Leaf spring HELP!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra174x4, Jan 24, 2020.
  1. Jan 24, 2020 at 9:42 PM
    Tundra174x4
    Tundra174x4 [OP] New Member
    Cody
    2017 tundra sr5 trd off-road 4x4
    Hello everyone, I’m still a noob and have a noob question. I have a 2017 tundra and I am upgrading my suspension with ICON 2.5 they are adjustable up to 3” I also got the rear and a set of LEAF SPRINGS. My question is, when I replace the new leaf springs there is a thick shorter one On the bottom about 18” long? Do I keep that in there? Or just toss it and install the new leaf springs? I think the shorter one is for support for towing ext... all help appreciated
  2. Jan 24, 2020 at 11:30 PM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    Hey Cody, I’ll take a look at mine in the morning and let you know what they did to mine at the shop. I have the same expansion pack. Beware that these things squeak when the ubolt and leaf rub. Almost everyone who has them greases them up. I did learn something new last month that I should share with everyone who has them. The off road shop discovered that the Ubolts are too tight on the leafs when torqued correctly, hence the squeak. They brought this to icons attention, but apparently they haven’t done anything about it. The shops solution was to add washers to stretch the ubolts out so they’re not so tight on the leafs when torqued to spec. I haven’t had a squeak since.
  3. Jan 25, 2020 at 12:23 AM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    I’d love to see a picture of the ubolts with washer if you get a chance.
    Do you have one on each side?
    Jengel451 likes this.
  4. Jan 25, 2020 at 2:04 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    i believe those leaf springs are added to your existing. They are not replacements.
  5. Jan 25, 2020 at 4:11 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Tundra174x4[OP] likes this.
  6. Jan 25, 2020 at 7:30 AM
    Tundra174x4
    Cody
    Ok that makes sense, I originally had a 3-1 ready lift in there and I loved the look. I bought this package and was just lost about the leaf springs. So you really don’t get much performance out of these leafs compared to stock?
  7. Jan 25, 2020 at 9:36 AM
    Elfine
    Elfine Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    I have the same add a leaf on mine and combined with the new shocks I noticed a huge difference. Basically, the two supplied leafs will replace 2 from the original pack.
  8. Jan 25, 2020 at 11:00 AM
    SoCalTundy
    Here’s a pic with the expansion pack. They removed the top two and added the pack.
    Here’s a pic with the washers they added to prevent the squeak. You can see they added one on each side of the inside.
  9. Jan 25, 2020 at 12:47 PM
    Tundra174x4
    Cody
    I’m going to do the same but keep the heavy loaded leaf on the bottom out
  10. Jan 25, 2020 at 3:52 PM
    Challenger1
    Andy
    Much appreciated! I have the full RXT replacement leaf springs. Started squeaking a bit after a little mud from the trails.
    Hopefully this will help and stop the squeaking. Lol
  11. Apr 27, 2023 at 12:54 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Reviving the thread. Sway bar isn’t it. U bolts are torqued to spec and haven’t changed since install and 500 mile check. The small U clamps aren’t the problem. Replicating under the truck it is for sure the entire leaf pack. I just shot chain lube in the cracks so I’ll see if that works in. I did do about 40 miles on forest roads which were dusty and then washed it a day later and the squeaking started a day after that. But I’ve done the same thing on my stock leafs for 20k miles and they never squeaked so ? Also pictures of my one leaf which looks like the one listed here. It looks weird but I guess it’s normal ? I installed them as they came stock. RXT Springs.
    long story short the springs are on 1,500 miles and no noise until today. 2 days after dusty roads and a wash. Is this the battle we’ll have with the Icons?
