Stock setup with 275/70 R18, Any Rubbing? And Suspension upgrade question.
Discussion in '2.5 Gen Tundras (2014-2021)' started by TacomaLC, Feb 6, 2020.
  1. Feb 6, 2020 at 2:57 AM
    TacomaLC
    TacomaLC [OP] New Member
    Chip
    T-town
    2020 Tundra Voodoo 2020 SequoiaTRD 2000 Tundra LTD (RIP)
    Looking at going with 275 70 18 and wondering if I will get any rubbing?
    I don’t plan to tow much or haul much and looking to improve the ride. I have 2020 platinum and love how flat it corners but it doesn’t handle bumps well and the rear gets annoyingly jittery on wash board roads.
    Want a TRD Pro ride for bumps and flat cornering like the platinum. Don’t want to lift it just level it too. Is that even possible?
  2. Feb 6, 2020 at 3:49 AM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I'm running 33x12.50x18 on 18x9 +12mm offset, no lift. I had to remove the front mud flaps. I rubbed at full lock on the bumper plastic, I added 1/2" bumper shim, can't even tell. I have 2020 Trd sport.
  3. Feb 6, 2020 at 9:13 AM
    rrod
    rrod 2005 AC Tundra SR5 4x4
    Rob
    Aluma Series, JBA UCA, Wheelers add a leaf
    I'm running Cooper AT3 All terrains in 275/70/18 tires and was surprised that I rub in reverse with the wheel turned. I thought I would be fine just going up one tire size because I have a 6112/ 5160 Billstein suspension installed. Im sure some has to do with my wheel offset which I believe to be +18. I also have an aftermarket high clearance prerunner bumper but it rubs on the back of the wheel well mud flap. Im going to do the heat gun massage technique and try and save the mud flaps. Its weird how some rub in front and others in the back of the wheel well?
  4. Feb 6, 2020 at 9:22 AM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    I ran 275/70/18's with TRD OR wheels on my sport for a while. Originally installed with stock suspension and there was no rub at all. After installing 6112's @ 1.9" setting to level it, I then got some rubbing on the skid plate. Easy fix - cut small sections out of the skid.
  5. Feb 6, 2020 at 11:16 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Based on my research here ( I will also be getting 275/70-18 when I need tires) there is typically no rub on a stock truck. However, that will depend on the wheels you use. If you use stock TRDOF wheels, should be good. If anything, could rub on those bolted on front flaps- air dams in the front of wheel wheel. Those can easily be removed.
  6. Feb 6, 2020 at 12:53 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    I stock ride height with coopers in this size and I rub in reverse and full lock also however mine are rubbing on the tip of the upper control arm, and this is with spidertrac spacers
  7. Feb 6, 2020 at 12:55 PM
    frichco228
    Frank
    Virginia
    Yep, spacers or aftermarket wheels with non stock offset could rub more
  8. Feb 6, 2020 at 3:05 PM
    kevine0001
    kevine0001 New Member
    Kevin
    hmmm, i'm going to be getting 285/65 on stock rims for my '17 CM OR4x. i would imagine no rubbing since it's only one size up, but reading this makes me think i'll be doing my own BMC
  9. Feb 6, 2020 at 3:24 PM
    frichco228
    Frank
    Virginia
    Those should fit no issue, no BMC needed. They are only a hair taller than stock for the OR package. Also a touch thinner.
    kevine0001[QUOTED] likes this.
  10. Feb 6, 2020 at 4:47 PM
    Berdine
    Frank
    Binghamton, NY
    kevine0001 and Big J like this.
  11. Feb 19, 2020 at 2:37 PM
    19h341
    19h341 New Member
    Scott
    League City
    19 MGM crew
    Tint, scs ray 10s, bfg 275/70/18
    I went from 255/60 r18 to 275/70 r18 +25 offset and I rub the front mudflap
  12. Feb 19, 2020 at 3:03 PM
    19h341
    19h341 New Member
    Scott
    League City
    19 MGM crew
  13. Feb 19, 2020 at 3:06 PM
    AK 6.7PSD Replacement
    AK 6.7PSD Replacement New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    I just did this 3 days ago with Cooper LT275/70R18. All stock, no rub forward, backward, straight or turned. Lotsa room in there...
