  1. Jan 28, 2020 at 8:38 AM
    I did the online and pick up and they honored it for the 27f.
    What all are you planning on running off the 31? It’s a lot of battery, size, weight is much more. I think you would have to extend your cables as well. A lot more stress on that front fender pinch welds. Unless your super overlandiculous, I would stick with a 27f or do dual 24fs. It all comes down to what you need and use it for. I got the 31 marine for the 4runner and it’s way over kill for what we use it for
    speedtre[QUOTED] likes this.
  2. Jan 28, 2020 at 9:00 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Well, I'm slowly transitioning this to our "off the beaten path" camping rig and away from a DD. I refuse to use the term 'overlander'....it's just too pretentious. :)
    The 31M is only 7 pounds more than the 27M and it's almost 40lbs lighter than two 24Ms. Two 24Ms would be good (redundancy and all) but the weight is MUCH more and there is the fit issue. The 31M is essentially the same size as the 27M only about an inch taller...cost is not much more than the 27M and much less than two 24Ms....decisions, decisions...
  3. Jan 28, 2020 at 9:57 AM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    let me know what he says, Id only be interested in a muffler or headers, not a whole exhaust.
  4. Jan 28, 2020 at 10:00 AM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    I ditched that oem tray holder. Added this metal one. Careful if anyone orders one. There's an identical plastic version.
    WirthCo 21085 Battery Tray
  5. Jan 28, 2020 at 10:16 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Apparently there's no standard system for first gens and the group buy is only for the standard system. I didn't bother calling. I just got that info from the thread
    jImmegart[QUOTED] likes this.
  6. Jan 28, 2020 at 10:20 AM
    Does it still have the 2 outward dots on the bottom that keep it from sliding? Those seem important.
  7. Jan 28, 2020 at 1:38 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Got the flex brake hose service performed today. All went well. Knocked out a few other items like cleaning up the inside of the wheels with wire brush and painting them. Put anti-seize on the rotor mating to wheel surface. Rust Reformed the dust shields and spindle arms etc. Finish Coated everything Gloss Black.
  8. Jan 28, 2020 at 1:59 PM
    Fred
    Hand Protectors
    Couple of observations:
    1) The braided brake lines do not make the truck stop quicker. The pedal has the same pressure as before. The pedal does have a more consistent feel now. In other words, it doesn’t have a slow at first to tailing hard pedal to stop the truck. Its the same pressure throughout the push. Truck still stops the same distances though.
    2) I had bleed my brakes pretty well and even double up on a lightening round a few weeks back. The brakes improved tremendously, as the old fluid was very dirty. Today during bleeding of the Proportioning Valve, some milky fluid came out. Maybe some cack was still trapped up in there or the newer fluid from prior bleeds did some cleaning actions?
    3) Discovered a tear in my front pass side caliper piston boot. This is probably the reason the prior bleed fluid was so bad on that side a few weeks ago. All the other piston rim look crusty. I think its time for WL13 upgrades. :yes:
    Proportioning Valve Milky Today
    Prior Bleed Dirty Fluid from a few weeks back from this caliper tear side.
  9. Jan 28, 2020 at 2:01 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'm thinking about removing my fender flares and wanted to get opinions. I'd like a wider stance on my wheels, but I already have spacers and a 0 offset rim. I'd fill in the plug holes on the fender.
    kodyquist21 and 1Silverback like this.
  10. Jan 28, 2020 at 2:22 PM
    MauiTRDPRO
    MauiTRDPRO New Member
    2003 Tundra AC Super White 2018 TRD PRO Tacoma Calvary Blue
    That’s awesome! Installed one on my tundra along with the JBA exhaust! Definitely worth the money!
  11. Jan 28, 2020 at 2:28 PM
    rock climber
    Or go all in and get the GX460 caliper upgrade!
  12. Jan 28, 2020 at 2:31 PM
    speedtre
    speedtre New Member
    Inland Northwest
    revtune and KarmaKannon like this.
  13. Jan 28, 2020 at 2:38 PM
    Fred
    Hand Protectors
    Post up some info, por favor.
  14. Jan 28, 2020 at 3:10 PM
    rock climber
  15. Jan 28, 2020 at 4:32 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Oh come on! Any links that aren't tied directly to the nsa headquarters?
    Trailscape, speedtre, bmf4069 and 2 others like this.
  16. Jan 28, 2020 at 5:58 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    You get some adhesive metal plates with the mount. My phone has a molded case that I put the metal plate on but you could put it on the phone.
  17. Jan 28, 2020 at 6:05 PM
    SoCalPaul
    Paul
    That’s a good point, never really thought about it. Now you’re going to make me look for a different place. When there really isn’t another good place.
  18. Jan 28, 2020 at 6:09 PM
    Fred
    Hand Protectors
  19. Jan 28, 2020 at 6:19 PM
    SoCalPaul
    Paul
    Nice, I might do mine on Saturday.
  20. Jan 28, 2020 at 6:21 PM
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    I think it would look better without the flares. How do you plan on filling the plug holes?
  21. Jan 28, 2020 at 6:22 PM
    Fred
    Hand Protectors
    I bet one or two of my calipers might be seized based on what I saw. I’ll test the theory when the new stuff comes in and I pull these old pads out. A couple pumps should tell the story.
  22. Jan 28, 2020 at 6:32 PM
    SoCalPaul
    Paul
    Personally I like the flares, but they should be color matched as should your shell.
    oscardog86 likes this.
  23. Jan 28, 2020 at 6:34 PM
    ESTundra937
    Eddie
    San Diego
    Awesome! Thank you for posting this, parts have been added to the list. :thumbsup:
    Are the red brake lines from napa?
  24. Jan 28, 2020 at 6:36 PM
    SoCalPaul
    Paul
    @KarmaKannon here are some screenshots from The Yota Guy RE: GX460 brake upgrade.
    362C7135-4490-4D48-8214-EB4510D06344.jpg A25C05F8-E66B-4341-ADBD-D17EAD9BC8DA.jpg 663D26DB-C1AD-4AA7-98AB-7B7B1559FB91.jpg
  25. Jan 28, 2020 at 6:36 PM
    This person used little white dots to fill them. No clue what they are but I bet someone does.
  26. Jan 28, 2020 at 6:40 PM
    Fred
    Hand Protectors
    From Wheelers. They are Power Stops.
    I may have another set of Power Stops that was wrongly sent from another distributor after I cancelled the order and my money was returned. They still shipped it. Box came in today and I’ll contact them about it.
    If they say keep it I’ll let them go for half price? Give me a few days.
  27. Jan 28, 2020 at 6:40 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well shit. I have to look into yhis
  28. Jan 28, 2020 at 6:43 PM
    ESTundra937
    Eddie
    San Diego
    Those would end up bugging the hell out of me, might be better to leave the flares on. Ha!
    With that much tire stickn out might as well get some LT fenders.
  29. Jan 28, 2020 at 6:44 PM
    empty_lord
    05 rollover special
    Soo what brakes is he using? Gx460? The rotors are too shallow from what I can find
  30. Jan 28, 2020 at 6:45 PM
    ESTundra937
    Eddie
    San Diego
    Sweet, thank you. Let me know, Im in.
