Anyone running 17" rims on your 2.5 gen?
Discussion in 'Wheels & Tires' started by BuckWallace, Apr 2, 2018.
  1. Dec 1, 2019 at 8:45 AM
    #391
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    @14burrito, are you using wheel spacers to clear UCA'S?
  2. Dec 1, 2019 at 8:48 AM
    #392
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    No Sir,
    1st pic is with the new KO2 and 2nd pic is with the Coopers. Never been worried about contact.
    Too add, I do kiss the arms a little bit at FULL lock. I'm 100% ok with this...its my steering stop. Helps me not do full lock to lock maneuvers and I'm completely OK with this. Just one downside to Camburg arms with the amount of caster they build in.
    Also to mention,
    Wheel spacers with 35s on RW will more than likely require a CMC to be complete.
    equin and Samoan Thor[QUOTED] like this.
  3. Dec 1, 2019 at 10:20 AM
    #393
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    Would you do me a favor if you get a Chance and take a picture of the treads or measure how many inches of threads are showing on each side? THANK YOU!
    Midway[QUOTED] likes this.
  4. Dec 1, 2019 at 10:29 AM
    #394
    showtime240
    showtime240 New Member
  5. Dec 1, 2019 at 10:33 AM
    #395
    14burrito
    2014 SR5 CM 4x4 5.7
    I'm guessing close to 1.75, 2". From what I see, Kings seem to require more preload.
  6. Dec 1, 2019 at 10:56 AM
    #396
    Midway
    Midway New Member
    No problem, will do!
  7. Dec 1, 2019 at 11:00 AM
    #397
    Midway
    Midway New Member
    Here's a couple for now, I'll get some better pics.
    DMB4x4[QUOTED] and Voyagermike like this.
  8. Dec 1, 2019 at 1:45 PM
    #398
    Samoan Thor
    Thanks @14burrito, badass truck, I wish Toyota kept making the RW wheels
  9. Dec 1, 2019 at 2:30 PM
    #399
    DMB4x4
    DMB4x4 New Member
    Just to clarify this gives the truck about 2.5-3in lift?
  10. Dec 1, 2019 at 2:33 PM
    #400
    DMB4x4
    DMB4x4 New Member
    Also are you running a aftermarket UCA?
    I ordered Baja kits uca and 2.5’s
    I was just curious on how much more travel you get w a co and Uca vs stock
  11. Dec 1, 2019 at 2:39 PM
    #401
    14burrito
    2014 SR5 CM 4x4 5.7
    He has Camburg kinetic upper, shows in the initial post you commented on ;)
    DMB4x4[QUOTED] likes this.
  12. Dec 5, 2019 at 11:35 AM
    #402
    Shaggie13
    Shaggie13 New Member
    Mitch
    Central CA
    2017 TRD Pro Tundra Superwhite
    Fifteen52 wheels, rolling on tires.
    Finally put on my 17" wheels.
    Fifteen52 Traverse HD zero offset with some Dick Cepek Trail Country EXP 315/70/17:
    drobb, equin and Topherwv like this.
  13. Dec 5, 2019 at 12:02 PM
    #403
    Topherwv
    Topherwv New Member
    Looks great. 315 had to be a tight fit
  14. Dec 5, 2019 at 1:52 PM
    #404
    Shaggie13
    Mitch
    Central CA
    :sawzall:
  15. Jan 4, 2020 at 4:26 PM
    #405
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Method 701 17s on stt pros
    SC_TRD, recomr, sr5shark and 5 others like this.
  16. Jan 4, 2020 at 9:53 PM
    #406
    Gilby1
    Gilby1 New Member
    ‘16 Blazing Blue Platinum - SOLD, '20 Super White Platinum
    17” Methods with 35x12.5 Toyo OC R/T’s.
    300BLK, recomr, equin and 3 others like this.
  17. Jan 5, 2020 at 7:22 PM
    #407
    COTundra23
    COTundra23 New Member
    great looking truck. What lift / suspension setup are you running?
  18. Jan 9, 2020 at 2:27 PM
    #408
    recomr
    recomr New Member
    Picked up some Rock Warrior wheels off of CL for cheap. Major elbow grease cleaning them and painted the center caps. Wrapped in 305/70/17 Ridge Grapplers. Took the little mud flaps off up front. NO RUBBING.
