2020 crew max SR5
Discussion in 'General Tundra Discussion' started by dekmak, Jan 11, 2020.
  1. Jan 11, 2020 at 6:18 AM
    dekmak
    dekmak [OP] New Member
    2020 Tundra SR5 Crewmax 4x4
    Stock
    I have a 2020 crewmax SR5 and wondering about remote start. If I setup the free trial of the remote connect and Entune will it allow me to have remote start? Also, once the free trial is over do you have to have a WiFi subscription for the vehicle as well in order to use the remote connect features.?
  2. Jan 11, 2020 at 10:12 AM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Not all devices are compatible with remote connect. Check with toyota for your device. Once trial is over you will need to subcripe to it.
  3. Jan 11, 2020 at 12:09 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Do you have remote start capability in a SR-5 level? My 2020 limited will start using the fob pushing lock 3X and holding on the 3rd time. I also setup remote connect and it gives lock/unlock start/stop, tire pressure, map locate, guest driver settings - mph limit,range.... and a few other things. Saftey connect, Remote connect, destination assist all are good for 1 year, Dynamic Navi expires in 2 years. I use apple connect and haven't even touched Toyota navi yet. I'm not sure if I will subscribe to any of these features once they expire. I'm fine with the remote start on the fob.
    Do you have the remote start feature?
  4. Jan 13, 2020 at 4:19 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    I have a 2020 SR5 with the premium audio. I setup remote connect and can start the truck with the app. Haven’t tried with the key fob yet.
  5. Jan 13, 2020 at 2:01 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    I tried to get Remote Start on my 2020 Sr5 with the app. It said my vehicle was not compatible to have Remote Start. My dealer told me I had it at the sale. Did the app. Nope!
  6. Jan 15, 2020 at 4:20 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Mine says it just has safety connect, which I haven't signed up for yet.
  7. Jan 15, 2020 at 5:28 AM
    swampshark
    swampshark New Member
    south la
    2020 MGM SR5
    My salesman also touted the features of the "remote connect"....but I believe u must have the premium audio...
  8. Jan 15, 2020 at 5:47 AM
    Doxiedad
    James
    Charleston, SC
    Mine made no mention of remote connect, just the safety connect. Yeah you have to have the premium audio for it to work.
  9. Feb 4, 2020 at 6:30 PM
    ssmith110
    ssmith110 New Member
    I have a 2020 SR5 CM. Just tonight is was trying to see if I had the app capabilities. App kept kicking me off. Went to the garage and pushed the lock button 3 times and hold it in, the Amber lights flash and mine starts up. Motor dies when you touch the door handle. Still can't seem to make the app load right though (Android).
  10. Feb 5, 2020 at 4:40 AM
    swampshark
    south la
    2020 MGM SR5
    ssmith110....do u have the premium audio with on board nav?
  11. Feb 5, 2020 at 4:42 AM
    ssmith110
    Swampshark I believe it's just standard. Not JBL. Nav is through Android auto.
  12. Feb 5, 2020 at 4:50 AM
    ssmith110
    Swampshark I was trying to set up the remote app. It wouldn't let me enter my Vin but didn't say the Vin was not compatible. My truck does have the wifi though. That's what I was researching when I came across this thread.
