Lexus LX/ $runner brake upgrade for our Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by evilrb, Feb 13, 2020.
  1. Feb 13, 2020 at 3:35 PM
    evilrb
    evilrb [OP] New Member
    Jeremy
    Sorry if I missed the info, I tried searching and can't seem to find it...
    I read a post about the newer Lexus GX460 / 4runner brake upgrade for our trucks.
    You have to shave down the caliper brackets to center them but everything bolts right up.
    I have a 13wl upgrade but I want to try it out.
    Does anyone have the info?
    I basically just looking to confirm how much of the bracket you need to shave off to get a quote from the machine shop before I buy everything.
    Also, I want to confirm the casting number, 14 something...
    Thanks guys!
    Nevermind right after I post this I find it... :rofl:
    Thread here: The 14WA rotors are 1” larger in diameter compared to the 13WL rotors
  2. Feb 13, 2020 at 3:59 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    mcharfauros and evilrb[OP] like this.
  3. Feb 13, 2020 at 4:06 PM
    evilrb
    Jeremy
    BubbaW[QUOTED] likes this.
  4. Feb 13, 2020 at 4:34 PM
    Professional Hand Model
    Fred
    Hand Protectors
    If you go for it, then how about writing up an exposé. Looks like a lot of work and $$$. That machine work grinding the ears looks like its about 3mm (from reading) and needs to be spot on. I wonder if that weakens the casting?
  5. Feb 13, 2020 at 4:47 PM
    evilrb
    Jeremy
    speedtre and Darkness like this.
  6. Feb 13, 2020 at 5:01 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Likely a little weaker. But I don’t believe there’s enough taken off to cause alarm
  7. Feb 14, 2020 at 4:39 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
  8. Feb 14, 2020 at 5:38 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
  9. Feb 14, 2020 at 5:41 AM
    Fred
    Hand Protectors
    Good eye. The pic says not actual part. I saw that yesterday, too.
