SOLD: silver center dash trim/bezel, black air vents
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by InsaneAuto86, Jan 11, 2020.
Thread Status:
Not open for further replies.
  1. Jan 11, 2020 at 4:47 PM
    InsaneAuto86
    InsaneAuto86 [OP] New Member
    SE PA
    2020 Tundra SR5 TRD
    EDIT: A/C vents SOLD, silver bezel available
    ALSO INCL: MESO 4X4 trim ring and push start ring
    Again, NO AC VENTS ARE INCLUDED
    $100 + actual shipping (package is 26x18x7 and weights 4lb 4oz)
    Located in Reading PA
    recent shipping quotes - USPS to AZ $70, UPS to AZ $53
    Selling a take off silver center dash piece from 2020 SR5 Tundra w 500 miles on it. SOME yellow tabs missing on back. NO cracks or issues. This DOES HAVE the 4x4 hole.
    (I replaced this with the SR black dash piece and kept the chrome vents)
    If you need a stock one to hydro-dip, wrap, or paint, here it is!
    Voyagermike and Y0TA PR0 like this.
  2. Jan 13, 2020 at 4:23 AM
    coTony
    Tony
    Montrose, CO
    Do you have a good picture of your blacked out dash after the swap? The shipping would break the deal for me
    GLWS
  3. Jan 13, 2020 at 4:49 AM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    A/C vents are sold. If you want the plain silver center, $100 + actual shipping.
    Will throw in the MESO 4x4 black trim and the push start trim
    Y0TA PR0 likes this.
  4. Jan 13, 2020 at 5:29 AM
    rockfordhx
    rockfordhx New Member
    If it will fit my 2017 SR5 I will take the silver center. Checking to see if it will fit....
  5. Jan 13, 2020 at 9:27 AM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    I replaced it with the generic SR bezel with no issue. There was no "year" specified on the p/n, just an option for the presence of the 4x4 knob
  6. Jan 13, 2020 at 10:57 AM
    rockfordhx
    Thanks InsaneAuto86. My SR5 is a 2WD so no 4x4 knob. I have to pass on this.
  7. Jan 14, 2020 at 1:21 PM
    Jerry81
    Jerry81 New Member
    SAN ANTONIO, TX
    How long did it take to install?
  8. Jan 14, 2020 at 1:41 PM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    About 1.5hrs because I went slow. Everything pretty much just pulls out w clips. I did not remove the driver kick panel nor pass glove box.
  9. Jan 14, 2020 at 1:49 PM
    Jerry81
    Jerry81 New Member
    SAN ANTONIO, TX
    Thanks, I'll save it for when I swap my head unit and knock it all out at once.
  10. Jan 15, 2020 at 3:43 AM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    Message sent
  11. Jan 18, 2020 at 1:08 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Details on how you did this. Everything I've seen, pretty much takes the whole dash apart. If it can be done easier, I may consider this.
  12. Jan 18, 2020 at 1:43 PM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    It's really not that bad. Like I said, everything pulls out. I didnt remove any of the center console shift trim, nor the glove box or lower driver dash. Just pulled out the clip at each corner and you can wiggle it out.
    I had it out and replaced before my wife had any idea I was modifying a brand new truck. Dont be overwhelmed! You got this!!!
  13. Mar 9, 2020 at 4:14 AM
    Tiger343
    Tiger343 New Member
    19 Tundra 1794
    Where did you the new center bezel from? I'm thinking of changing mine. I found some on the ID website. Also, why are/did you change your muffler? I have a 19 Tundra 1794 edition. It's got a rumbling noise to it and I want to quite it down. Is that what you did it for?
    Thanks for your help,
Thread Status:
