  1. Feb 3, 2020 at 9:30 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Only 1 of 4 pistons on each caliper were working. This was after 15 pumps of the brake pedal.
  2. Feb 3, 2020 at 9:40 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    It doesn't take a much bigger mirror to help a lot. My ranger mirrors are only a little bigger, they show me a lot more than the tundra mirrors. Cameras are great, but perspective that you get from side mirrors are really nice for seeing the back corner of a vehicle.
  3. Feb 3, 2020 at 9:57 AM
    KarmaKannon
    Utah
    Some junk
    Just ordered stuff to do another retrofit set of headlights. I want to try some new things with paint and such so it will be fun. Maybe I'll get them done this weekend, but we'll see. I have garage work to do besides that. I'm still stoked!
    FrenchToasty and speedtre like this.
  4. Feb 3, 2020 at 10:03 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It's probably going to stop a little better with the new callipers.
  5. Feb 3, 2020 at 10:29 AM
    Did you notice any uneven pad wear? Any pulling to the side under braking?
  6. Feb 3, 2020 at 11:03 AM
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    Thank you!
    SoCalPaul[QUOTED] likes this.
  7. Feb 3, 2020 at 11:06 AM
    Musashi66
    That is a spectacular looking truck!! I want those wheels - I was very tempted to buy them when TRD had that awesome black Friday sale.
    wingnutted and speedtre[QUOTED] like this.
  8. Feb 3, 2020 at 11:11 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Thanks...as good as their black friday sale was, 25% off, their TRD 40th anniversary sale last year was 40% off.... I ALMOST pulled the trigger last year...still kicking myself for missing that one...lol
    Musashi66[QUOTED] likes this.
  9. Feb 3, 2020 at 12:01 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    The new one is much better :cheers:
    speedtre[QUOTED] likes this.
  10. Feb 3, 2020 at 12:30 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Looks sick. Nice job!
  11. Feb 3, 2020 at 2:19 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    That would affect your braking performance a bit!
  12. Feb 3, 2020 at 2:36 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    My truck was assembled in late 2003 and has a 13WL on them so Id assume they are the bigger ones, Thanks!
  13. Feb 3, 2020 at 2:59 PM
    Fred
    Hand Protectors
    I did not. The pads are 1.5 years old (12k miles). Seems like only one piston on the inside of each wheel caliper was working fully and the one below it was slightly working. Both outside pistons on each side were seized. So, maybe they were equal in their pressure keeping the drive line straight.
    I just buttoned things up and did some more post-mortem analysis on the calipers. This pic shows the actual piston that was working the best after I pulled it out with channel locks. Nasty fluid in the chamber cup was from being trapped up in those other chambers even after I’ve bleed them 3 times prior recently.
    Check out the corrosion built up on the side of the ‘best’ piston. I can imaging what the others would look like if I could pull have them out. Tried my best, but no can do. Locked up!
  14. Feb 3, 2020 at 3:18 PM
    Fred
    Hand Protectors
    Finished the front brake 13WL upgrade. Took about 7 hours in total. Truck stops pretty good now. I’m still getting used to the new pedal feel that the upgrade gives. Feels like pedal distance is a *little* farther on the push. The braking is much more solid. I think tomorrow I’ll adjust the LSBP Valve down a bit so more bias goes to the front brakes now that the old stuck calipers are gone.
    Tomorrow I’ll also be bleeding and adding the new DOT5.1 fluid for the final tune up.
  15. Feb 3, 2020 at 3:29 PM
    Fred
    Hand Protectors
    Here is a picture of the Widdy Wack Bleeding System. Pretty straight forward. Got all the ‘Self Bleeders’ installed except for the LSBP Valve which will go in tomorrow on the final DOT5.1 install.
    Bottom is a pic of a loose cotter pin that was making a rattling noise on the passenger side. I discovered the noise a few months ago when in a parking garage. The echoing sound caught my attention and stumped me until today when pulling off the bent up axle cap to straighten it out I could hear the tinkle sound of the pin rattling. Fixed it by bending the other leg up in the opposite direction.
    speedtre and bmf4069 like this.
  16. Feb 3, 2020 at 3:39 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    how/why does one do this, and should I, and where is it? :rofl:
    vaguely specific enough?
  17. Feb 3, 2020 at 4:00 PM
    Fred
    Hand Protectors
    It shifts the braking bias to the rear brakes. Normally, it would sensing a load in the bed and adjust the braking to the rear brakes. In my case, I manually ‘adjusted’ the nuts up to ‘fake’ a weighted bed. I did this as an experiment for better braking last year.
    Turns out my braking improved. Now that I have new properly operating front calipers the adjustment is not needed as much and I do some slight shifts/tweaks.
    The LSBP Valve is located under the bed near the drivers side behind the spare tire. The adjuster is located just above the rear diff housing.
    CodyP[QUOTED] likes this.
  18. Feb 3, 2020 at 4:21 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Likely wasn’t seized yet. When you pump the brakes without pads only 1 piston coming out is kinda normal. Sticking is likely what you had
  19. Feb 3, 2020 at 4:34 PM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    Sold my 1st Gen today, a little sad to see her go but she served me well :) She was an 04 double cab 2wd with 197k on the clock, never had a problem with it. Her she is rolling out of the drive for the last time :wave:
  20. Feb 3, 2020 at 4:35 PM
    empty_lord
    05 rollover special
    Sucks to see them go, but at least your not “upgrading” to a domestic!
  21. Feb 3, 2020 at 4:35 PM
    Fred
    Hand Protectors
    Cool. Is that caliper an open loop system? I had lots of nasty dark fluid still up in there still with recent flush bleeds. Both those inside pistons on each caliper were frozen. I put Channel Locks on them to try and turn/twist them loose and no go. Couldn’t pry them out with BF screw driver either.
  22. Feb 3, 2020 at 4:36 PM
    empty_lord
    05 rollover special
    It’s just a big empty cavity in there for fluid.
  23. Feb 3, 2020 at 4:38 PM
    41bigdawg
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Definitely not! My 5th Tundra is sitting out in the garage :)
  24. Feb 3, 2020 at 5:23 PM
    SoCalPaul
    Paul
    https://www.youtube.com/watch?v=qoQlAW4DPnA
  25. Feb 3, 2020 at 5:36 PM
    Fred
    Hand Protectors
  26. Feb 3, 2020 at 6:45 PM
    SoCalPaul
    Paul
    KarmaKannon likes this.
  27. Feb 3, 2020 at 6:54 PM
    Chungdra95
    Chungdra95 Chungdra95
    Dennis
    CA
    2002 Tundra, sr5, 4.7l, RWD, LSD
    Bilstein 6112& 5160 setup Cold Air int
    Installed some Bilstien 6112 up front and 5160 in back today(sorry didn't take before picture) the ride is soooo much better than the stock OE suspension.20200203_145509.jpg 20200203_145521.jpg 20200203_164026.jpg
    Darkness, Volt92, 1Silverback and 9 others like this.
  28. Feb 3, 2020 at 6:56 PM
    Looks good, is your truck black, or that deep blue color? I have the same setup front and rear, which setting did you do the fronts at?
  29. Feb 3, 2020 at 7:01 PM
    Chungdra95
    Dennis
    CA
    @FrenchToasty Thanks man,Yeah It's black. I set it to the top (6th ring)
  30. Feb 3, 2020 at 7:07 PM
    wingnutted
    wingnutted New Member
    Seattle
    2006 Black Tundra TRD Double Cab
    That looks great! I'm in the process of ordering exact same, 6112 front, 5160 rear. What setting did you go with? UCA's as well or not?
