Deck System or Locking Bed Cover for Golf Clubs?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Atlas415, Jan 28, 2020.
  1. Jan 28, 2020 at 11:18 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had a Retrax on my 2005, it rattled like crazy on the highway with the big rear window down.
    I hear they don't rattle as much anymore..
    It was fairly watertight.
    I currently have an Undercover Flex on my 2014, had it replaced under warranty.
    It certainly is not waterproof, it leaks a tad around the edges in a hard storm, but the new one leaks less than the old one.
    Old one started leaking thru the seams in the panels.
    79999485-1BF1-47BD-BE7A-392B4B48BCED_zps_3dcb9ee9432f39537119854886dff8fd4c53ae99.jpg
    E56C2A52-CB37-4473-BA4A-B034B228A760_zps_68059568c03bcad9bc30d16392fdbc6934371974.jpg
    Old one before they replaced it.
    If Undercover would not have warranted the old Flex, I was ready to buy a Diamondback for $1600.
    I'd go with the Diamondback if the rugged look fits to looks of your truck.
  2. Jan 29, 2020 at 8:04 AM
    Atlas415
    Atlas415 [OP] New Member
    Yes, usually. But that would be a good idea except that I also just want to keep the clubs in there permanently.
  3. Jan 29, 2020 at 8:32 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How expensive are the clubs? The diamond back is the only one that would probably deter all theives. Any others cover can be broken into with the right force or big enough pry bar
    Atlas415[OP] likes this.
  4. Jan 29, 2020 at 8:36 AM
    Atlas415
    Yeah that’s a great point. My buddy that has a 2012 tundra has one of those. The only thing he said he doesn’t like about it is that with a lift, it makes it harder for him to get to things that are up by the cab because of the way that the front half of it opens up, or something to that effect. But it definitely seems very sturdy and I’ve stood on the back of it. Do you think that it ever gets in the way as far as if you have to load up a bunch of boxes orFurniture to help somebody move, because you have that front half in the way? Or is it reasonably quick for two people to takeoff if you had a situation like that?
  5. Jan 29, 2020 at 10:17 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ive had 2 different kinds of folding covers. Ive gone back and forth on a rollup. If you ever need a full truck bed i can see the diamond back being very intrusive. They have to be very very heavy
  6. Jan 29, 2020 at 10:53 AM
    LyonKing
    LyonKing No way Bells is bigger than Waimea bro...
    2019 White TRD Pro
    Nitto Ridge Grappler 295/70/18 KMC XD135 GRENADE OR Light Bar - Rigid Flush mount reverse lights - Rigid Diamond Back HD Tonneau Cover AMP Research Powerstep OEM Wireless Charger Husky Liners X-act Contour mats Interior LED Swap Center Console Organizers 6 3/4" Antenna Pioneer 7" HU - AVH-W4400NEX Graco Nautilus 3-in-1 Car Seat
    For the DiamondBack It's really easy to pull off the three panels by yourself. The too main ones are easy and don't need tools. For the little middle panel it's less than 10min to pull it off and just need a socket or wrench. You don't need help.
    I currently leave my clubs in the bed full time and got new ones last year with custom shafts etc so they weren't cheap. More than double the cost of the DB HD cover that's for sure.
    All this said is b/c I don't need to use my full bed all the time so it works well for me and keeping my clubs from getting stolen.
    Atlas415[QUOTED][OP] likes this.
  7. Jan 29, 2020 at 8:20 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Not so- the two big panels weigh about 45 lbs each tops. Removing them is easy- flip two small bales that hold the shocks in place, then open the panel to 90 deg, slide sideways and lift. The panel is off. Then, loosen clamps on each side with a wrench and the center comes off quickly.
    LyonKing and Atlas415[OP] like this.
  8. Jan 29, 2020 at 9:50 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dang you’re talking straight to my wallet!
  9. Jan 29, 2020 at 10:01 PM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    Diamondback without question. And perhaps a crossbin for shoes and clubs. Bakflip and Extang are overpriced junk in my book, based on first- hand experience.
  10. Jan 30, 2020 at 3:14 AM
    Atlas415
    Thanks a bunch for posting these pics, too! It is definitely a good looking system as well...
  11. Jan 30, 2020 at 3:17 AM
    Atlas415
    Not sure if I mentioned it, but can you believe what the dealership charged for the trifold cover? I told them to add it as a dealer option when I was buying the truck in December or so. I thought I'd read that the price was $700. But after the install, it came to over $1200!!! I'm suppposed to get a refund on it today when they take it off. So I DB would just be a straight swap, cashwise...
  12. Jan 30, 2020 at 4:57 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I got this one from Amazon. Very high quality and absolutely no leaks in my bed! I like how it rolls into the canister and it only takes up about 10" of the bed in the front. It isn't tall so gear and whatever can be put under the canister. I can lock it in any position and rolls very easy into the canister. The only thing that they could improve on is that each side lock has a different key. No big deal, just an extra key.
    Same as a Retrax but at 1/2 the cost.
    https://www.amazon.com/gp/product/B07NVSPD3T/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    Atlas415[OP] and nowayout like this.
  13. Jan 30, 2020 at 5:34 AM
    Borgs
    Borgs New Member
    PA
    Check out Mike’s @mgm16trdpro
    build page. He has a Diamondback HD with the pull out deck system. He sold me his Diamondback cross bin a few years ago, which I love. I have the 8 inch I think, and I think my clubs would fit in it to keep them off the bed. The 13 inch may be even better for your use.
  14. Jan 30, 2020 at 7:21 AM
    LyonKing
    2019 White TRD Pro
    $1.2k?! What a joke. That trifold is junk. You'll love the DB.
    I also leave the rain cover on the top of my golf bag which keeps them from falling out of the bag
  15. Jan 30, 2020 at 10:22 PM
    kenstl
    kenstl New Member
    Interested in this as well as I plan on keeping my clubs in the truck a majority of the time. I was leaving toward the Truxedo metal roll up with the cloth top but I do like the look and security of these.
  16. Jan 31, 2020 at 3:23 AM
    Atlas415
    I will. Thanks!
  17. Feb 1, 2020 at 6:58 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Any questions feel free.
  18. Feb 2, 2020 at 6:57 AM
    Fastestcolor
    Fastestcolor New Member
    Blue Ribbon Limited CM
    I have a roll n lock. Works pretty well imo. Will drip slightly at the corners near the tailgate if parked nose high. I have indoor outdoor carpet on my bed floor to keep the bedliner from scratching softer items and only the comers of the carpet get moisture and it doesn’t run anywhere else. I keep a uniform jacket in my bed full time and it’s never gotten wet.
