7" BDS REAR LIFT UPGRADE
Discussion in '2.5 Gen Tundras (2014-2021)' started by WaipioTUNDRA, Jan 24, 2020.
  1. Jan 24, 2020 at 3:32 PM
    WaipioTUNDRA
    WaipioTUNDRA [OP] New Member
    2016crewmax7"BDS35x12.5
    Wondering what options I have for upgrading my 7" BDS lif in the rear ... tryna get away from blocks ... I'd imagine theres a leaf/shackle combo guys are running
  2. Jan 24, 2020 at 5:35 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I have 7in bds! I replaced the rear with a icon rxt leaf pack and +3 coach builder shackles!
    coachflip likes this.
  3. Jan 24, 2020 at 6:08 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Pro form shackles super beefy and I think you can get them up to 3” $60 online then you will probably want a leaf pack
    Black Wolf likes this.
  4. Jan 24, 2020 at 6:11 PM
    This.....^^^^^^. Mine are finally going on shortly.....
  5. Jan 24, 2020 at 7:36 PM
    coachflip
    coachflip New Member
    2016 CM
    This is exactly what I did, end up with 5.75" rear lift. Super soft and great ride, but does sag down loaded so I will be adding some bags for towing or payload duties.
  6. Jan 24, 2020 at 7:38 PM
    anthonygan
    2017 Cement TRD PRO
    Depending on what shocks you have in the back too, will help with the sag! Every since I replaced mine they don’t sag like before! Much better!
  7. Jan 24, 2020 at 8:04 PM
    WaipioTUNDRA
    Hows that ride
  8. Jan 24, 2020 at 8:14 PM
    anthonygan
    2017 Cement TRD PRO
    Honestly better then the blocks! But I upgraded shocks at the same time so I can speak too much about the ride
  9. Jan 24, 2020 at 8:15 PM
    WaipioTUNDRA
    I was gonna say what did you do about shocks on there ? Or did you order that icon kit
  10. Jan 24, 2020 at 8:20 PM
    anthonygan
    2017 Cement TRD PRO
    BB97E24E-DC96-4FE3-816B-1338485250B6.jpg I ordered some Kings!
    salmonfacesalad likes this.
  11. Jan 24, 2020 at 11:01 PM
    xtyfighterx
    Ty
    North Idaho
    Did you get new poly bushings to? It was a pain to install mine the stock shackles studs were seized in my leafs I had to cut off the old shackles and press the old bushings out
  12. Jan 25, 2020 at 8:59 AM
    Got the poly's and greaseable shackle bolt from 4WP. Lift is going on once I get my tax refund. Still debating on tires and wheels. Might use TRD rims but might need some BORA spacers. Won't know for sure until the lift is in place. Getting some RCI skids and other goodies.
  13. Jan 25, 2020 at 1:36 PM
    xtyfighterx
    Ty
    North Idaho
    Oh good. Have fun!
