  1. Feb 20, 2020 at 7:18 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well. Got home to find some shit fell and hit the tailgate on the tundra. Yay me. It’s one thing if it was just a scratch. Nope dented in and down to bare metal.
    Guess I’m paying to paint the tailgate again. Shit sucks.
    I’m staying away from
    Home tonight. Kinda pissed between this and someone shattering the window on my rav4 today
    Darkness and lsaami like this.
  2. Feb 20, 2020 at 7:21 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Holy crap, I remember that truck from the TS forums. I think his name was ChaseIntegra. I used to be nutty about that truck.
    Darkness and jImmegart[QUOTED] like this.
  3. Feb 20, 2020 at 8:06 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Well that's a sh*t day. Sorry.
    At least it will be easy for them to match the paint.
    CodyP likes this.
  4. Feb 20, 2020 at 8:10 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    If you go the 'if one's bad replace the whole lot' route, there is a kit to replace all the p/s lines.
    BUT
    There are also two lines on top of the steering rack - they are NOT part of the kit. They CAN be ordered separately from the rack.
    BTDT, told the kit covered all (didn't), told the 2 lines only sold with the rack (wrong). "The more you know".
  5. Feb 20, 2020 at 8:40 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Sucks man, sorry to hear that. Sometimes you just have one of those days. [​IMG]
    I got my chemical guys leather cleaner and conditioner. Seems to have made some difference and it's not crazy slick or shiny. My driver's side seat was already a little dirty from the last month or so of just going to work. Looks like I'm going to need to keep up on this cleaning routine.
  6. Feb 20, 2020 at 9:29 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Some states require the corners to be reflective front and rear
    jImmegart[QUOTED] likes this.
  7. Feb 20, 2020 at 9:43 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I'm not 100% sure but more than likely. You see, the stock radio has a wider faceplate that fills the dash opening without this trim piece. All aftermarket double dins are going to be about the same size faceplate-wise and are a little narrower than the stock unit that's why there are these trim pieces are offered.
  8. Feb 20, 2020 at 9:46 PM
    artsr2002
    'Yonder
    Karma, is that factory leather or aftermarket?
  9. Feb 20, 2020 at 10:35 PM
    artsr2002
    'Yonder
  10. Feb 20, 2020 at 11:00 PM
    empty_lord
    05 rollover special
    Not in your 02. 02 doesn’t need anything
  11. Feb 20, 2020 at 11:30 PM
    empty_lord
    05 rollover special
    Yea. Wonderful day. On well. The beds getting the Bedliner extended further down the side of the bed to protect it from the cap going on
  12. Feb 21, 2020 at 4:58 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Soak some PB blastr Silicone with Teflon spray on those belts and look out because you might lose an eye.
  13. Feb 21, 2020 at 5:41 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    You were going to have the cap painted to match anyway? Always better doing 2 jobs at the body shop at the same time. Better of a worse situation. :-/
    empty_lord[QUOTED] likes this.
  14. Feb 21, 2020 at 7:02 AM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    We got some new tires(295/60R20), and now the lift is level! I had the driver's rear leak air out everyday until I replaced them. I'm guessing the sidewall got weak and bowed out more on that side. I still need to do the front lift(barely clearing front and rear while static), and u joint then she'll be done for a while. I reached out to VLEDs who explained the issue with my front parking lights only working as turn signals. Here is the page about it. https://www.vleds.com/ck/ Getting those fixed soon.
  15. Feb 21, 2020 at 7:37 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Those wheels look awesome on your truck. Love the gunmetal on grey look
    Army_of_One[QUOTED] likes this.
  16. Feb 21, 2020 at 8:22 AM
    KarmaKannon
    Utah
    Some junk
    Katzkin
    artsr2002[QUOTED] likes this.
  17. Feb 21, 2020 at 10:13 AM
    AlbertaBeef
    AlbertaBeef New Member
    Glen
    Airdrie, Alberta, Canada
    2001 Tundra 4x4 Access Cab TRD Off Road
    17" Rims and 265/70R17 tires, 20" Light Bar, Power Stop Brakes, Diff Breather Relocate
    LOL. I might do that once I do my spring detail on the interior. For now, the sanding/cleaning of the shoulder d-ring and a good wipe of the belt has made a tremendous difference.
  18. Feb 21, 2020 at 1:10 PM
    Deslock23
    Deslock23 New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
    New shoes & a bath.
  19. Feb 21, 2020 at 1:18 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Cross member be damned, I got the skids on.... mostly. Should've been sleeping but I was too anxious.
    [​IMG][​IMG]
    [​IMG][​IMG][​IMG]
  20. Feb 21, 2020 at 1:38 PM
    That might be the best black paint I've seen on here. It looks great! You should paint those step bars BLACK!!!!!
  21. Feb 21, 2020 at 1:38 PM
    @because_wumbo-truck what type of drill bit did you use on the frame? I'm curious how that went. Looks great!
    because_wumbo-truck likes this.
  22. Feb 21, 2020 at 1:48 PM
    KarmaKannon
    Utah
    Some junk
  23. Feb 21, 2020 at 2:19 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Ryobi drill bits. Started small and went up sizes about 3 or 4 times
  24. Feb 21, 2020 at 4:04 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Same.
  25. Feb 21, 2020 at 4:11 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Damn I need to paint my side trim and your black paint condition blows mine out the water!
    Deslock23[QUOTED] likes this.
  26. Feb 21, 2020 at 4:18 PM
    Army_of_One
    OEM+
    That's a hot truck!
  27. Feb 21, 2020 at 5:44 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Swapped that coil pack. Truck runs good now. :woot:
  28. Feb 21, 2020 at 5:45 PM
    artsr2002
    'Yonder
    P1442 and P1445 on my 2005 DC. Which bypass have y'all used around here? Are the block off plates required to be installed also? Thanks.
  29. Feb 21, 2020 at 7:21 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    After letting 7oz of Seafoam do its job in the crankcase to hopefully loosen up some sludge for about a hundred miles, I did an oil change today. It came out all dark and burned. :O
    Refilled with 7 quarts of Castrol 5w30 synthetic and an OEM Toyota filter. She's running goodly now, no more burning oil smell emanating from the engine bay. Cleaned out a lot of the grime from the lower engine, my newly-repaired valve cover gaskets must had been leaking for years, it was gross.
    Also made a scrapyard run and picked up a little siren basically for free, which would be cool to wire to a panic switch in case city truck camping ever gets sketchy. Will have to do some research on this one.
    As well grabbed two door checks there from a Sequoia that didn't have a ton of miles. They are exactly the same and held open pretty well on it, so I figure for $7 they are way better than mine (which like to slam on me if I'm parked on an incline more than 1 degree). I think new they are $50?
  30. Feb 21, 2020 at 7:45 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Nice. You had us worried
