Compustar remote start question
Discussion in '2.5 Gen Tundras (2014-2021)' started by sgrounds22, Jan 29, 2020.
  1. Jan 29, 2020 at 10:52 AM
    sgrounds22
    sgrounds22 [OP] New Member
    2018 Tundra Limited
    Is there an option during installation to allow for the thermostat to be in auto mode and blow air when you remote start?
  2. Jan 29, 2020 at 11:21 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Not specifically. When the truck is started remotely, the climate controls will be at whatever you left them at. On my 2019 Limited, I believe 'auto' is a static feature that stays on.
  3. Jan 29, 2020 at 11:25 AM
    sgrounds22
    2018 Tundra Limited
    I have an 18 limited and if I have it in 'auto' when I shut the truck off it is not blowing air on remote start. It also does not start blowing air until I increase or decrease the fan speed manually. It's definitely not the temperature it is set to when I remote start the truck, so that's not it. The only thing I can think of is it's something in the compustar setup.
  4. Jan 29, 2020 at 11:37 AM
    801Tundra
    UTAH
    Assuming you're using an iDatalink bypass solution, I've never seen any HVAC control settings in the programming menus.
  5. Jan 29, 2020 at 2:34 PM
    Theonlyway
    Theonlyway New Member
    User
    My 2015 gmc 1500 had that feature. It would auto turn on heat or cooling depending on outdoor temp. Even the heated seats and steering wheel
  6. Jan 29, 2020 at 2:42 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    On my 19 Platinum I leave the heat on auto and it will not blow any air until the truck is warmed up and it can actually blow hot air.
  7. Jan 29, 2020 at 3:56 PM
    timsp8
    NY
    I have a compustar but I turn my heat to hi and fan up before I turn off the truck. Then next time I remote start it is running and warm after about 10 min.
  8. Jan 30, 2020 at 5:17 AM
    nodak67
    nodak67 New Member
    JR
    same here.
    if you leave it on auto, the hvac will not work since the truck doesnt actually know its started since the remote gets around letting the vehicle know its started. they remote doesnt let go until you press the brake. (you can watch this process by standing next to the vehicle and remote start it. the remote start unit will unarm/door unlock, start the vehicle then lock the doors under the remote start module). once you get in and press the brake, the remote start passes control to the vehicle ecu and then everything works.
    this doesnt work if you have the PTS system and not a key ignition.
    if you manually set the hvac controls they will work since its set to dumb mode and works since it has power.
    Jrharvey02 likes this.
  9. Jan 30, 2020 at 5:21 AM
    nodak67
    nodak67 New Member
    JR
    forgot to add a tidbit. on our 2018 platinum that has a key, another way to tell the remote module has control is when you unlock and get in the vehicle the seat memory buttons dont work (the seat wont move and the steering wheel doesnt move) until you press the brake to release control back to the vehicle. then the seat memory buttons work.
  10. Jan 30, 2020 at 7:15 AM
    sgrounds22
    2018 Tundra Limited
    Thanks all.
  11. Jan 30, 2020 at 7:15 AM
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    Not trying to hijack the OPs thread. Anyone with compustar that activated its auto hot/cold feature? Thanks
  12. Jan 30, 2020 at 7:20 AM
    Joe333x
    Joe333x Member
    Boston
    Just for reference I ordered my remote start from https://www.12volt.solutions/ and it comes with an Omega/FlashLogic module and my auto climate works during remote start as it is supposed to.
  13. Jan 30, 2020 at 7:21 AM
    Jrharvey02
    Jrharvey02 New Member
    This is great info. I’ve always wondered why my steering wheel doesn’t set to my normal position when remote started. Nor does other stuff seem normal, but I can’t remember what. I’ve been shutting the truck off and restarting with key, guess I’ll have to try depressing brake.
  14. Jan 30, 2020 at 9:53 AM
    timsp8
    NY
    I think that was the OPs question.
  15. Jan 30, 2020 at 11:06 AM
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    That feature is available/optional in my compustar CSX but not sure if all models have it. Also, it needs to be activated during install.
    Below is the excerpt from the compustar FAQ about hot cold feature:
    “The hot/cold start feature is an optional feature in Compustar units that will allow your vehicle to automatically remote start when the temperature reading in the vehicle cabin reaches a set temperature”
    i have not yet activated this feature.
  16. Jan 30, 2020 at 11:08 AM
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    OP, please check with your installer if the auto hot/cold feature in your compustar is available/activated.
  17. Jan 30, 2020 at 12:02 PM
    timsp8
    NY
    I don't think Id like that feature. Sounds like your truck will be starting all times day and night whether or not you are going anywhere or even home.
  18. Jan 30, 2020 at 12:09 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    I have the compuStar on my 2017 and the HVAC works and truck warms up. I always left the heated seats on high if it’s going to be really cold... haven’t driven it a ton lately but that stuff always worked for me.
  19. Jan 30, 2020 at 12:15 PM
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    The reason that i have not yet activated the said feature.
    The default setting is off as described. Thus, it needs to be activated everytime before use by pressing (I think) a combination on your remote.
  20. Jan 30, 2020 at 5:28 PM
    nodak67
    nodak67 New Member
    JR
    just make sure you have the ignition key in and turned to on before hitting the brake. :)
    Jrharvey02[QUOTED] likes this.
