Are all lugnuts created equal?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Acewray246, Jan 28, 2020.
  1. Jan 28, 2020 at 5:28 AM
    Acewray246
    Acewray246 [OP] New Member
    Ace
    Nashville, TN
    2019 Tundra CC Limited
    2019 Poor Mans Pro (Limited TRD with used Pro parts added as found cheap)
    Do 18" Limited, 20" Platinum / Sport / 1794, and PRO aluminum all use the same lugnuts?
    Understand the steel wheels are unique, but curious if that was only different one.
    Thanks,
    Ace
  2. Jan 28, 2020 at 6:24 AM
    Welcome from NY.
    I believe the only difference is that the alloy wheels have a washer and are a little deeper.
    I'm sure others will chime in.
  3. Jan 28, 2020 at 7:12 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Steel wheels use giant nuts. They’re different than normal washer-lugs
    Also the cheap eBay lugs suck. They pit and rust and the finish flakes off once you touch them.
