Diode Dynamics SS3 SAE Pro fog lights installed. Update 4/17/21. Now with SS3 Max.
Discussion in 'Lighting' started by Danman34, Dec 13, 2019.
  1. Jan 29, 2020 at 6:02 PM
    #91
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    DBLizzo,
    Will do!
  2. Jan 29, 2020 at 6:15 PM
    #92
    Danman34
    Danman34 [OP] New Member
    Danny
    2018 White Tundra TRD Sport
    Very straight forward. Couldn’t be any easier.
  3. Jan 30, 2020 at 5:35 AM
    #93
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    I've been following this thread and love these fogs. I'm itching to purchase them. I'm just trying to determine if the pro is worth the extra cost.
    yoshi82 likes this.
  4. Jan 30, 2020 at 5:45 AM
    #94
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Are you in the situation where more lights are needed? Or more regular, daily street driven?
    Imo the pro are for more off road type.
  5. Jan 30, 2020 at 6:01 AM
    #95
    wwinslett
    Will
    Birmingham AL
    This is a good point. It would be regularly driven on the street.
    More light is always cool though
    Luckydog likes this.
  6. Jan 30, 2020 at 6:06 AM
    #96
    BrandonL812
    Brandon
    It is. Especially if you drive the country road/highway. More lights is always better. But just have to determine how much night drive you have and how often you end up using the extra light. That may or not justify going for the pro version.
    wwinslett likes this.
  7. Jan 30, 2020 at 6:07 AM
    #97
    Danman34
    Danny
    Pros. Buy once, cry once. I’ve had no issues with blinding oncoming traffic. I even walked out in front of the truck and ducked down to see where the light became blinding. You would have to be in a go kart for them to be blinding. Haha
    Luckydog and wwinslett[QUOTED] like this.
  8. Jan 30, 2020 at 6:11 AM
    #98
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    @Diode Dynamics i was browsing your site last night. Will a amber ss3 pro be available in your driving beam? Thank you!
    cancel that. Josh with customer service got me lined out. Had to order the SS3 amber pro driving separately from bracket. Josh even took $20.00 off bracket to get it to match price of kit. I am excited to get these lights and see how they work in heavy fog.
  9. Jan 30, 2020 at 3:19 PM
    #99
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I got the sports. My buddie got the pros. If you have good headlights already like the 19+ led units then the sports will more than suffice. If you have holegen headlights still I would opt for the pros. Hope that helps.
    I’m still happy w my sports.
  10. Jan 31, 2020 at 1:27 PM
    #100
    jtdunc
    jtdunc New Member
    2014 Tundra Double Cab - Magnetic Gray
    Got the DD SS3 Pro foglights, white, installed but they are currently controlled by the turn knob on the headlight stock. On a whim, purchased a foglight button for the dash. Have room.
    How to wire up my foglights to that dash button so I can run fogs alone independent of having my low beam headlights on?
    Soldering iron, heat shrink, zip ties, and wire snips ready!
  11. Jan 31, 2020 at 1:29 PM
    #101
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Look up 5 minute anytime fog light mod. And then u add a switch
  12. Jan 31, 2020 at 4:50 PM
    #102
    Buildn
    Medina, Ohio
    Diode Dynamics SS3 Sport Fogs
    Just installed tonight.
    Check out the pics!
    Tundra805 and 316KS_Runner like this.
  13. Feb 1, 2020 at 10:05 AM
    #103
    Danman34
    Danny
    Just an FYI to guys who had oem led fog lights. So, apparently the factory fogs and wiring are only designed for a 16w bulb. The Pros are 36w lights. I decided to build a harness to run the fogs off a direct feed from the battery rather than take a chance on the stock wiring. I may be overdoing it, but I’m just that extra lol.
  14. Feb 1, 2020 at 10:53 AM
    #104
    wwinslett
    Will
    Birmingham AL
    I’d be curious to know what OEM foglight bulbs pull amperage-wise vs the Pro?
  15. Feb 1, 2020 at 12:28 PM
    #105
    Danman34
    Danny
    amps = watts/volts
    pros 36/12v = 3 amp.
    Running - 36/14v = 2.57
    stock 16/12v = 1.3 amp.
    Running - 16/14v = 1.14
    probably not enough to hurt anything. But I have peace of mind haha.
    wwinslett[QUOTED] likes this.
  16. Feb 1, 2020 at 4:51 PM
    #106
    wwinslett
    Will
    Birmingham AL
    Definitely good thinking!! No light is worth catching anything on fire.
