Fox 2.0
Discussion in 'Suspension' started by Kolotous_701, Mar 31, 2019.
  1. Mar 31, 2019 at 10:09 PM
    Kolotous_701
    Kolotous_701 [OP] New Member
    Lift my 2015 tundra over the weekend with fox 2.0. Tires 285/65/18 good year ultra terrain. Didn’t really feel the lift to be noticeable. I was told it was about 3.5” with tires. Does the picture justify 3.5”? I wanted to be about 4”, what I can do? Any suggestions would help
    georgiey22 likes this.
  2. Mar 31, 2019 at 10:11 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Crank them up
  3. Mar 31, 2019 at 10:14 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Think 2.0 will only get you 2-2.5 inches of lift....looks nice and level to me..
    Want more up front add a shim or two.
    You will have to do something to lift the rear end if you do to level it out.
    TacomaLC likes this.
  4. Mar 31, 2019 at 10:38 PM
    Kolotous_701
    @xtyfighterx what do you mean add a shim or two? What can I do to the rear? What parts?
  5. Mar 31, 2019 at 10:58 PM
    Cmilla25
    Cmilla25 New Member
    2015 Tundra Trdpro
    Look into the @coachbuilder set up. Shakles in the rear and shims in the front
  6. Apr 1, 2019 at 1:02 AM
    xtyfighterx
    Ty
    North Idaho
    Coachbuilder makes shims the which are a 1/4 thick you add to the top of your coilovers...rear you can add a shackle,block, add a leaf, leaf pack etc take your pic how much do you want to spend?
  7. Apr 2, 2019 at 1:30 PM
    Kolotous_701
    @xtyfighterx what parts would I need for a 4inch lift? I was told I can leave the front suspension the way it is.
  8. Apr 2, 2019 at 4:23 PM
    xtyfighterx
    Ty
    North Idaho
    4wd or 2wd?
  9. Apr 2, 2019 at 5:18 PM
    Kolotous_701
  10. Apr 2, 2019 at 5:19 PM
    xtyfighterx
    Ty
    North Idaho
    You need new spindles then
  11. Apr 2, 2019 at 5:30 PM
    Kolotous_701
    @xtyfighterx that’s all I need? How about upper control arms?
  12. Apr 2, 2019 at 5:36 PM
    xtyfighterx
    Ty
    North Idaho
    Nope only 4wd needs those changed out. Ya you can spindle lift your truck since it’s 2wd it’s way easier an cheaper to do then on a 4wd
  13. Feb 9, 2020 at 9:01 PM
    Tmoz78
    Tmoz78 New Member
    2010 Tundra Crewmax
    CAI, Gibson Exhaust, air bags, sway bar, brake controller
    Was looking to get those same shocks installed soon. Would love to hear an update on first impressions.
  14. Feb 9, 2020 at 9:10 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Buy once, cry once. IMO a 2.0 is too small. If your going small shock route, just do 5100s.
    Otherwise, get a larger shock body like the 6112 or any 2.5 bodied coilover. It's a big heavy truck.
    jordan0317, Hbjeff and Tmoz78[QUOTED] like this.
  15. Feb 9, 2020 at 9:56 PM
    Tmoz78
    Tmoz78 New Member
    2010 Tundra Crewmax
    I agree on the weight. I don't do much offroading per say. Truck is on paved roads 99% of the time other than the handfull of camping trips we do. Thanks for the suggestion.
  16. Feb 10, 2020 at 12:55 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I had some on my truck, they rode to rough for my taste so I'm taking them off. Ill have the whole set forsale on here shortly.
