FOX PRO shocks from a 2019-2020 on my 2018
Discussion in 'Suspension' started by SM 2018 1794, Feb 5, 2020.
  1. Feb 5, 2020 at 11:21 PM
    SM 2018 1794
    SM 2018 1794 [OP] New Member
    Hi everyone I want to know if replacing my factory TRD off road shocks with the new FOX Shocks would be worth it.
    Benefits and height change etc?
    Second how do I get ahold of the new FOX suspension since I heard on PRO owners can buy them.
    Any thoughts
    Tundra1078 and Rica25 like this.
  2. Feb 5, 2020 at 11:39 PM
    InTheRough
    InTheRough New Member
    Kolt
    Gig Harbor, Washington
    2020 Platinum
    AR Headers DirtyDeeds Exhaust UpTop Racks Rock Warrior wheels
    If you are only looking for a more capable stock height suspension then the Pro suspension may be what you are looking for but if you plan on lifting at all, you may be better off looking at the FOX (or other) branded suspension parts; especially considering the price.
    Only Pro owners are supposed to be able to buy them but pretty much any dealer can find a TRD Pro VIN to order the parts.
    Sparks parts sells the individual parts:
    TRD Pro Fox Suspension - Rear Shock - Toyota (PTR61-34190-RR)
    TRD Pro Fox Suspension - Front Left Spring and Shock - Toyota (PTR61-34190-LF)
    TRD Pro Fox Suspension - Front Right Spring and Shock - Toyota (PTR61-34190-RF)
    rustytoys likes this.
  3. Feb 6, 2020 at 3:17 AM
    SM 2018 1794
    Thanks for information and part numbers.
    I was thinking the TRD FOX suspension may lift the truck up at least another inch or two from the stock height. Or at the very least act as a leveling kit to bring the front end up just a little.
    Guess I would have to find a PRO and do some measurements or see if the factory has spacers I would have to buy as well?
    Mainly looking for the best suspension for ride quality and performance without changing control arms or anything to give Toyota a reason to screw with the warranties I paid for.
  4. Feb 6, 2020 at 4:29 PM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    The Fox Pro suspension raises the front end about 2", the rear is the same height as stock trucks I believe
  5. Feb 6, 2020 at 4:42 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’d go with the fox 2.5s over the pro suspension and I’m sure they are pretty close in price.
    Berdine likes this.
  6. Feb 6, 2020 at 5:42 PM
    Blueknights75
    Ron
    Clayton, NC
    Both the TRD PRO Billys and the TRD PRO Fox shocks level the front 2”. There is no lift effect on the rear for either type of PRO shocks.
  7. Feb 6, 2020 at 7:06 PM
    SM 2018 1794
    Thanks for all the replying. Lifting the front a couple of inches sounds pretty good.
    I will definitely look at the shocks from FOX as this would most likely be the company I would use.
    Think Ill find a PRO and try to park next to it just to get a good visual.
    Does anyone have a PRO with the FOX shocks that can let me know how the ride is on the pavement.
    Thanks
  8. Feb 6, 2020 at 7:20 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    IMO, for the price, there are many many other options out there.
  9. Feb 6, 2020 at 7:28 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Don’t forget to measure the before and after of install of new parts. So you’ll know if any thing happens.
    On level ground, measure from center of the wheel well opening on fenders and bed to the ground.
    Good luck.
