Recommended Maintenance
Discussion in '1st Gen Tundras (2000-2006)' started by sjamins1986, Jan 27, 2020.
  1. Jan 27, 2020 at 9:28 PM
    sjamins1986
    sjamins1986 [OP] New Member
    2000 Tundra TRD Limited
    TBD
    I have a 2000 Tundra (4.7L) with 213k miles.
    Not a lot of service history, I’m the 3rd owner. Previous owner had it for 8 years and did only the most basic maintenance. First thing I did was Timing belt/water pump/thermostat.
    She has an exhaust leak on the drivers side manifold. I’ve priced headers and they can be installed by a shop in Seattle (Stan’s Headers) for roughly the quote for one exhaust manifold from a local shop. I’d like to go the header route, just need to wait until I have the funds.
    It seems relatively inexpensive to replace plugs/coil packs so that is something I may do this spring. Is there any other items that would be a good idea to do at this mileage interval?
  2. Jan 27, 2020 at 10:14 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Here's something to think about. This scenario happened with my brother's V8 Tundra several years ago.
    It's the only unscheduled maintenance issue he's had in 225K miles.
    speedtre likes this.
  3. Jan 28, 2020 at 4:11 AM
    speedtre
    speedtre New Member
    Inland Northwest
    At 20 years and that mileage I would replace LBJs (OEM only)and as mentioned above, the radiator (Denso, best value). Replace all diff/trans case oil (if it's 4x4). Lube the whole driveline. Clean the intake ...guaranteed it's filthy. I would run seafoam in the oil (1 ounce per qt of oil) for 50-100 miles and then change to high mileage synthetic oil.
    Since you are doing the LBJs I would look at other front end parts that are wear items like tie-rod ends and steering rack bushings.
    Welcome!
  4. Jan 28, 2020 at 5:00 AM
    bmf4069 Captain wtf
    revtune likes this.
