Air intake systems
Discussion in 'Performance and Tuning' started by Tj020, Feb 1, 2020.
  1. Feb 1, 2020 at 2:31 PM
    Tj020
    Tj020 [OP] New Member
    Tyler
    2017 Toyota TSS off road 4X4
    None
    What are the best air intake brands/systems for a 2017 Toyota Tundra crew max TSS off-road?
    Thanks!!
  2. Feb 1, 2020 at 2:33 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Stock.
    Tiamat likes this.
  3. Feb 1, 2020 at 2:36 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Stock. Made by Toyota.
    Rex Kramer likes this.
  4. Feb 1, 2020 at 2:45 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Stock is CAI
    Do a drop in, remove charcoal filter or look into SABM if you feel like tinkering.
    15whtrd, Ckatz53 and Rex Kramer like this.
  5. Feb 6, 2020 at 7:43 AM
    tsmith2037
    tsmith2037 New Member
    2018 Limited TRD
    Considering Cold Air intake and rear swaybar
    What about the TRD cold air intake factory mod. Is this worth doing?
  6. Feb 6, 2020 at 9:57 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    If you want it because of looks and/or sound, then yes.
    10TundraSR5 and 15whtrd like this.
  7. Feb 6, 2020 at 10:02 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The factory air intake systems is the best.
    If you free up the exhaust side then it's worth dropping in a free flowing air filter, otherwise - stay with stock.
    15whtrd likes this.
  8. Feb 6, 2020 at 10:57 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1 another, spend money on something with benefits
    15whtrd and Tj020[OP] like this.
  9. Feb 6, 2020 at 2:59 PM
    Tundra_power
    Tundra_power New Member
    Sabm with high flow drop in filter and trd flow accelerator=bad ass, iv tried them all k&n, volant, s&b and all of them suck and loses low end torque. Stay with stock get bullydog or dap tune.
  10. Feb 7, 2020 at 9:58 PM
    Tj020
    Tyler
    None
    Awesome, appreciate the info
  11. Feb 7, 2020 at 11:06 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I have to agree with the others about leaving it stock.
    If you feel the need to buy something, maybe a Magnum FLOW Pro DRY S Air Filter.
    https://afepower.com/afe-power-31-10146-magnum-flow-pro-dry-s-air-filter
    https://www.amazon.com/aFe-Power-31...FZEVRN2R8RY&psc=1&refRID=55R2NDVBDFZEVRN2R8RY
    I've always used the OEM air filters.
    Never use an oil based filters (from what I've read), it will mess with your sensors.
    Welcome to the forum...
  12. Feb 8, 2020 at 3:01 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Toyota spends alot of time and money on Research and development and testing with all kinds of Hi-tech equipment....................that you dont have. Leave it stock.
    Tiamat likes this.
  13. Feb 8, 2020 at 4:13 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Careful with anything labled "high flow", "free flow", what it really means is More dust particulates that can cause engine wear (grit against pistons) is allowed in compared to Stock.
    I mean how can you get more flow without letting in more bad stuff??
  14. Feb 8, 2020 at 4:36 AM
    Rex Kramer
    Georgia
    Great air filter... it really earns it's keep if you also open up the exhaust with something like a BAMuffler cat-back.
  15. Feb 8, 2020 at 5:03 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    No
  16. Feb 8, 2020 at 5:47 AM
    Vizsla
    Vizsla 2 = 2.5
    Stock, or maybe something that gets rid of the stock style filter. I’ve used the TRD drop in, K&N, and AFE dry flow. All pulled dust through on the first trip off-road, stock filter let’s nothing visible past it.
  17. Feb 8, 2020 at 6:43 AM
    Tiamat
    Tiamat New Member
    any performance mod done to computer controlled engines are wasted if not tuned for the new air, exhaust or fuel. This is what I was told by local performance shop.
  18. Feb 10, 2020 at 3:54 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    It only works if you add a front spoiler, a whale tail in the back, some side skirts, rear diffuser, slicks, and some ground lighting...................and the Dice hanging from the rear view mirror.
    10TundraSR5 likes this.
  19. Feb 10, 2020 at 4:38 AM
    Tiamat
    Tiamat New Member
    Man you forgot the most important part...chromed Curb indicators
  20. Feb 10, 2020 at 5:15 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Toyota has a really good design straight form the factory. Just replace the filter with a TRD or K&N and you're good to go. If you want to get all fancy pants, get the air accelerator from the TRD CAI and install it as well.
    Tiamat likes this.
