundy
    Bay Area, CA
    To be honest I was like “Dude is a zen master”. To drive a truck and not care if it looks like your using it like a truck must be very freeing. My wife put a tiny scratch in my tailgate and I obsessed over it for months. Lol
  18. Jun 5, 2020 at 6:53 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I have grown to enjoy a beater that’s for sure haha. My two little kids play in, on and around the truck steady and I don’t even flinch when they drop their bikes handle into the door haha. That’s honestly partially why it’s taken me so long to finish the body work. Once it’s done I can’t imagine not having ocd over my
    hard work and nice truck. Also partially why I chose bedliner to finish the body, it’s very easy to touch up and hide.
    Oh and since we’re on the fender flare thread, I will be re installing my flares once everything is bedlined. ;)
  19. Jun 6, 2020 at 6:25 AM
    BUGEATER
    BUGEATER SAPPER SWiG
    Nebraska
    2014 black SR5 limited 4x4
    My flares rubbed all the way to he metal. So I rhinolined where the outline was. I’m very happy with how it turned out!
  20. Jun 6, 2020 at 7:16 AM
    #50
    canadianguy
    Kevin
    Ya think that’s what I’m gonna end up doing too. Mine aren’t as bad, and as soon as they rust trough or I save up enough coin ima get glass fenders, cuz why not?!?!
  21. Jun 6, 2020 at 8:53 AM
    #51
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Anything resting on the paint will rub...no way to avoid it. Flares are a one-way ticket.
    Best idea I’ve seen is the Rhino under where the flare goes on the fender. Of course that only works on a black truck.
    Mountun Goat and Tundyfundy like this.
  22. Jun 6, 2020 at 9:02 AM
    #52
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    great idea
    BUGEATER[QUOTED] likes this.
  23. Jun 7, 2020 at 11:27 AM
    #53
    TundraGuy66
    TundraGuy66 New Member
    Mat
    2020 Cement Tundra TRD
    How long have you had them on your truck? I am wondering how long the protectant tape will last?
    15whtrd[QUOTED] and Tundyfundy like this.
  24. Jun 7, 2020 at 12:23 PM
    #54
    15whtrd
    15whtrd Mr. Blonde
    Personally no fender flares for me, but if I did, that’s what I would do. Typical cars that are wrapped, years ago it was taken off around five years if I recall correctly. But I don’t see why it wouldn’t last longer. Just gets harder to remove the older it is.
  25. Jun 7, 2020 at 1:44 PM
    #55
    Tundyfundy
    Bay Area, CA
    Typical PPF lasts 3-7 years based on care. Since it will be covered from the flare I don’t think sun damage would be an issue.
    Just a hunch but the question may have been referring to how long it will take for the flare to rub through the film.
  26. Jun 7, 2020 at 1:52 PM
    #56
    TundraGuy66
    Mat
    Yeah, curious about if it would rub through. I would think that it would be OK because there is not really any metal contact. I have had some protectant tape on my car for a rooftop rack and it has done pretty well except for where there was metal contact.
