Rear end noise, lemon?!?!?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by RedBarca19, Jan 22, 2020.
  1. Jan 22, 2020 at 6:07 PM
    RedBarca19
    RedBarca19 [OP] New Member
    2019 4x2 CM SR5
    Hey guys, so ive been dealing with this noise, see video below, since 600 plus miles, been to the dealership 3 times now. The first time they lubricated the pads, the second time they machined the rear rotors, this time the truck is sitting at the dealership and they cant figure it out, supposedly i was told by my service advisor that someone from Toyota is coming to look at the noise because they can't figure it out. It seems like a break rotor issue to me, but these folks are scaring me because they cant figure it out which leads me to believe it might not be as simple as i thought. It is a 2019 Tundra 4.6 CrewMax 2 wheel drive.
    https://youtu.be/aQL8SCUhlOg
    Any thoughts????
  2. Jan 22, 2020 at 6:13 PM
    Grittytundra
    Grittytundra New Member
    sepa
    Sounds like my Tacoma I just got rid of. It had out of spec axles.
  3. Jan 22, 2020 at 6:18 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    My first thought is that the brake dust shield is bent and rubbing on the rotor.
    Whatever it is shouldn’t be hard to track down making noises like that.
    MS22 likes this.
  4. Jan 22, 2020 at 6:21 PM
    RedBarca19
    2019 4x2 CM SR5
    Seriously!!!!!!
  5. Jan 22, 2020 at 6:22 PM
    RedBarca19
    2019 4x2 CM SR5
    Thats what i thought too, but that has been adjusted the first time it went in, no change.
  6. Jan 22, 2020 at 6:26 PM
    RedBarca19
    2019 4x2 CM SR5
    This noise only happens when the breaks are applied, if the truck comes to a rolling stop, no noise.
    landphil likes this.
  7. Jan 22, 2020 at 6:27 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    The dealership couldn't figure this out? :confused: If it were mine i would pull the caliper and run it (on jack stands) to see if the noise disappears, then check the shields. You can see the caliper dancing around, which also could mean a bent axle or warped rotor as others have said. Good luck.
  8. Jan 22, 2020 at 6:28 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    :notsure:One of the pads in backwards??
    Am I seeing the caliper wobble around with the warped rotor or axle?
    MS22 and landphil like this.
  9. Jan 22, 2020 at 6:32 PM
    RedBarca19
    2019 4x2 CM SR5
  10. Jan 22, 2020 at 6:34 PM
    RedBarca19
    2019 4x2 CM SR5
  11. Jan 22, 2020 at 6:35 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Good catch, totally missed that watching the first time on my phone.
    That rotor has some serious run-out, caused by either the rotor itself or the axle shaft. Since the rotor was supposed to have been machined, it doesn’t look good for the axle shaft.
    GODZILLA and 15whtrd like this.
  12. Jan 22, 2020 at 6:39 PM
    Grittytundra
    sepa
    Exactly how mine started out, had it in 5 times for brakes then the sixth time they checked the axle specs. I hope it’s not that
  13. Jan 22, 2020 at 6:41 PM
    TILLY
    Massachusetts
    That would drive me nuts! Did you show your first vid to the dealership?
  14. Jan 22, 2020 at 6:43 PM
    RedBarca19
    2019 4x2 CM SR5
    What happened, did they buy it back? Did you go the lemon law route? Im so frustrated, the truck has less then 2k miles i havent even made the first damn payment yet.
  15. Jan 22, 2020 at 6:44 PM
    Grittytundra
    sepa
    I couldn’t lemon law mine since I bought used BUT I did lemon law a previous vehicle and you fall under that ( atleast pa lemon laws ) for sure
  16. Jan 22, 2020 at 6:45 PM
    RedBarca19
    2019 4x2 CM SR5
    The dealership has all the videos, i have a few more too that i turned in to them. On the bright side, if there is one, the dealership seems to be trying and they aren't just blowing me off.
  17. Jan 22, 2020 at 6:45 PM
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    Thats a noise i would for sure have noticed when test driving the truck before purchase.Could be a piece of gravel stuck between brake pads and caliper
  18. Jan 22, 2020 at 6:48 PM
    RedBarca19
    2019 4x2 CM SR5
    Yes i agree, on the day i test drove it was about 20 degrees and windy as hell. Also, the noise can't be heard inside the cab, only of your windows are down.
  19. Jan 22, 2020 at 6:49 PM
    RedBarca19
    2019 4x2 CM SR5
    Was the noise the only thing yours had? What other symptoms?, mine has no shaking, no wobbling, nothing while driving, the only time it does it is when the breaks are applied. Uou can't hear anythi g inside the can, only when the windows are down.
  20. Jan 24, 2020 at 7:16 AM
    ryandv
    ryandv New Member
    Monterey, CA
    2019 Black Tundra TRD Pro
    I had the same exact issue with my 19 Pro. It was the rear axle. The dealership replaced it. I had to bring it in for several visits before they figured out what the issue is.
  21. Jan 24, 2020 at 7:43 AM
    RedBarca19
    2019 4x2 CM SR5
    Mine is still at the dealership they've had it all week and they can't figure it out they have sent all the videos to the Toyota field rep and I am beyond frustrated about it. I noticed mine at 600 miles. Did they replace the rear end or jusy axle shafts? I would think this would compromise the differential in the longrun, but i could be wrong.
  22. Jan 24, 2020 at 8:49 AM
    viha22
    viha22 MAGA
    WA
    Bro i was in your boat in terms of frustration but im sure Toyota will make it up to you.
    When i got my new Limited in 2014 i had rear main seal leaking oil on my driveway and they had to drop my transmission to replace the seal when i had less than 1k on the odometer.
  23. Jan 24, 2020 at 9:11 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    That is exactly what mine does. It didn't always do this either. It only makes the noise when I first apply the brakes. So maybe I bent the axle shaft at one point overloading it?
  24. Jan 24, 2020 at 9:11 AM
    RedBarca19
    2019 4x2 CM SR5
    Just left the dealership, i asked to talk to the tech, they took me back as he was working on my truck, to my surprise, they were checking the axles, thank goodness.... hopefully they find something soon. You are right... they will take care of it i have faith .
  25. Jan 24, 2020 at 9:40 AM
    ryandv
    ryandv New Member
    Monterey, CA
    They replaced the rear axle shaft.
  26. Jan 24, 2020 at 10:09 AM
    RedBarca19
    2019 4x2 CM SR5
    Thanks so much!!!!!
    ryandv[QUOTED] likes this.
  27. Jan 24, 2020 at 12:08 PM
    RedBarca19
    2019 4x2 CM SR5
    Hallelujah!!!!!! Dealer just called, both axles are bent, they are replacing both axels, bearings, brakes, rotors, etc..... finally some answers. They are waiting for Toyota to approve everything and they will order parts. I hope this is the end of the ordeal with this NEW truck.
    GODZILLA, yoshi82, ryandv and 3 others like this.
  28. Jan 24, 2020 at 5:51 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I wonder if this is a manufacturing issue (either machining or material defect) or a damage in shipping issue.
    Either way, replacing an axle shaft or two isn’t rocket surgery, and shouldn’t result in any long-term issues. The differential won’t be affected, and good to hear your’re getting new rotors etc.
  29. Jan 24, 2020 at 6:10 PM
    RedBarca19
    2019 4x2 CM SR5
    Thanks for the input. Hopefully everything gets done right and all my posts from now on are on aesthetics.
    sask3m likes this.
  30. Jan 24, 2020 at 7:17 PM
    TILLY
    Massachusetts
    Glad they figured it out and the dealership is taking care of you. :thumbsup:
