Sway Bar End Links
Discussion in '1st Gen Tundras (2000-2006)' started by Eugene406, Apr 8, 2019.
  1. Apr 8, 2019 at 5:54 AM
    Eugene406
    Eugene406 [OP] New Member
    Montana
    2002 Toyota Tundra SR5 TRD
    Bone Stock.
    Hey All,
    Broke a sway bar end link this weekend installing my 5100's. What end links have you had luck with? Usually, I would run OEM, but I can't seem to find them online.
    Thanks,
    Alltimehigh likes this.
  2. Apr 8, 2019 at 12:52 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Oem, moog, beck arnley.
    00TundraZ likes this.
  3. Apr 8, 2019 at 12:58 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    check ebay. If you can find some with a shock eyelet poly bushing on the bottom, get that. I ran a pair like that from Downey OffRoad for a decade without issue.
    RIP Downey :bowdown:
    Black Wolf likes this.
  4. Apr 8, 2019 at 1:06 PM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    i just did Moog. I will say that their bushings they supplied with them felt like hard plastic, nor polymer or rubber. I used Wheeler's anti sway kit which includes end link bushings.
    I would be money your sway bar bushings could be replaced, might as well do those too while you are there. Just an idea :thumbsup:
    revtune likes this.
  5. Apr 8, 2019 at 1:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    @Roman can hook you up with OEM.
    Or, I might have some lying around here, can't think of where right now.
    15whtrd, joonbug and Roman like this.
  6. Apr 8, 2019 at 4:39 PM
    Eugene406
    Montana
    Bone Stock.
    I trashed both sides, the bushings were shot regardless. I'll just go with a set of Moogs and replace the bushings if they fail.
    Thanks all.
    00TundraZ[QUOTED] likes this.
  7. Apr 8, 2019 at 7:17 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Miss those guys!
  8. Apr 10, 2019 at 3:35 PM
    Tundradrenalin
    Virginia Beach, VA
    I have a pair of OEM from my ‘05. Probably took them off in 07 when I installed the Downey’s. They look great rust free and joint feels nice
    mcharfauros likes this.
  9. Apr 10, 2019 at 3:50 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I bought a set for my 2000 tundra 5 yrs ago from eBay. I had broken 2 sets in the past so I found a set of custom made heavy duty ones for I think $25.00 I don't remember the site but, I haven't had any problems since.The tubing is twice the size as the stock links and welded very well.
  10. Apr 10, 2019 at 4:19 PM
    truckee_mctruckface
    truckee_mctruckface New Member
    Charles
    Seattle
    2005 DC SR5 TRD off road Spectra Blue
    00TundraZ, Hooptytrix and revtune like this.
  11. Apr 10, 2019 at 5:52 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    That’s really cool, thanks for the heads up:thumbsup:
  12. Apr 11, 2019 at 5:43 AM
    Eugene406
    Montana
    Bone Stock.
    How much?
  13. Apr 11, 2019 at 5:54 AM
    Tundradrenalin
    Virginia Beach, VA
    $20 would be ok. Free shipping (because everyone likes free shipping)
  14. Apr 11, 2019 at 6:03 AM
    Eugene406
    Montana
    Bone Stock.
    Deal. Sending DM.
  15. Apr 11, 2019 at 6:12 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    well that sucks. I would have bought those. I mean Moogs are roughly $30 a side, so I was in it for $60. Another $40 for a pair that stout would have been a no brainer for me. Dang! :annoyed:
    Edit: I found those same end links elsewhere for $89.95 just a heads up. Making it an even better deal! Oh well, maybe when my Moogs pop I'll get those.
  16. Apr 19, 2019 at 9:38 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
  17. Jun 30, 2019 at 6:12 PM
    DkpittGen1
    DkpittGen1 New Member
    2006 Tundra DC 2WD
    Bilstein 6112s on front, 5100s on rear, SPC Light Racing UCAs, Suspension Max Sway Bar Arm Link
    I just installed a pair of Suspension Max Links
  18. Jul 23, 2019 at 7:40 AM
    timesinfinity
    timesinfinity New Member
    drew
    northeast
    Curious - how did you tighten down the vertical bolt? Even my thin wrenches can't fit in to grab the bottom nut to keep it from spinning.
  19. Jul 23, 2019 at 7:52 AM
    I had to jam a pair of long nose locking pliers in there and clamp them down as tight as I could. Turn the wheel all the way out to give you more room to work.
  20. Jul 23, 2019 at 7:59 AM
    timesinfinity
    drew
    northeast
    ah thanks for the reply! i tried that but mine were too fat still. maybe i'll try to grind down a pair of old ones. good call.
    i need one of those flat stamped out ikea throw away wrenches ha.
  21. Jul 23, 2019 at 9:48 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I hate the top nut design they give you. The locknut is basically an oval nut that cuts/mutilates the end link threads as you go.
    I toss that crapper and use a nylon locknut then double it by putting another ontop. No problems in the last 20 years.
  22. Jul 24, 2019 at 1:29 AM
    andrew8404
    andrew8404 New Member
    Andrew
    I just got these links too but don’t waste your time using the needle noise pliers. It’s much easier to take the bottom bolt out (next to the gold link) then tighten the top with a 14mm wrench while using another 14mm wrench on the bottom skinny nut. Once that’s tightened down bolt the bottom bolt back in and done.
    timesinfinity[QUOTED] and 2scars like this.
  23. Feb 15, 2020 at 11:25 PM
    TurtleWrench
    TurtleWrench New Member
    Dom
    2013 Sequoia Platinum
    I am lifting my front end about 2" and Suspension max has end links that are longer. How do yours ride after install? more rough?
    Here is the 1 i am thinking of buying
    Extended end links here
  24. Feb 16, 2020 at 5:16 AM
    Yep, those are the ones I used. No complaints here. I don't think they changed the ride at all. I didn't enjoy driving the truck with the sway bar off.
  25. Feb 16, 2020 at 10:29 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I think I'm finally tired of driving a boat. I'm going to start piecing together a set of end links to get my factory sway bar hooked up to my control arms. Let's just say I hope it's not too hard, but I have little faith that it won't suck.
  26. Feb 16, 2020 at 11:26 AM
    @Mstudt makes some as well
    Mstudt likes this.
  27. Feb 16, 2020 at 11:53 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Re-installing my front sway was super nice. Made the truck alive again. When I added a rear sway bar, she really changed even more dramatically for the better. Wooooweeee!
  28. Feb 16, 2020 at 6:01 PM
    TurtleWrench
    Dom
    Did you go with the hellwig rear sway bar? I was looking at the kit on ebay for about 385$
  29. Feb 17, 2020 at 4:57 AM
    Fred
    Hand Protectors
  30. May 28, 2024 at 4:24 AM
    lukedias00
    lukedias00 New Member
    2014 Tundra 4x4 Off-Road Limited
    Hey you still running those MOOG sway bar links? In the same situation, trying to find new ones to run.
    Weagle likes this.
