What suspension changes for towing?
Discussion in 'Towing & Hauling' started by grandcru, Dec 17, 2019.
  1. Feb 6, 2020 at 5:55 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    As other have already said, it's fine and leave it alone.
  2. Feb 6, 2020 at 6:01 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    I'm sure you are right. I am probably over thinking it. The truck drives like a dream pulling the boat as is.
  3. Feb 6, 2020 at 7:04 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I have a 20' fishing boat with a similar weight. Never even considered adding any suspension aids.
  4. Feb 6, 2020 at 7:24 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    My 18' Ranger is nowhere near the weight of the OP's boat but @Coachbuilder1 advised me that if you get any squat in the rear then the TSS system and traction control can get squirrelly.
  5. Feb 6, 2020 at 7:29 AM
    harrydunn
    harrydunn New Member
    Columbia, MO
    Because I was inverted.
    Call it, Friendo.
    Air bags. I had sumo springs but swapped them out for the custom control that air bags provide.
    NewTundraGuy2020 likes this.
  6. Feb 6, 2020 at 8:16 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you still have the Sumosprings I would buy them from you. I need them for my TT.
  7. Feb 6, 2020 at 8:19 AM
    Bad Cow
    Georgia USA
    As you can see by the photo, I might get an inch of squat. There is NO traction control or TSS system issues whatsoever. I think I'm going to put this behind me and just enjoy my truck as it is. Thanks.
  8. Feb 6, 2020 at 8:59 AM
    NewTundraGuy2020
    NewTundraGuy2020 New Member
    Aaron
    VA
    2020 Tundra 4x4 Crewmax Limited TRD
    In progress...
    If you want, put air bags on it. They’re not that expensive, especially if you do NOT do the onboard compressor, etc. I had them for 2 boats of mine (24’ single diesel express sport fisher and a Malibu inboard ski boat). I was very happy with the Firestone bags. I routed the air fils to the bottom of my rear license plate holes. Super convenient and looked trick.
    Anyway, my 2 cents if you go that route.
    It was totally worth it for me.
    Bad Cow[QUOTED] likes this.
  9. Feb 6, 2020 at 10:33 AM
    Bad Cow
    Georgia USA
    Thanks for the input buddy. I will sleep on it for a while. Might just leave it alone for a while. But I do like the adjustability of the air bags.
  10. Feb 7, 2020 at 12:43 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I am still evaluating the Roadmaster Active Suspension. I think your rig looks very level and I would go with it but, if you have concerns, I think you ought to look at that product....it does provide some lift when not loaded and provides some relief from squatting when loaded up. Not expensive and relatively easy to install. It's not as aggressive as a WDH but that is not what you are looking for...
    ATHiker and Bad Cow[QUOTED] like this.
  11. Feb 11, 2020 at 5:45 AM
    harrydunn
    Columbia, MO
    Call it, Friendo.
    Sorry, returned them for refund.
    Ruggybuggy[QUOTED] likes this.
