Tapping into a switched fuse for grill lights
Discussion in 'Lighting' started by Sandy4x4, Jan 21, 2020.
  1. Jan 21, 2020 at 8:21 PM
    Sandy4x4
    Sandy4x4 [OP] New Member
    2018 Tundra SR5 4x4
    Hi, I am a newbie to this forum. I have a 2018 Tundra SR5 crewcab (new to me). I have installed LED grill lights for extra visibility on Texas back roads. The right side of the fuse box is shown below. I would like to add-a-fuse to a fuse that is on when the ignition is on and off when the ignition is off. Does someone know which is the best fuse to tap into?
    Thanks!
  2. Jan 21, 2020 at 8:40 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    There is one labeled IGN which is ignition.
    Positions noted on the back side of the cover. It's either a 7.5amp or 10amp fuse, cannot recall off hand.
  3. Jan 22, 2020 at 7:30 AM
    Sandy4x4
    2018 Tundra SR5 4x4
    That is the first 10A fuse on the top right next to the 2 blanks. Thak you for your help!
  4. Jan 22, 2020 at 7:34 AM
    Welcome from NY.
  5. Jan 22, 2020 at 8:52 AM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    There is a thread that tells you how to tap into wires for the raptor lights.
    Hood bulge amber light grill (raptor lights too)
  6. Jan 22, 2020 at 9:37 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
  7. Jan 22, 2020 at 11:09 AM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    You don’t want to tap into a fuse. The fuse is there to protect that circuit. Get a test light and find an empty slot that turns hot (light on) when ignition is turned on.
  8. Jan 22, 2020 at 12:31 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    If you tap into an existing fuse just make certain the original fuse has enough capacity for both since the current must run thru the original fuse first.
    I usually just create a new tap straight to the battery and place the fuse right at the battery. Luck.
