FUEL ADDITIVE THOUGHTS
Discussion in 'General Tundra Discussion' started by SILVER FOX, Jan 23, 2020.
  1. Jan 23, 2020 at 6:01 PM
    SILVER FOX
    SILVER FOX [OP] New Member
    GARY
    IDAHO
    2015 SILVER DOUBLE CAB
    BULL BAR ** FENDER FLAIRS ** TINTED WINDOWS ** VISOR VENTS.....so far. :)
    Being new to Tundras (3 weeks) and THE forum, I have not seen any comments regarding the use of, or need for fuel additives, mainly to neutralize ethanol.
    Are there any members who use it; why, what kind, noticable changes, etc.
    I have used Star-Tron for years in my other truck, a 2004 GMC, lawn mowers, snow machine, weed trimmers, etc. I store all of them for the season, and when I need them they ALL start on the first pull; I've always had start problems until I started using Star-Tron. (I'm not a dealer!!!)
    I have not seen any info from Toyota regarding the pros or cons of using these types of products.
    Let me know what you think.....
    Go easy on me.....I'm left handed. :crapstorm:
    Johnsonman likes this.
  2. Jan 23, 2020 at 6:11 PM
    Rica25
    Ricardo
    Tulare
    I actually did a Fuel induction By BG products today also on every oil change I have done since 18k to now at 150k miles I've done two bottle treatments one for the oil and other 44k for fuel tank
    Jrharvey02 and SprinterAE86 like this.
  3. Jan 23, 2020 at 9:18 PM
    SILVER FOX
    GARY
    IDAHO
    The StarTron is designed to neutralize Ethanol, eliminating the harmful effects it has on fuel systems.
    Thanks for the info, I will give it a try. Couldn't hurt, and the investment will be well worth it.
  4. Jan 23, 2020 at 10:54 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Startron is excellent. I also use Seafoam as an injector cleaner.
    Rica25 likes this.
  5. Jan 24, 2020 at 1:08 AM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    I run a bottle of Lucas fuel system cleaner in between oil changes
    15whtrd, Rc23 and Rica25 like this.
  6. Jan 24, 2020 at 3:12 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Welcome aboard!
    Adding that will be less expensive than pumping 89 ethanol free.
    Rica25 likes this.
  7. Jan 24, 2020 at 3:22 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    I use Lucas fuel system cleaner and Marvel Mystery oil. Buy them both by the gallon at F&F.put 12-16 oz in every 60 days if I remember. Welcome. D
    Rica25 likes this.
  8. Jan 24, 2020 at 7:26 AM
    SILVER FOX
    GARY
    IDAHO
    After doing the research, I found that "ethanol free" 89 octane actually contains 10% ethanol.
    They didn't lie...just didn't tell the truth.
    The Californian and Rica25 like this.
  9. Jan 24, 2020 at 7:30 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    Same - I'm new to the tundra world and pre-programmed to oil changes every 3-4k but in all my previous vehicles I did this. Roughly every 6-8k miles and ran perfect over 200k miles for both.
    Flyinryank[QUOTED] and Rica25 like this.
  10. Jan 24, 2020 at 7:52 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Hey Leftie, I was gonna be a leftie but my 1st grade teacher sat me down in a Rightie desk and took my pencil out of my left hand, miracle I'm not a serial redrummer...
    But getting back to your question, yeah here's a long time Startron user. As you know it is far more than an ethanol nuetralizer. For those who don't know the product, read up on it here: http://www.starbrite.com/startron
    I too use it on every vehicle and small engine from bmw, porsche, 4runner, prius, camry, sequoia, honda mower, polaris atvs.
    What I noticed is the when pulled spark plugs after 70-90k, they look like they've been firing good n' hot, like no fuel is left behind, no residue, no carbon, clean.
    ATVs and small engines love it and start up Instantly, one pull.
    I buy it by the gallon, haha: https://www.amazon.com/Star-Brite-9...eywords=startron+gallon&qid=1579880476&sr=8-4
    I only use 1 ounce per tankful so it goes a Long way...
    It is far less expensive than other brands of ethanol neutralizers and to me appears to work better.
    Required, probably not, but I like it. Luck all.
  11. Jan 24, 2020 at 7:52 AM
    timsp8
    NY
    Around here you have to go with premium for no ethanol. And only certain stations have it.
  12. Jan 24, 2020 at 8:16 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Been using Lucas Oil Fuel Treatment for years, about every 5 or 6 fills ups. Have never had an issues w/any of my trucks. Since I don't buy gas at the same stations, I feel it's a bit of protection and certainly can't hurt anything.
    Flyinryank likes this.
  13. Jan 24, 2020 at 9:44 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    No, you misunderstood - it's not free of ethanol, the ethanol is free.
  14. Jan 24, 2020 at 10:12 AM
    SILVER FOX
    GARY
    IDAHO
    Must've had the same teacher; (Mrs. Eaton?) mine whacked the back of my left hand every time I changed from my right hand. That was 60 years ago; ALL the desks were right handed; clear thru college. ooops..I just dated myself. Hasn't bothered me at all at all at all
  15. Jan 24, 2020 at 10:40 AM
    SILVER FOX
    GARY
    IDAHO
    Well....they tricked me...again :facepalm:
    Rica25 likes this.
  16. Jan 24, 2020 at 11:05 AM
    The Californian
    Eric
    Just wait until I come out with my line of Calorie Free, Carb Free beers.
    Alphamale and Rica25 like this.
  17. Jan 25, 2020 at 4:57 PM
    IBJC
    IBJC New Member
    2020 tundra sr5 crewmax Cavalry Blue
    Been using 44k for a few years in my Tacoma before trading her. Great stuff!
    Rica25 likes this.
  18. Jan 25, 2020 at 5:40 PM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    I just started using the concentrated Seafoam fuel injector cleaner and upper cylinder lube. Autozone had it on sale for $3.99 so I’m going to run a few back-to-back and then at every oil change. I’m going to start using the StarTron at every fill up and have been looking for a reason to try it.
  19. Jan 25, 2020 at 5:43 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    I don’t think it makes a difference on tundras.
    GDI engines actually recommend it.
    Darkness likes this.
  20. Jan 26, 2020 at 5:18 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Have you considered Stabil 360. My marine guy told me it has Star Tron in it. I have not bothered to verify
    Rica25 likes this.
  21. Jan 26, 2020 at 5:33 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    The Marvel Mystery oil may cause issues down the road. I tried it in my 2006 Corolla XRS. My check engine light came on.
    MMO is 70% Naphthenic Hydrocarbons. 29% Mineral Spirits. Used in gas its more of a upper cylinder lube than it is a cleaner. I was told the MMO flooded the cat and o2 sensors with oil/lubricant. In the old days with lower catalyst efficiency standards (pre-2002) there would be no issue. Today catalytic converters are held to a higher efficiency (+-90%). My cat may have been on the edge of efficiency (over 200,000 miles). However, I had to change the o2 sensor. Suggest you stick to the modern low oil PEA fuel system cleaners.
    Rica25 likes this.
  22. Jan 26, 2020 at 6:05 AM
    muledawg
    muledawg New Member
    Indianapolis,IN
    2019 Silver Sky Metallic TRD CM
    I use this in everything. I don’t think you can find it on shelves of stores. You have to find a rep that sales this, at least that’s the way it is here in my area. They have products for every type of use. I’ve run their product in my ole ford that has 270,000 miles on it (4.6L) and still running strong doing oil changes every 5k with Napa gold filter. Good product? Or just lucky? 4CE1F6B1-47FF-4F4D-9C5C-B30D77A74BBD.jpg
    Rica25 likes this.