    If you knew what gauge wire the truck uses for the fogs I’m sure you could google the suggested amp rating.
  17. Feb 1, 2020 at 5:02 PM
    #107
    Danman34
    Danny
    It looks thin. In the 18-20 gauge range.
  18. Feb 1, 2020 at 5:27 PM
    #108
    Dylan7194x4
    Dylan7194x4 New Member
    Dylan
    2013 red cm rw
    Screenshot_2020-02-01-18-25-00.jpg I'm just going to drop this in here incase anyone else is worried. This chart shows that even at 20 gauge the factory wire size is more than enough. Also still waiting on some love for the 2nd gen. Haha
    wwinslett and BrandonL812 like this.
  19. Feb 1, 2020 at 5:29 PM
    #109
    wwinslett
    Will
    Birmingham AL
    @Diode Dynamics have you done any tests in regards of the tundra wiring being safe with the Pro fogs?
    farm&forest and Luckydog like this.
  20. Feb 1, 2020 at 6:00 PM
    #110
    Danman34
    Danny
    I ran them without a harness for 2 weeks with no issues. I just like knowing the powers going through something I know is more than big enough. Plus, my harness has a relay for each side. So even if one side goes bad for whatever reason, the other light still functions.
    Dylan7194x4[QUOTED] likes this.
  21. Feb 1, 2020 at 8:49 PM
    #111
    Dylan7194x4
    Dylan
    2013 red cm rw
    Cant ever be too careful just wanted to point out for others that may not have the electrical skills or knowledge that the factory wiring is rated for the amperage that these lights draw. I would hate to see anyone not buy these lights just because they were afraid they wouldnt work as plug and play. I understand where you're coming from, I am an electrician with many years in industrial motor controls and relays who is currently trying to save some coin buy building my own version of the spod system. I am by no means an expert in automotive electrical but I understand relays and how they work, others may not have the knowledge or skill. Here is what one of my work benches looks like currently, it a mess I know but I just stopped in frustration at running out of positaps. Also still waiting on some 2nd gen love. I am dying for a set of these fogs in amber for the gen 2.20200201_214902.jpg
  22. Feb 1, 2020 at 9:04 PM
    #112
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I also built my own control enclosure. I like being able to replace individual relays. I'm sure the Spod is a great system but nothing beats hand built with quality American/Jap relays and switches
  23. Feb 3, 2020 at 5:56 AM
    #113
    Buildn
    Medina, Ohio
    Diode Dynamics Install Question:
    Since I just installed these SS3’s did any of you notice vibration? Driving in I noticed over some bumps in the road that caused the lights to flicker like. Because the stock light is much lighter than the aluminum DD’s.
    I might be to picky but I’m thinking of hot glueing or silicone the trim a little to help secure the light housing better. Has anyone else experienced this?
  24. Feb 3, 2020 at 6:10 AM
    #114
    fisherman951
    Tony
    2017 crewmax 4x4
    Zip tie is usually the fix for the vibration
    BlueBottle and Luckydog like this.
  25. Feb 3, 2020 at 6:27 AM
    #115
    Danman34
    Danny
    Yep. Zip ties. It’s the entire bezel that needs to be secured better.
    farm&forest and BlueBottle like this.
  26. Feb 3, 2020 at 6:41 AM
    #116
    coTony
    Tony
    Montrose, CO
    How do the white lenses on the Pro series look with your existing truck headlights? It is rated at 6000K which is a blue tinted white light that I hate but the 5000K is not offered. I was told by DD that it is a "hint" of blue. What do you guys see with the installs?
  27. Feb 3, 2020 at 7:01 AM
    #117
    Danman34
    Danny
    Factory led headlights are around 55-5700k. The 6k fogs should match fine.
    For what it’s worth, the oem led fogs measured out around 6150k.
  28. Feb 3, 2020 at 8:43 AM
    #118
    Buildn
    Medina, Ohio
    Zip ties of course!
    Thanks for the reply.
  29. Feb 4, 2020 at 3:33 PM
    #119
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    F6455966-A60E-46B2-BBBC-3EFF5A5201F1.jpg Two pros hooked up plug and play to factory plug
    Tundra805, LogCabins and wwinslett like this.
  30. Feb 5, 2020 at 6:13 AM
    #120
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    78DE52B8-3425-453A-9586-B5645A021EFD.jpg Have to adjust a little bit down but they are way lower than headlights with blinding traffic. Never realized how much yellow gives you usable light. Also bad picture will take more tonight
    LogCabins, BrandonL812 and wwinslett like this.
