Red Rust and Brine spots on White paint- how to remove?
Discussion in 'Detailing' started by TWJLee, Feb 4, 2020.
  1. Feb 4, 2020 at 11:21 PM
    TWJLee
    TWJLee [OP] No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
  2. Feb 5, 2020 at 12:44 AM
    somadbamos
    somadbamos Dude, you're being totally undude.
    Jake
    Idiot Out Wandering Around
    '14 Crewmax w/ Attitude
    Clay bar - super simple, just takes some elbow grease. There are kits with the quick detail spray available at most auto/big box stores you can use. I usually use a clay bar with soapy water and a mit. Set the mit on the hood/top of the fender to keep the area I'm working on lubricated and rub back and forth in a straight line. Fold the clay over when it gets dirty. If you drop it, pitch it. Not worth scratching your paint saving a lil chunk of clay.
    Give YouTube a search, tons of how to's if you want to see the process!
    T-Rex266, Omohundro and TWJLee[OP] like this.
  3. Feb 5, 2020 at 3:41 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I would try Iron-X. It helps remove metal like that from paint. And then clay bar.
  4. Feb 5, 2020 at 3:54 AM
    PermaFrostTRD
    Northern NY
    As said above, iron X.
    Also another product “smooth move” by shine supply that others have attested to as being just as successful as iron X but without the awful chemical smell.
    I can only speak for the iron X. It works but it stinks.
  5. Feb 5, 2020 at 4:08 AM
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
  6. Feb 5, 2020 at 5:43 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    It does smell. They have a lemon scented one now which is slightly less foul.
  7. Feb 5, 2020 at 8:04 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I would also be inclined to protect the finish with an acrylic sealer like Klasse.
  8. Feb 5, 2020 at 10:04 AM
    I bought a new vehicle that had that when I bought it and the dealer called it some kind of fallout. They took it into the detailing bay and an hour later it was gone. They had some kind of liquid that removed it but I dont know what it was called. Reach out to AutoMagic and see if they have something. https://www.automagic.com/
  9. Feb 18, 2020 at 6:41 PM
    kodiak
    kodiak New Member
    Iron-X will get rid of them easy peasy
  10. Mar 18, 2020 at 3:41 AM
    briarpatch
    briarpatch New Member
    As others have said, Iron-X or similar fallout remover is your friend on this one. Meguiars now sells a ready to use product called Spray Clay, which might be available to you locally. Most of these products do smell, mostly like skunk piss, but they do they job
