Headlight Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by PoppytoZach, Feb 2, 2020.
  1. Feb 2, 2020 at 11:06 AM
    PoppytoZach
    PoppytoZach [OP] New Member
    2016 Tundra
    The headlights on my 2016 Tundra went off during my drive last night. The dash lights stayed on. Not sure what happened. I turned the engine off and started the truck again after 5 minutes or so and they started working again. Any one else have this experience? Also, on two separate occasions months apart, the lights would not turn off after I shut off the engine and locked the truck. I pulled the fuse each of those times to kill the lights. I've had the truck since 2018.
  2. Feb 2, 2020 at 11:07 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Did you check the relays?
  3. Feb 2, 2020 at 11:46 AM
    PoppytoZach
    2016 Tundra
    No,but I'll take a look. Thanks for the reply. I also wanted to mention that I do not have the auto headlight feature unlike many of the posts related to issue.
  4. Feb 2, 2020 at 12:22 PM
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    gearrunner on youtube had that problem it was his headlight switch, only happened when switched to auto i believe
