Thinking of a Tundra Limited
Discussion in '2nd Gen Tundras (2007-2013)' started by lexusrocks, Feb 8, 2020.
  1. Feb 8, 2020 at 8:51 AM
    lexusrocks
    lexusrocks [OP] New Member
    Found one, 2008, around 100K, a limited Crewmax with all the toys. Asking 18.9K very nice truck drives great. Has a good service history, and the secondary pump was replaced.
    Only thing that scares me is this in the service history:
    2
    11/19/2019
    CUSTOMER STATES FRAME HAS A LOT OF RUST PLEASE CHECK HHAS WARRANTY EXT
    CUSTOMER STATES FRAME HAS A LOT OF RUST PLEASE CHECK HHAS WARRANTY EXT ~|~CUSTOMER STATES FRAME HAS A LOT OF RUST PLEASE CHECK HHAS WARRANTY EXT ~|~ ~|~109194 CK OVER NO RUST PERFORATION FOUND
    Another record says they applied fluid film a few years ago...Haha..that must be long gone. I use that stuff too and it barely lasts a season.
    Being in upstate NY, I've seen vehicles turn into dust. I don't believe that opinion above will be true a year down the line, no matter what they apply to it.
    I can't find any other limiteds here, I may still go for it.
    I've found that these trucks share a trans with my Lexus GS. The GS has an all time AWD planetary TC.
  2. Feb 8, 2020 at 11:25 AM
    Do you have pix?
  3. Feb 8, 2020 at 12:04 PM
    lexusrocks
    The rust? No. but there is an ad for it.
  4. Feb 8, 2020 at 12:15 PM
    Of the vehicle
    Was original owner thinking factory rust? If it’s in NY, it’s probably true rust.
  5. Feb 8, 2020 at 12:22 PM
    lexusrocks
    If I take another look I'll take pics. I guess though if Toyota said its ok...maybe it is ok?
  6. Feb 8, 2020 at 12:34 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Someone is selling rust?
  7. Feb 8, 2020 at 12:35 PM
    e30cabrio
    No. Many have had the undercoating done, it was not ok & Toyota said we offered frame replacement, you took undercoating, you are on your own.
    I'd look elsewhere unless the truck is free.
  8. Feb 8, 2020 at 12:49 PM
    lexusrocks
    I found this in the service history:
    2
    12/5/2017
    2007-2008 TUNDRA - CLEAN FRAME, APPLY CRC, INSTALL PLUGS
    2007-2008 TUNDRA - CLEAN FRAME, APPLY CRC, INSTALL PLUGS ~|~HOF ~|~. ~|~0 COMPLETE FRAME UNDER COATING AS PER TOYOTA INSTRUCTIONS
    0" style="border: 0px; font-style: inherit; font-variant: inherit; font-weight: inherit; font-stretch: inherit; font-size: inherit; line-height: inherit; vertical-align: baseline;">
    Parts
    Name
    Part #
    Qty
    PLUG, HOLE KIT
    0400718234
    PLUG, HOLE KIT
    0400723234
    T00-CORROS RES KIT
    00289T00KTDS
    Warranty Pay
  9. Feb 8, 2020 at 1:27 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Is there a bed liner? If so lift it up and look for rust on the bed (particularly where the bed mounts to the frame) it’ll be obvious. I have the same truck and had the frame recall cover a new frame. My bed rotted out and I replaced that on my own. I’d say if it hasn’t been replaced and there’s obviously been concern over it, I’d pass