    Stock suspension for now. Sits damn near flush to the quarter panels. Wouldn’t mind a little wider.
    35057085-B199-4D7D-AC67-EFD5899D3359.jpg8EE7DAC6-C39F-4AEB-8031-4BD9CFDD3CD5.jpgAC2D272C-971B-4FB5-8FE0-1080DD6D993B.jpg07AA321D-9D05-4639-9253-33B2034199D5.jpg
    Faveo1125, MIKEJAUB44, rebmo and 10 others like this.
  19. Jan 18, 2020 at 12:30 AM
    #409
    ricd250584
    ricd250584 New Member
    Chateauguay, Qc
    2016 red Tundra TRD
    Stock at moment
    Nice, Did you have to do any cutting, and what kind of 4/2 lift to you have
  20. Jan 18, 2020 at 3:47 AM
    #410
    Steelyhead
    Steelyhead 2016 Tundra TRD
    America
    16 Tundra TRD/03 Limited TRD
    How did you like the stt max ?
  21. Jan 18, 2020 at 11:46 AM
    #411
    14burrito
    2014 SR5 CM 4x4 5.7
    The only downfall I had with the Cooper was wet boat ramp traction. (In 2wd), extremely light brake pedal pressure, extremely low speed...the damn tires would not "grip" which caused me to slide backwards. Ramps here in Phx AZ local lakes are by no means steep. Otherwise the tires performed very well. Have yet to have an opportunity to test the KO on a ramp.
    Jman245 likes this.
  22. Jan 19, 2020 at 3:17 PM
    #412
    14burrito
    2014 SR5 CM 4x4 5.7
  23. May 6, 2020 at 8:58 PM
    #413
    BAMF
    BAMF New Member
    2020 White Tundra TRD Sport
    For all the folks running 17" methods on their 3rd gens, did any of you have to use ET lug nuts or install longer wheel studs to safely run those wheels?
  24. May 6, 2020 at 9:01 PM
    #414
    Trdwillie14
    Billy
    2014 trd off road
    Not I
    BAMF likes this.
  25. May 7, 2020 at 3:22 AM
    #415
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    Nope.
    BAMF likes this.
  26. May 19, 2020 at 5:08 AM
    #416
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    America's tire installed their black lugs on my Method 313's. When I took it to my Toyota mechanic months later for a tire rotation he said the lugs were not to spec and showed me how little threads they actually screwed into. He ordered me lugs (procomp) that have a longer thread neck and are to spec, which makes me feel safer especially after comparing the two.
  27. May 19, 2020 at 5:33 AM
    #417
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    After looking at pics I think in leaning towards the icon rebounds wheels..if I can swap the lip bolts to black
    Sephon likes this.
  28. May 20, 2020 at 9:58 AM
    #418
    BAMF
    BAMF New Member
    Are the new lugs ET lugs? I considered these but, I've read a few different posts where folks have seen the ET part (the longer neck that recesses into the wheel) breaks off under load.
    Still considering the ET lugs. Whats cheaper to fix? A wheel stud and possibly wheel replacement when the ET part breaks, or wheel+tire+rotor assembly+wheel studs+new lugs when the entire wheel flies off while driving?
  29. May 30, 2020 at 10:36 AM
    #419
    nyccmtundra
    nyccmtundra New Member
    2017 Cement TRD Pro
    TRD Pro on 285/75/17 Nitto Ridge Grapplers (34"x11.5") on Fifteen52 Turbomac HD wheels 17"x8.5" 0ET (4.75" BS)
    J&ATundra, Gee Dub, pvmike and 9 others like this.
  30. May 31, 2020 at 3:25 PM
    #420
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Joined the club! 295/70r17 Cooper St Maxx
    1EB9D257-282A-4BDD-BAA3-C53B189FC9DD.jpg 9892941D-64F1-4708-8B9B-99D4E139D426.jpg 584C08BD-D688-4ED4-B959-734C5BA028D1.jpg
    Pjholt, equin and COTundra23 like this.