  14. Feb 19, 2020 at 3:12 PM
    19h341
    19h341 New Member
    Scott
    League City
    19 MGM crew
    Making me regret my scs wheels for $1500 I might powder coat my steel pen and sell the scs ray10s
  15. Feb 19, 2020 at 3:44 PM
    kevine0001
    Kevin
    i think the difference here is stock wheels. going from stock 275/65 to 275/70 should not make that much difference. aftermarket wheels and diff offset will make a difference. i'm going to be running stock rims, but going to 285/65. i don't believe it'll rub, and i've read more than enough guys who have done the same with no rub.
  16. Feb 19, 2020 at 4:38 PM
    2018Tundra
    2018Tundra New Member
    VA
    2021 Tundra Platinum
    I had KO2s in 285/65 on stock rims, no rubbing whatsoever.
  17. Feb 19, 2020 at 4:57 PM
    frichco228
    Frank
    Virginia
    Correct. Will be fine on stock wheels. Wheels with different offset could rub....same with adding wheel spacers to stock wheels
  18. Feb 19, 2020 at 5:01 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Careful, some dislike the LT rated tire ride which 99 percent of this tire size has. P rated stock tires are smoother riding, so changing to LT may exacerbate some of the issues you are already experiencing with ride quality.
    For a level that helps the ride quality most on here recommend Bilstein. I am really liking my Dobinsons. Plenty of front lift/level options out there. Pick a budget and do some research.
    Also note that after a level you may wanna stuff bigger tires in there, ask me how I know.
    For flat cornering look into a TRD rear sway bar.
    panicman and InsaneAuto86 like this.
  19. Feb 19, 2020 at 5:05 PM
    19h341
    19h341 New Member
    Scott
    League City
    19 MGM crew
    Mine rides a lot rougher than my small stock highway tires.
  20. Feb 20, 2020 at 6:42 AM
    My LT tires are at 45psi and there is zero difference from my P tires that were at 40psi. I drive a truck, not a Lexus sedan. I appreciate the strength and capability my particular LT offers over the previous P metric dealer tire (they were some random Bridgestone crap something or another).
    19h341 likes this.
  21. Feb 20, 2020 at 8:20 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Hey AK, any other shots of your truck with those tires? I plan to stay stock suspension for the time being and those look like a great upgrade.
    jerzeedivr likes this.
  22. Feb 20, 2020 at 8:24 AM
    Sure gimmie a sec. getting the youngest out of the hospital after they carved out his tonsils with a melon baller...
  23. Feb 20, 2020 at 8:57 AM
  24. Feb 20, 2020 at 9:05 AM
    Ronsofury and panicman[QUOTED] like this.
  25. Feb 20, 2020 at 10:11 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    20180613_185134.jpg I had 275/70r18 Ridge Grapplers on my stock 17 Limited TRD OR with no rub. Monday I had 6112 installed at 1.9" and 5160 rear on my new 2020 running same size but Trail Grapplers.20200218_154120.jpg
    panicman and 19h341 like this.
  26. Feb 20, 2020 at 1:03 PM
    kevine0001
    Kevin
    I'm not too worried about ride. I'm currently running duratracs on my tundra and had duratracs on my built up land cruiser. i never really noticed anything while driving. probably because my hearing sucks and i turn the radio up...ha ha
  27. Feb 21, 2020 at 8:07 AM
    panicman
    Eric
    Thanks!!
    speedy recovery to your kiddo- that’s no fun!
  28. Feb 21, 2020 at 8:46 AM
    jerzeedivr
    jerzeedivr New Member
    2015 Tundra SR5 TRD CM.
    N-Fab Nerf Bars, Maxliner 3D Floor Mats
    I'm glad you posted! I plan to do the exact same thing. Love the Tires and Wheels!
  29. Feb 21, 2020 at 8:54 AM
    19h341
    19h341 New Member
    Scott
    League City
    19 MGM crew
    Did you try the coachbuilder front bumper shims to move it up 1/2 inch?
  30. Feb 21, 2020 at 8:58 AM
    jerzeedivr
    Thank You! Looks Awesome!!!
