Raised Lettering
Discussion in '2.5 Gen Tundras (2014-2021)' started by mambo143, Oct 28, 2018.
  1. Jan 24, 2020 at 5:28 AM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Thanks, mine just came in a strip with tighter spacing than the tailgate letters. So if I cut them individually do I just pull the backing and align each letter in the stamped letter indent? My concern is that they all line up. Do you do a snap line for the letters to square up with or does aligning them individually within each letter stamping do the job as far as overall alignment?
    Thanks! Hate to do it and have it look misaligned.
  2. Jan 24, 2020 at 9:47 AM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    Mine aligned pretty naturally, I just went slowly and made sure they were lined up before pressing them in.
    Here is Matte Black on black.
  3. Jan 24, 2020 at 10:04 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Align individually. Just make sure you keep them centered vertically and horizontally within the openings. Eyeballing is fine
    rebmo likes this.
  4. Jan 24, 2020 at 6:41 PM
    rebmo
    Rural SE Wisconsin
    Thanks all for install guidance. Nice job on the red letters. I may bring mine inside for the job also. Here's a pic of how the letters I have are configured. Each letter has a cutout around it for the backing adhesive. No instructions provided so again, thanks for the guidance, prefer not to screw it up and probably just overthinking it. I'll be installing individually and lining up centered top to bottom, side to side, equally spaced.
    jewsNbrews likes this.
  5. Jan 24, 2020 at 6:58 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Those seem like the bigger ones like Chris has a few posts above. I don't think there's a lot of extra room for them to get crooked on you if you take your time. Also be sure to clean the recesses really good with some rubbing alcohol before applying. Good luck.
    jewsNbrews and rebmo like this.
  6. Jan 24, 2020 at 7:18 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Cut them out while leaving the backing and a smal piece to grab and peel off when ready to place. Test fit the pieces so you see how it should look. Then like @TILLY said clean the tailgate and then clean with alcohol before applying. Its rather simple once you see them lined up in their correct spot prior to applying.
    rebmo[QUOTED] and TILLY like this.
  7. Jan 26, 2020 at 1:35 PM
    Jorgeflores
    Jorgeflores New Member
    POULSBO, WA
    17 Tundra Crewmax
    Lifted, wheels/tires
    The raised lettering looks real sharp. You guys know any place that sells them in camo?
  8. Jan 26, 2020 at 2:00 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I havent seen any like that before.
    Jorgeflores[QUOTED] likes this.
  9. Mar 20, 2020 at 2:04 PM
    rebmo
    Rural SE Wisconsin
    Well, I went and did it and it turned out great for the look I wanted. Thanks for the tips.
    Going for a silver/gray/stainless/chrome mix look and this balanced out the 4x4 lettering on the tailgate. Sorry Chrome haters, hate away!
    Oh yeah, remind me to remove that dealer sticker, yuk!
    Hoff and jewsNbrews like this.
