Harbor freight pressure washer?
Discussion in 'Detailing' started by dspilot, Feb 8, 2020.
  1. Feb 8, 2020 at 7:56 AM
    dspilot
    dspilot [OP] Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    Anybody using one of these? I need a PW...will be mostly used for car cleaning, but I just can't justify dropping major coin on one right now.......79 bucks aint bad.....
  2. Feb 8, 2020 at 8:00 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    In my experience, harbor freight is good for quick, temporary, inexpensive fixes.
    Something like a pressure washer I can't imagine lasting very long, but that's why it's $79 bucks.
    Anything I have purchased from there was to use on a job and then discard after use.
    Harbor "single use only" freight.
  3. Feb 8, 2020 at 8:12 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I wouldn't do it. I've been really happy with my Sun Joe. There are some "used" ones for around $105, but $205 is a really good price for this model.
    ChickenBender and dspilot[OP] like this.
  4. Feb 8, 2020 at 8:20 AM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
    If you are looking to use a foam cannon with a pressure washer, you are going to want at least 2.0 GPM and close to it. If you can get close to 2.0 GPM and change out the orifice to give you better results
    Skew12, Rica25 and dspilot[OP] like this.
  5. Feb 8, 2020 at 8:28 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Had too many electric pressure washers burn up. Gas only for me.
    and I disagree about harbor freight being a throw away tool store. Used to be of that mentality but some of their products are quite stout. Impact sockets, for example, are a really solid buy.
    Navi, Stroke250, Black Wolf and 4 others like this.
  6. Feb 8, 2020 at 8:29 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    I have one for dirtbike post ride cleanup. So far it's been fine for that, not a lot of pressure. I've also used it to clean up greasy 70 year old tractors.
    I got the extended warranty on it because I know it won't last. Most electric washers are short term.
  7. Feb 8, 2020 at 8:41 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I have a sunjoe from homedepot got it for less then 90 bucks and works good
    Black Wolf, Rica25 and dspilot[OP] like this.
  8. Feb 8, 2020 at 8:52 AM
    Check out @War Machine and his vehicle detailing threads.
  9. Feb 9, 2020 at 10:20 AM
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    I got this one for $116. It was on sale at that price, has a functional hose reel (not just a storage reel) and powers the foam cannon well. 2000 psi, 1.4 gpm.
    If you’re not in a hurry, keep an eye out for a sale to jump on.
    AR ANNOVI REVERBERI AR390SS... https://www.amazon.com/dp/B00N6XBM64?ref=ppx_pop_mob_ap_share
  10. Feb 9, 2020 at 11:13 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    I bought on a few months ago. Used it to wash the car and truck a couple times, haven't had any issues. Not sure how long it'll last, but I've been hunting for a Honda powered gas PW the last few months to rebuild anyway. The HF one doesn't have a quick fitting for an aftermarket foam cannon, and the little one that comes with it doesn't hold much. But I don't really have any complaints.
  11. Feb 9, 2020 at 1:07 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’m using the harbor freight one no issues plenty of pressure works great over a year now use it in the house siding the side walk the truck you name it. Think I got mine on sale for $65 .
  12. Feb 11, 2020 at 6:20 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    If you go with the Harbor Freight unit, be sure to go to their website and sign up for coupons. That'll get you an extra 20% off of the price.
  13. Feb 11, 2020 at 6:50 AM
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    I had a electric pressure washer and was more like a glorified hose. your better to save and by a gasoline power washer it will last along time and you will be able to clean anything.
    Black Wolf likes this.
  14. Feb 14, 2020 at 10:16 PM
    Hhtundra
    Hhtundra New Member
    Check out the sunjoe pressure washers, they are pretty good for the price, no electric washer will match the power of a gas powered one, but if you check the psi that is on the higher end you should be fine
  15. Feb 15, 2020 at 5:20 AM
    Adam New Member
  16. Feb 15, 2020 at 5:34 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have this little electric Ryobi from Home Depot. It was under $100 and works great for car washing, foam cannon and even cleaning the driveway. I have a gas pressure washer also but find myself using this one most of the time because it is so easy to move around and plenty of pressure for most jobs.
    Blueline and Rica25 like this.
  17. Feb 15, 2020 at 6:43 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I got an HB many years ago, was on sale for $25, guess what that was 15 yrs ago and it still works, well the protection circuit (box w/ on-off switch) so I just cut it out and added another cord, woohoo!
    It's rather strong, will knock off grime and mold growth on a metal travel trailer in 30 mins (32'). Luck all....
    MS22 likes this.
  18. Feb 15, 2020 at 6:54 AM
    20% off good until 04/16/2020
    Free light good until 06/30/2020
    Rica25 likes this.
  19. Feb 17, 2020 at 8:00 AM
    CO_Native
    CO_Native New Member
    Englewood, CO
    2024 Limited CM Silver/Nightshade
    Had mine 3 years now, still works like a charm. For the price I didn't expect more than 1 year out of it, but I'm pleasantly surprised.
    I use it on my House, my Harley, Travel Trailer, and Trucks. The soap dispenser is a nice feature too, just rinse after use so it doesn't get gummed up.
    Rica25 likes this.
  20. Mar 1, 2020 at 7:04 PM
    ChickenBender
    ChickenBender New Member
    I have the SUNJOE. Been solid for 3 years
    Rica25 likes this.
  21. Mar 2, 2020 at 11:21 AM
    briarpatch
    briarpatch New Member
    Rica25 likes this.
  22. Mar 2, 2020 at 11:27 AM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    Nice! I was thinking of getting that one! There is another Ryobi model that puts out 1900 psi for $150 Ill probably go that route.
    Rica25 and Boerseun[QUOTED] like this.
  23. Mar 2, 2020 at 11:29 AM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    Rica25 and Boerseun like this.
  24. Mar 2, 2020 at 11:39 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Those SunJoes frequently go on sale for around $120ish (give or take). I'd shell out the extra $40 for one of those before spending $80 on a Harbor Freight pressure washer. Nothing against HF (I've gone there for plenty!), but you get what you pay for.
    Rica25 likes this.
  25. Mar 2, 2020 at 7:12 PM
    dspilot
    North Mississippi
    I ended up catching this on an open box clearance at Lowe’s. It was brand new and I only paid 100 bucks for it.
  26. Mar 2, 2020 at 8:22 PM
    Score:thumbsup:
    Rica25 and dspilot[QUOTED][OP] like this.
  27. Mar 2, 2020 at 8:41 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Literally everything electronic I have bought from Harbor Freight has either failed to turn on or caught on fire within a few uses; and I think you can get lung cancer from breathing in the store.
    Rica25 likes this.
  28. Mar 2, 2020 at 8:45 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Don't threaten me with a good time.
  29. Mar 3, 2020 at 4:54 AM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
    Good deal!
    Rica25 likes this.
  30. Mar 3, 2020 at 5:03 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    I always wanted a gas PW for years because I got spoiled with a commercial one at an old job. It was never in the budget, but I always had uses for a pressure washer, so I got a free one from a neighbour. It was a cheap karcher and the wand leaked. I replaced the wand with a proper one and used the machine happily till the winter when I left it outside and it froze and blew up. I subsequently got a Simoniz 1900 PSI and another Karcher 1500 psi one for free because the wands leaked. I ended up giving away the other karcher and Ive had the simoniz for 3 years (I keep it indoors for winter now). I've spend maybe 50 bucks on a decent wand and I bet I can get free electric units whenever this one decides to quit. Gas is better performing, hands down, but for washing wooden decks and washing boats and cars and bikes and atvs and cleaning my house etc. the electric is pretty handy and smaller to move around, and it does the job well enough that I'm no longer looking for a gas one (even though I can afford one now). This summer I am plumbing a warm water line to the side of the house for washing my toys and truck
    Rica25, Boerseun and dspilot[OP] like this.
