VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Feb 19, 2020 at 7:31 AM
    #2761
    NWATundra
    NWATundra New Member
    2013 White Tundra DC
    Are you guys using the p5flash V1.2.2.exe he sent out? He sent it with my last tune in December. I will try to attach a link.
    https://ovtune.zendesk.com/attachments/token/SpX1W0IWodEFqhtS2deDANFgI/?name=p5flash_V1.2.2.exe
  2. Feb 19, 2020 at 7:39 AM
    #2762
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Yes, @OVTune is this something we need to request if we have 4:88 and 37s?? The reason I ask is 4:88 and 37s is really close to stock 32s and 4:30
    UTTundra[QUOTED] likes this.
  3. Feb 19, 2020 at 7:41 AM
    #2763
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Yes if you have different gears you need to let us know so we can update your tune for it.
    you need to use the most up to date version of p5flash, which is 1.3.1, but any version higher than 1.2.1 will work. We send 1.2.2 out with tunes. Redownload it
  4. Feb 19, 2020 at 7:48 AM
    #2764
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thank you for the quick response. I sent an email to zendesk and requested the update for 4.88 gears and 37" tires. As a reminder, I also have the follwoing options on my tune:
    Long Tube Headers
    6000 rpm red line
    91 octane and also a second base tune for 87 octane (just in case Im in the sticks and cant find premium gas)
    Remove throttle limits in 4wd
    Thanks!
    Alex
    Order 5285
  5. Feb 19, 2020 at 8:10 AM
    #2765
    Midway
    Midway New Member
    Is anyone running Two separate tunes 91/87 or 93/91 by switching with Tow/haul?
  6. Feb 19, 2020 at 8:14 AM
    #2766
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm not even sure that is available just yet, unless someone individually is testing it....:monocle:
  7. Feb 19, 2020 at 8:15 AM
    #2767
    Midway
    Midway New Member
    Gotcha. Thanks.
  8. Feb 19, 2020 at 8:22 AM
    #2768
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    yes i am
    Wynnded and Midway[QUOTED] like this.
  9. Feb 19, 2020 at 8:23 AM
    #2769
    spm58
    spm58 New Member
    I'm getting same exact thing
  10. Feb 19, 2020 at 8:23 AM
    #2770
    Midway
    Midway New Member
    Oh...
    Ok, I definitely want this, too. o_O
    papasmurf[QUOTED] likes this.
  11. Feb 19, 2020 at 8:28 AM
    #2771
    NWATundra
    Can you share the link for the p5 1.3.1? I can’t seems to find it anywhere.
  12. Feb 19, 2020 at 8:28 AM
    #2772
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    OH, nice! I thought that maybe this was still more in the planning stages.
    Likewise, when it's available for my ECU....
    Midway[QUOTED] likes this.
  13. Feb 19, 2020 at 8:34 AM
    #2773
    Midway
    Midway New Member
    This would be nice, as I do have 93 available, but 91 is more prevalent when I travel to the West coast. Would be so easy to just hit tow/haul without flashing.
    I'll send Zendesk an email to see if my ECU is supported. Plus, with the Harrop SC, I'll have to see if this is plausible. Would be nice!
    Wynnded[QUOTED] likes this.
  14. Feb 19, 2020 at 8:35 AM
    #2774
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Can't wait to see what that harrop with your crazy engine and this tune can do.
    ViktorG[QUOTED] and Wynnded like this.
  15. Feb 19, 2020 at 8:41 AM
    #2775
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Downloaded the version available on the blog, got 1.2.2 was able to flash. Where is the newer 1.3 version?
    Thanks
  16. Feb 19, 2020 at 9:43 AM
    #2776
    coTony
    Tony
    Montrose, CO
    Really... well doesn't that suck all. GRRRR! Mine does not feel any different than before the flash... at all. I will try to flash again tonight with the same file see if anything changes. It said successful when it completed. Very disappointing. I do not have any of the features either like the instant shifting, gear lock, etc..
  17. Feb 19, 2020 at 9:48 AM
    #2777
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I didn't add those things to your file...…….. I corrected the gear ratio on it.
    Those features are not ready yet on 2018 ECUs. I'm working on it.
