What skid plate to get
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rustyscrew, Jan 27, 2020.
  1. Jan 27, 2020 at 7:42 PM
    Rustyscrew
    Rustyscrew [OP] New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I’m really considering getting a new skid plate. Basically between the TRD and the RCI. Both in aluminum. Which do you guys suggest? And there differences?
    Pinay likes this.
  2. Jan 27, 2020 at 7:43 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Depends if you do any off-roading or not.
  3. Jan 27, 2020 at 7:47 PM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Essentially zero off-roading
    Pinay likes this.
  4. Jan 27, 2020 at 7:49 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    All right. If you did go off-road I’d say go with steel. You should be good to go on the RCI.
  5. Jan 28, 2020 at 8:45 PM
    mofferman
    mofferman New Member
    Windsor, CO
    2019 double cab
    Am happy with my RCI skids. They were easy to mount and look great!
