  1. Feb 3, 2020 at 7:30 PM
    Jpneely
    Jpneely New Member
    White SR5 5.7
    Thats good to know. thanks bud.
  2. Feb 4, 2020 at 4:57 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Installed a 295/70/18 spare tire on the stock spare wheel. plenty of room between the Toytec shackles.
  3. Feb 4, 2020 at 5:58 AM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    So much better
    monaco730, NAFlash, GAknight and 6 others like this.
  4. Feb 4, 2020 at 9:15 AM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Out with the old
    In with the new
  5. Feb 4, 2020 at 10:03 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Looks good, do you have any more pics of the mounting, and what material you used? I like the rokblokz but not their molded logo...
  6. Feb 4, 2020 at 10:09 AM
    coastaldad
    coastaldad New Member
    Charles
    Lenoir, NC
    2018 Crewmax TRD Off Road
    325FDB1C-B48B-422E-8C64-C24909A3604F.jpg 46EC293C-3B0A-441D-ADB6-11BE7206C3C8.jpg A1F61D06-4662-47A0-8D87-34BC38871190.jpg Installed TVD Vinyl emblem inlays on the blackout iforce emblems.
    773_eddie, Boerseun, NAFlash and 8 others like this.
  7. Feb 4, 2020 at 10:20 AM
    Nice. How's it feel? Any complaints? I mean, get really nit picky and let me know. Everybody always just says, "good" or "It's better" and I am looking for anything that anybody doesn't like on it.I am not sure that I would like the completely different shape on the TRD shifter.
  8. Feb 4, 2020 at 10:30 AM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    Link to material:
    https://www.amazon.com/Buyers-Polym...s&qid=1580840765&sprefix=mud+,aps,277&sr=8-22
    I'll get some mounting pics. All the mounting was done using factory hardware and locations. The only spot that was different was the front flap innermost screw, I had to make a 1.5" spacer and use a longer screw.
    Edit, Link to build with a few more pics:
    https://www.tundras.com/threads/trooperdc4x4s-2017-build.42268/
  9. Feb 4, 2020 at 10:37 AM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    Had all of the new painted front end parts clear bra’d.
    ElNopal, twistedcricket and GODZILLA like this.
  10. Feb 4, 2020 at 10:43 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Awesome, thanks!
  11. Feb 4, 2020 at 10:59 AM
    ARMYGREEN
    2014 CrewMax MGM
    Only thing I would change on it is make the stitching black as well.
    GODZILLA[QUOTED] likes this.
  12. Feb 4, 2020 at 12:44 PM
    Looks great.
    I keep thinking about doing this.:monocle:
  13. Feb 4, 2020 at 1:51 PM
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    Finally got the dome and map lights changed to Headlight Revolution LEDs, and my VLEDs on the front footwells, have to study on how to turn them on sans opening the door, but I am working on a two way connection to my interior light switch and a separate small led lit on/off switch, i think I have it figured out. but want it to be correct.
    New Super white bulge and grill surround in as well, thinking on the mirror caps...
    ElNopal likes this.
  14. Feb 4, 2020 at 4:18 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Fits the hand much better, I rest mine on top not around the side. About the only negative I can say is how the back rounds out, not going straight down - but that's being super super nitpicky. You can tell it's plastic as that's right where your fingertips go, it doesn't bug me, but if you like full leather shift knobs than it will bother you.
    2018Tundra and GODZILLA[QUOTED] like this.
  15. Feb 4, 2020 at 4:27 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    What did you use?
  16. Feb 4, 2020 at 4:34 PM
    Thank you for the honest dirt. I don't mind the basic one as far as feel goes, but it just looks really cheap. I've been toying with lots of options for replacing it, but it's a low priority.
  17. Feb 4, 2020 at 4:44 PM
    belanger9
    Edmonton, AB
    A bunch
    The TRD one is expensive too - but I tried one that's kinda similar just all leather, but the threads were about an inch deep (stock Tundra shifters are like 6 inches deep) so there was so much of the shift rod exposed it looked weird. I think a ball style would look ok, but the hand shaped ones either need the deep threads or the shifter boot to look decent IMO.
  18. Feb 4, 2020 at 4:47 PM
    I agree, and I don't care for just the shifter balls. I was heavily considering the Tacoma knob with a boot, but then AJT put out the cover for the chrome, and that was the only reason I considered the boot.