    Wynnded likes this.
  18. Feb 19, 2020 at 9:50 AM
    #2778
    coTony
    Tony
    Montrose, CO
    Ok, any idea why the flash told me it was successful but apparently it did not take
  19. Feb 19, 2020 at 9:51 AM
    #2779
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Order 5199
    I have emailed the .CUW file for the most up to date calibration ID (3YWF8900).
    I do not have the .CUW for 3YWF4800 because it is an older calibration and the only way I can install it is a backwards way of installing Bullydog and then uninstalling it.
    I have discovered that when BD is uninstalled, it does not return your truck to the calibration ID that was in it before the install, but the calibration ID that they have on their server.
    I have also attached all the possible calibration ID's for 2007-2013 trucks and what they update to when supercharged.
    I can get you any .CUW file that is in blue, just let me know.
    Cannot wait to get your flash finally so I can run the 65mm pulley and 750cc injectors with a 7000 RPM redline and fast trans shifts :)
    Thanks.
    Viktor
    Calibration list 1.jpg Calibration list 2.jpg Calibration list 3.jpg Calibration list 4.jpg Calibration list 5.jpg
    AZTundra, shellshock and Wynnded like this.
  20. Feb 19, 2020 at 10:27 AM
    #2780
    NWATundra
    That is a bummer, were you experiencing strange shifting? The new tune for me has corrected all of my shifting so far
  21. Feb 19, 2020 at 1:12 PM
    #2781
    e30cabrio
    2 New logs, broken up into under 2mb files sent!
  22. Feb 19, 2020 at 3:37 PM
    #2782
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    How do you know it did not take? did you test any of the issues you previously had to see if they are still there?
  23. Feb 19, 2020 at 5:16 PM
    #2783
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    also, not really related..but
    if you own our flash kit, we will be releasing support for folks to be able to make their own tunes via our software
    expected release for Tundra is April
    Cuban11182, ryanwgregg, mzim and 4 others like this.
  24. Feb 19, 2020 at 5:20 PM
    #2784
    e30cabrio
    I'd be afraid I'd kill my motor. I had a high compression NA 350Z that blew out a piston. Machine shop that built it blamed the tuner. (not sure that was true)
    AZTundra likes this.
  25. Feb 19, 2020 at 7:09 PM
    #2785
    ViktorG
    Viktor
    Calgary, Canada
    Sick!
    Now if I could only get that base tune, I could start adjusting it myself ;)
    Does that .CUW I send help?
    Order 5199
    Wynnded likes this.
  26. Feb 19, 2020 at 9:45 PM
    #2786
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    #4821 Only curious.
  27. Feb 20, 2020 at 3:19 AM
    #2787
    coTony
    Tony
    Montrose, CO
    I have not been in a situation to run any of those type of tests, Air Force One landed yesterday and the traffic was terrible. I have one hairpin turn I go through everyday on the way to work and slowing down for the first turn is always a quick downshift and high RPM's until I get my foot into it going into the curve. It was the same after the new file was flashed so I will flash it again. The main problem was the quick shifting in some gears and rapid down shifting when stopping quickly in traffic. I have an appointment tonight after work but will go out for logging data tomorrow.
    There was not a note in the E-mail on what to log so I will repeat what was done previously.
    Thanks for the updated file Matt, I will get some seat time in this weekend
  28. Feb 20, 2020 at 4:54 AM
    #2788
    osidepunker
    Alex
    2013 Tundra DC 4x4
    wait what :eek::eek::eek:
    I wouldnt want to touch the ignition and AFRs, but does this mean we will be able to adjust shift points, or red line, or the stupid throttle limits in 4wd???
  29. Feb 20, 2020 at 5:00 AM
    #2789
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Another question @OVTune would the self tune version be something that we could take to a dyno tuner and have them work up a truly custom tune???
    Or would it be limited in some fashion?
  30. Feb 20, 2020 at 5:35 AM
    #2790
    e30cabrio
    A) Thanks for the new file!
    B) I said in my response with new logs it felt worse, I guess it needed more "reboots" because it felt awesome this morning!
    Thanks!
    Wynnded and AZTundra like this.
Thread Status:
