Tundra Antenna Bezel Ornament 2014-2019 Replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra14Platinum, Oct 5, 2019.
  1. Oct 5, 2019 at 8:35 AM
    Tundra14Platinum
    Tundra14Platinum [OP] I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    I'm looking for an OEM replacement. I can find the gen 2 but having trouble finding gen 3. The gen 2 are innie and the gen 3 is an outie. Does any one know where to find one other then the stealership? Thanks
  2. Oct 5, 2019 at 9:10 AM
    PM @Roman , he can help you out.
    NewImprovedRon and Roman like this.
  3. Oct 7, 2019 at 8:54 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  4. Feb 1, 2020 at 12:11 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    How difficult is it to replace?
  5. Feb 1, 2020 at 5:50 PM
    Noojen
    Noojen New Member
    DFW
    2016 MGM Limited CM 4x4
    It’s not...use pliers and a knife to remove the old one. Then, use some window cleaner to help the new one slide on. Just make sure the edge of the fender slips in the channel on the ornament on all sides. Took me less than 10 minutes to remove and install just a couple weeks ago on my ‘16 CM.
    tightywhitey[QUOTED] likes this.
  6. Feb 1, 2020 at 10:29 PM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I need one of these too. Mine is extremely cracked in multiple spots. Glad to hear it's easy to swap. I was thinking it oud take longer than 10 minutes.
  7. Feb 7, 2020 at 11:28 AM
    tightywhitey
    New Orleans, LA
    Replaced it today. Sliced and peeled the old one off. Windexed and pushed the new one in.