  19. Feb 4, 2020 at 4:54 PM
    Newbie_19
    Newbie_19 New Member
    Towson, MD
    2019 SR5 SX Package Black
    Havoc HS2 flat black steps, Thule XSporter Pro Rack, spray in liner, 20% front windows, black lugs, TRD Rear Swaybar, OEM LED Fogs, 2019 Pro Headlights, NSV Lightbar, BAMuffler 10" budget, BAK MX4 JL Stealthbox, Infinity Speakers w/ aftermarket amps and stock HU.
    Finally back in town and had enough good weather to swap over to Pro LEDs to go with the OEM LED floods.IMG_20200204_172121~2.jpg
  20. Feb 4, 2020 at 4:54 PM
    daays
    daays New Member
    Narrowed my Caliraised fog issues down to a blown fuse. I had done the polarity swap to no avail, so when I went to check fuses I found the fog fuse was blown. I replaced it with the spare and it immediately blew again. I checked all the wiring again as well. I ordered a 100 count spare fuse set on Amazon, and we'll see if the 3rd time is the charm. If that doesn't work, I'll see if I can get the stock ones working which should isolate it to the fogs or their harnesses. Not a fun experience to say the least. Not that removing the fender liner is hard, it's just obnoxious doing it when you're trying to dodge cold weather and rain and only being able to do it in the couple hours of daylight after work.
    jewsNbrews, NAFlash and equin like this.
  21. Feb 4, 2020 at 5:58 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Sorry to hear of your fog fuse woes. I’ve read of a few others having issues as well, not necessarily with Caliraised in particular but with LED fogs regardless of brand. This is one reason I’m reluctant to upgrade. Please keep us updated on what more you may find on this issue.
  22. Feb 4, 2020 at 6:15 PM
    daays
    daays New Member
    Yeah I've seen others with issues as well. If this keeps happening I may just try and sell them and pick up some BD fogs like I thought about before I purchased these. Just a harder price tag to stomach.
    equin[QUOTED] likes this.
  23. Feb 4, 2020 at 7:12 PM
    Kevmo
    Kevmo _________
    20 MGM TRD Limited DC
    Got the TRD skid plate on and went ahead and painted the tow hooks at the same time. Very happy with the result.
    Heloravy, khunk, Spitfire and 16 others like this.
  24. Feb 4, 2020 at 7:14 PM
    dspilot
    dspilot Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    Picked up a brand new OEM rubber bed mat from a guy on Facebook for 40 bucks. I'm gonna have to trim it a little to make it fit right with my drop in bed liner, but couldn't beat the price.
  25. Feb 4, 2020 at 7:50 PM
    equin
    Ed
    DFW, TX
    Sorry for the dumb question, but what are the BD fogs?
  26. Feb 4, 2020 at 7:50 PM
    daays
    daays New Member
    My bad. Baja Designs.
  27. Feb 4, 2020 at 7:51 PM
    equin
    Ed
    DFW, TX
    Ah, gotcha. Yeah, I like those, too. So the BD fogs don’t have blown fuse issues?
  28. Feb 4, 2020 at 7:52 PM
    daays
    daays New Member
    They may very well but I've read threads about Caliraised having issues on multiple forums for Tundras and Tacomas. Should have done more research I suppose. But they're definitely a more reputable brand so I would hope they're able to work it out a little better.
  29. Feb 4, 2020 at 9:11 PM
    Keoki_m
    Keoki_m New Member
    Very nice!!! Did you just paint the silver part black? What’s the deets?
  30. Feb 4, 2020 at 9:39 PM
    ostm282
    ostm282 New Member
    Stock 2018 Tundra Limited Silver
    2" leveling kit installed up front
    I was motivated to build this mount because I saw someone else do something very similar. This is just a basic piece of 18"x2"x1/8" thick aluminum painted and mounted on the legs of the driver seat. The screws are countersunk and are threaded into a painted piece of wood on the backside. The fire extinguisher came with a wall mount so I just added it to my bracket and boom. It doesn't interfere with my feet when I'm driving and I forget that it's there. I only notice the red color when I get in the truck. Very simple and could come in very handy.IMG_20200201_142307.jpgIMG_20200201_142557.jpg IMG_20200201_142654.jpg
    Retired Blue, KELZ84, ntg and 19 others like this.
