305/65r17 Request for Information
Discussion in 'Wheels & Tires' started by UTAHRTK, Jan 22, 2020.
  1. Jan 22, 2020 at 5:59 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    There are many like it but this one is mine... Stock 2017 TRD Crewmax/ 275/55r20.
    I extremely close to pulling the trigger on the following and would love to receive input and/or guidance from this vast storehouse of knowledge:
    BFG T/A KO2- 305/65r17
    Method 701 (Black); 17 x 8.5; 0 Offset
    Bilstein 6112 @ 1.3 setting or possible lowest setting
    Bilstein 5160
    Course of Action -1
    Measure all 4- Measure top of wheel lip to wheel well edge
    Install shocks and wheels & Tires
    Measure again
    Alignment
    Drive for a week
    measure again
    Jack up rear at the drop hitch
    eyeball it level
    Measure and determine if I need a shackle and what size.
    Im expecting it to rub front wheel well liner and the front air dam flap gizmo. In this case I will either let it rub or perhaps trim/mold...
    Appreciate your input.
