Mountun Goat’s Anatomy Thread
Discussion in '2nd Gen Builds (2007-2013)' started by Mountun Goat, May 6, 2018.
  1. Feb 7, 2020 at 7:33 PM
    #151
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    OPERATION BLACKOUT.
    I clean the parts with spray nine and scrub with a proper fashioned 45 degree toothbrush head. Then rinse with water. Pretty good outcome I’d say ok a 12 year old truck with 480k
    I make sure I sand the entire surface evenly with 120 grit.
    Then spray thin layers of Napa flat black spray paint until coated.
    Plastic painting strategies include skipping the primer step. With past experience spray painting plastics, priming doesn’t seem to work too well. I think I’ll give this a shot and see how it goes.
  2. Feb 7, 2020 at 11:41 PM
    #152
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Well that was a bit of work, but well worth it. I dash mounted my cb radio and brake controller while the dash was apart.
    don3032, D4x4TRD, Vizsla and 3 others like this.
  3. Feb 7, 2020 at 11:57 PM
    #153
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Your shift knob is the “thats what she said” model
  4. Feb 8, 2020 at 12:31 AM
    #154
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha sounds about right
  5. Feb 8, 2020 at 6:44 PM
    #155
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    For spots I don’t want painted, I use 3m masking tape with plastic backing.
  6. Feb 9, 2020 at 9:20 AM
    #156
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Got the dash back together today. Doors next.
  7. Feb 9, 2020 at 9:32 AM
    #157
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Nice!
  8. Feb 9, 2020 at 9:48 AM
    #158
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks my dude!
    Y0TA PR0[QUOTED] likes this.
  9. Feb 9, 2020 at 10:10 AM
    #159
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    You have power folding side mirrors! That’s sick!
  10. Feb 9, 2020 at 10:30 AM
    #160
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Actually it came factory with power folding. I cheated out on my tow mirrors and didn’t ordered power folding. I probably will upgrade at some point when the rest of the things I need to do are finished. They are all scratched to hell now anyway with all the beatings haha
  11. Feb 9, 2020 at 10:34 AM
    #161
    TheBeast
    TheBeast The Beach
    nothing like a good shop project !
    looks great ! :thumbsup:
    Mountun Goat[OP] and Y0TA PR0 like this.
  12. Feb 9, 2020 at 10:45 AM
    #162
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Paint your towing mirrors! :popcorn:
  13. Feb 9, 2020 at 10:59 AM
    #163
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks, you bet. Having fun out there :)
  14. Feb 9, 2020 at 10:59 AM
    #164
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I do plan on it :) haha
  15. Feb 11, 2020 at 7:27 PM
    #165
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Got the top of the door blacked out. The ‘flat black’ vinyl spray turned out quite shiny. But that’s fine, as my arm sits there so it won’t be flat anyway haha. I am wondering if I should paint the bottom grey pieces matte black to match the rest, or paint quicksand to match the bedliner that’s going on the truck body... Thoughts?
    D4x4TRD, Vizsla and Y0TA PR0 like this.
  16. Feb 14, 2020 at 7:32 AM
    #166
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thought I’d post the masking process of the door panel’s.
    This scotch blue plastic backed tape is the greatest masking secret of all!
  17. Feb 15, 2020 at 11:17 AM
    #167
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Today I found these left over pieces of plastic (from the mud flaps I made) and cut them into a center console divider.
    After realizing the little tray would fit into the divider, I modified to make it fit.
    So stoked on this free, 15 minute upgrade!
  18. Feb 15, 2020 at 11:24 AM
    #168
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Haha nice! Tim Hortons change :thumbsup:
  19. Mar 1, 2020 at 7:23 AM
    #169
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I bought a 48” under tailgate led light strip as it fits the window width. Then I cut the rubber housing off the strip to make it fit into the window seam.
    I cut all the extra buytal out of the window seam to make room for the light strips and silicone.
    Taping the glass and body off helped keep a clean line.
    I laid the window seam half full of silicone, then set the light strip in. Once it was set, I filled the remainder of the seam with more silicone. To ensure perfect silicone placement I used a spray bottle of dish soap water for shaping lube. Just spray the soap onto the silicone and the finger of choice, then glide your finger as needed.
    Lastly, I wired the light into the existing circuit. This light is 5 function so has running(70%), brake, signal’s and reverse.
    I’m pretty happy with the outcome and will need to get some pictures once the truck is outside again.
    https://www.tundras.com/threads/double-cab-integrated-3rd-brake-light-install.63056/
    cowboyjack, don3032, 15whtrd and 5 others like this.
  20. Mar 1, 2020 at 8:39 AM
    #170
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    That’s sweet!! Looks good!
  21. Mar 1, 2020 at 8:40 AM
    #171
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks I’m pretty excited with how it came out :)
  22. Mar 1, 2020 at 2:22 PM
    #172
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Pretty sure I figured out the simplest way to mount ditch lights to any Tundra/Sequoia hood. Just had to remove the end of the cowl rubber trim pieces.
    Just bent some steel in the vice and drilled holes to fit the hood to hinge mounting bolts.
    :spy:
    gipsyfetus, Rengawt, 15whtrd and 3 others like this.
  23. Mar 1, 2020 at 2:38 PM
    #173
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Nice! I want to do this!
    how you like that short antenna? Does it work good?
  24. Mar 1, 2020 at 2:40 PM
    #174
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks. The antenna is brutal haha. Like 10% reception haha.
  25. Mar 1, 2020 at 2:47 PM
    #175
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Lol!
  26. Mar 1, 2020 at 2:47 PM
    #176
    Nice, what was the overall length of the metal straps you used?
  27. Mar 1, 2020 at 2:49 PM
    #177
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’ll have to make some measurements for everyone and make a build thread.
  28. Mar 1, 2020 at 2:52 PM
    #178
    I've got some metal straps that I bought at my ACE that I'll put to good use it seems!
  29. Mar 1, 2020 at 3:15 PM
    #179
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    You bet, that’s handy! I’ll get over there to measure soon
  30. Mar 7, 2020 at 6:30 PM
    #180
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Installed an automatic nanny bypass harness from @MikeBeach
    I’m stoked on this mod, as I used to press the trac button everytime I started my truck.
    BestGen, Hbjeff, ChargedToyo and 2 others like this.
