Tie rods out of adjustment?
Discussion in 'Suspension' started by scpete24, Jan 31, 2020.
  1. Jan 31, 2020 at 8:18 AM
    scpete24
    scpete24 [OP] Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Went offroading everything was great then I drove over what looked to be a small puddle on a dirt road but it was actually a pretty large pothole. Hit with the right front wheel and my buddy riding shotgun bounced up and almost gave me an aftermarket sunroof. Alignment was instantly off steering wheel was turned a bit left to go straight.
    Brought it back and took it to the off road shop I use for an alignment. Gets working on it calls and tells me the tie rod on the front passenger wheel that hit the bump is out of adjustment so they cant bring the toe in anymore. He says its bottoming out and wants to undo the tie rod and cut a little of the thread off so he can bring the toe in more. He said nothing looks bent or broken and can;t really explain why just knows thats the issue...
    He does a lot of work on my buddies jeeps and has always been very knowledgeable so I trust him but any of this make sense to anyone?
  2. Jan 31, 2020 at 8:23 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Something did get bent. Did he have to push out the other side?
  3. Jan 31, 2020 at 8:46 AM
    scpete24
    Orange County, CA
    What I am thinking as well. Any guesses as to which part would get bent the easiest?
  4. Jan 31, 2020 at 9:11 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I couldn't venture to guess. That's why I asked if the other side had to be moved out. As in if it shifted the entire steering rack.
    15whtrd likes this.
  5. Jan 31, 2020 at 9:14 AM
    scpete24
    Orange County, CA
    Sorry I missed your questions,said the other side was fine. I would be impressed if it moved the entire steering rack... Said the only problem is right front. Right now it's drive able but said the tire wear would be bad.
  6. Jan 31, 2020 at 9:47 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe time to just replace them and get some beefy end links from Coach builder.
  7. Jan 31, 2020 at 9:59 AM
    scpete24
    Orange County, CA
    The thought has crossed my mind, prob would if I knew it would fix my current issue
    15whtrd[QUOTED] likes this.
  8. Jan 31, 2020 at 10:02 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    If you have loose steering rack bushings could it have caused the rack to shift?
  9. Jan 31, 2020 at 10:07 AM
    scpete24
    Orange County, CA
    I'm thinking it could have but I have zero play in my steering wheel...
  10. Jan 31, 2020 at 10:22 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I’m definitely no alignment guru by any means. But it is known that many folks, when they get an alignment, don’t get their lower A arm cam eccentric bolts tightened enough. They take 200+ftlbs to keep them from getting out of whack. I’m sure your tech would’ve checked that but worth a thought. Also the cam tabs can get bent.
  11. Jan 31, 2020 at 10:25 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It sounds to me like something bent or shifted. If the LCA cam bolts didn’t shift, a bent spindle is my next suspect.
    scpete24[OP] and 15whtrd like this.
  12. Jan 31, 2020 at 10:45 AM
    scpete24
    Orange County, CA
    Forgot about the cam tabs being so weak. I know some vendor sells a product to strengthen them.
  13. Jan 31, 2020 at 10:46 AM
    scpete24
    Orange County, CA
    Hoping not the spindle but I agree it could have gotten pushed out from the force of the uptravel hitting my extended bumpstops
    15whtrd likes this.
  14. Jan 31, 2020 at 10:53 AM
    Vizsla
    Vizsla pretend2send
    If the alignment cams are fine, and it sounds like they are, have him check the spindles. Super simple, measure in between the top of the knuckle and tire on both sides, if different ones bent. If they are good you probably pushed the frame and coil tower in. Not much you can do, I would and have re-clocked the steering wheel instead of cutting the tie rod threads.
  15. Jan 31, 2020 at 10:58 AM
    scpete24
    Orange County, CA
    Thanks man, great info here. Whats it take to re-clock the steering wheel?
  16. Jan 31, 2020 at 11:03 AM
    Vizsla
    Vizsla pretend2send
    Look under dash up by brake pedal, there is a pinch bolt splined clamp on the shaft, it’s easy.
    joonbug and scpete24[QUOTED][OP] like this.
  17. Feb 2, 2020 at 5:55 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Call or David at CB he will tell you if it will fix it or not. David is not like other aftermarket place. Very smart guy and will not BS you and tell u to buy it if it will not fix it!!
