2004 Limited sunroof problem
Discussion in '1st Gen Tundras (2000-2006)' started by jddunkley, Mar 23, 2019.
  1. Mar 23, 2019 at 12:15 PM
    jddunkley
    jddunkley [OP] New Member
    Jon
    2004 Tundra Limited
    I bought this Tundra this month knowing that the sunroof didn't open. Didn't know that sunroofs were such an expensive problem! Anyway I had a friend look at it and he found this bracket on the left track disconnected and bent out of shape:
    I took the glass off by removing the 2 8mm bolts on both sides so I could take a closer look. The bracket on the right is also disconnected. It looks like it's supposed to connect to the hardware that the glass is bolted to and then run along the wavy track below it:
    The wavy track is what is connected to the motor and both sides slide back when the switch is activated. So I'm not sure how that wavy track is supposed to pull the glass back with the bracket. That's where I need help! If anyone can send pictures of how all this hardware is connected properly on their sunroof maybe I can figure out how to fix it.
    I'm also worried I might be missing pieces. I found this screw loose in the track on both sides of the sunroof:
    Thanks for any help!! Hoping to not have to spend $500 to get this fixed! :)
  2. Jan 20, 2020 at 2:12 PM
    dakotaaces
    dakotaaces New Member
    Hey I have the 2004 tundra limited and my sunroof doesn't work either. Did you ever find a fix for this?
    MrAristo likes this.
  3. Jan 20, 2020 at 2:44 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  4. Jan 24, 2020 at 3:26 PM
    dakotaaces
    I can hear the motor click but nothing after that. it won't budge in either the tilt or the open
  5. Jan 24, 2020 at 4:16 PM
    speedtre
    speedtre New Member
    Inland Northwest
    bmf4069 and BubbaW like this.
