  1. Feb 15, 2020 at 4:35 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If you have time when finished, would you mind taking a pic after your Center Cluster Panel is back in place. I have had the DMX906S on my short list for awhile but not ready to pull trigger. Might have to take a closer look at your DMX706S since I don't see but 2 differences at Crutchfield....HD Radio and USB inputs, also your model is $200 cheaper at Crutchfield....decisions, decisions !
  2. Feb 15, 2020 at 5:01 AM
    Professional Hand Model
    Fred
    Hand Protectors
    What led you to purchase these particular speakers (the Hertz brand)?
  3. Feb 15, 2020 at 5:12 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    They’re a higher end speaker brand. This they’re entry series, I’d say they’re on the higher end of “budget” speakers. The parent company to hertz is audison. I’ve ran audisons before and they’re amazing
  4. Feb 15, 2020 at 5:16 AM
    Fred
    Hand Protectors
    The center cone of the speaker looks different than some of the other new speakers I’ve seen. Most have the same look as the originals with the little build out. How much are these and would they work on my original stereo (2002)?
    KarmaKannon likes this.
  5. Feb 15, 2020 at 8:08 AM
    Tohopko
    Tohopko New Member
    2004DC
    I must be dense...or not enough coffee yet. I'm not seeing where this connector is?
  6. Feb 15, 2020 at 8:12 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Even tho mine is strictly the tray but same size, easy peasy trim tool should work
  7. Feb 15, 2020 at 8:40 AM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    yeah it just pops out easily. Installed an unltragauge there in my last tundra and it fit nicely.
  8. Feb 15, 2020 at 9:07 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Will do. Also another plus for the 706s is the chassis depth is half as deep compared to the 906s which means easier install with the rats nest of wires in the back.
    NUDRAT and BubbaW[QUOTED] like this.
  9. Feb 15, 2020 at 10:02 AM
    empty_lord
    05 rollover special
    They sound good with my 19 radio. They likely would sound good with yours as well. But they also may not get enough power from the 02 radio
  10. Feb 15, 2020 at 10:39 AM
    Fred
    Hand Protectors
    Took her out on a nice long test drive today on multiple types of roads including some sand driving.
    Still getting used to the new bushings, but I’d say overall they are smoother than the old bushings. The old bushings were more road sensitive and had a quicker/direct response feel. These are smoother and turn fast but with less jerk/jive.
    I think I liked the older bushings better for their sportiness. These new ones may be better for off road and city combo driving. Jury is still out and I’ll live with them for a while. May change back to stiffer ones, but so much work!
    NUDRAT, mcharfauros and Tohopko like this.
  11. Feb 15, 2020 at 12:44 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I just cut one on my dash.
  12. Feb 15, 2020 at 1:09 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    I believe it is behind the glove box.
    Tohopko[QUOTED] likes this.
  13. Feb 15, 2020 at 1:55 PM
    You're the 2nd person I've seen with the passenger airbag off. Is this because of children?
  14. Feb 15, 2020 at 2:04 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Yes sir.
    mcharfauros and jImmegart like this.
  15. Feb 15, 2020 at 4:32 PM
    artsr2002
    'Yonder
    Update: I got my headunit wired up with backup camera and amps. I used the mounting ears off the factory headunit since they are a nice metal instead of cheap plastic like most dash install kits but because the factory unit has a wider faceplate, I have a 1/2 inch wide gap on the sides of the Kenwood double din. No biggie I'll order a faceplate dash install kit to cover the holes.
    I had already installed a mini amp behind the single Din kenwood that I had before which powers my door speakers.
    I repurposed my brothers NVX MPVA1 mini amp and used it for powering up a 12 Rockford fosgate 12 in a wedge truck box that will just sit behind the passenger seat. I hardly have anyone in the backseat anyway.
    I mounted my backup camera right above the license plate. The Cam is powered off the headunit switched 12volt so I can use it at anytime. I connected the headunit reverse trigger to the reverse circuit at the bottom left kick panel where I found the Red/Black with silver spots reverse wire. Camera switches successfully when I put the truck in reverse. The image quality is OK but the viewing angle isn't very wide. I'm not able to see the trailer hitch but I hardly ever tow anyway so it should be fine.
    I'll be ordering a dash install kit to hide the holes on the sides of the headunit and the USB port button replacement to install my USB port in the front cubby of the console and then I can call it a day.
  16. Feb 15, 2020 at 4:50 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I started stripping the headlight chrome on my lunch break yesterday. The projector bezels were easy, the headlight reflectors weren't too bad, and one of the trim parts inside the headlight wouldn't strip at all. If it survived oven cleaner for an hour then I think it's safe to paint.
    I have a cool idea for the projector that I should be showing in about a week. Should add an extra bit of pizaz and character. Too much garage work right now to get much else done.
  17. Feb 15, 2020 at 5:25 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    Any tips on routing the video cable? Are there any grommets in the floor or door sills I can use? I didn't get a chance to look for myself today as I waited for FedEx and got started on the temp install before I fell asleep.
    There's a grommet under the drivers seat
  18. Feb 15, 2020 at 5:46 PM
    artsr2002
    'Yonder
    There was a nice big grommet between the outer front and rear driver seat bolts where there is already a big bundle of wires running beneath the truck. Worked out great.
    NUDRAT likes this.
  19. Feb 15, 2020 at 5:57 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    You need the Metra 95-8202
  20. Feb 15, 2020 at 6:03 PM
    artsr2002
    'Yonder
    Yep. Ordered. Thanks.
    mcharfauros likes this.
  21. Feb 15, 2020 at 6:06 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Thanks to Fred for the motivation and the know how I got my wheels repainted today. Took all day prepping and waiting between coats and I think they turned out pretty well, definitely much better than before.
  22. Feb 15, 2020 at 6:08 PM
    Filthyphil
    Phil
    Also what do you guys think, keep the canopy on, or keep it off? I’m kinda partial to it off now that I found out how heavy the bastard is.
  23. Feb 15, 2020 at 6:11 PM
    artsr2002
    'Yonder
  24. Feb 15, 2020 at 6:28 PM
    If you don't actually use it for anything might as well leave it off. I think mine only weighs around 150lbs though.
  25. Feb 15, 2020 at 6:31 PM
    Tohopko
    Tohopko New Member
    2004DC
    I like mine simply for the utility of having the bed covered when I need it.
  26. Feb 15, 2020 at 6:34 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Off. And sell it to me since you won't want it anymore...:thumbsup:
  27. Feb 15, 2020 at 6:45 PM
    empty_lord
    05 rollover special
    I plan on keeping mine on. I can remove it easily enough with a lift on the ceiling once I get a roof rack on it.
    oscardog86, NUDRAT, Tundra2 and 2 others like this.
  28. Feb 15, 2020 at 6:51 PM
    Tohopko
    Tohopko New Member
    2004DC
    Not much accomplished today. Mostly bedding a rifle, putting ads out on Armslist and prepping optics for sale. Did find time to install the Gentex GNK20 mirror. Not sure there is a much easier install if you already have a power mirror--uses the same connector, just gets two wires added for the temp probe. Titan, one of the nine, decided he needed to supervise.
  29. Feb 15, 2020 at 7:02 PM
    KarmaKannon
    Utah
    Some junk
    Bedding a rifle and installing a mirror? Sounds like a good Saturday to me!
  30. Feb 15, 2020 at 7:15 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I didn't know some models came with power mirror. Hell my 06 limited didn't haha I'd love one of those.
    Cute pooch.
