  1. Jan 17, 2020 at 11:48 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    if you ever get bored can you get pictures of the connectors under your seat.
    NUDRAT likes this.
  2. Jan 18, 2020 at 12:06 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    "Premium grade brake fluid designed for all ABS, drum or disc brake systems requiring DOT 3 or DOT 4 fluid. Featuring a high dry boiling point, Valvoline™ Brake Fluid reduces the risk of fluid evaporation and possible brake failure and the low-moisture formula provides excellent vapor lock protection for maximum braking performance, while also gaurding against corrosion.
  3. Jan 18, 2020 at 12:12 AM
    empty_lord
    05 rollover special
    i run motul dot 5.1 (NOT 5. 5 IS NOT FOR ANYTHING OTHER THAN ODD CARS)
    my father gets a deal on it through a friend.. complete overkill for the truck... but really high boiling point
  4. Jan 18, 2020 at 2:34 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I'll try to remember when I wake up today
  5. Jan 18, 2020 at 4:33 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Patience, work table and numerous pictures....according to how far you go in maintenance, would suggest checking sliders and add grease if necessary. Mine were a little more fun given they have power everything but by hooking a small 12v batt to motor terminal while on bench, was able to exercise all motor functions, clean out old grease and replentish. Get to redo my driver seat once the upholster guy finishes my drivers seat bottom.
  6. Jan 18, 2020 at 5:00 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Besides what @because_wumbo-truck offers, here’s some I took if it will help. Have others if needed.
  7. Jan 18, 2020 at 5:35 AM
    empty_lord
    05 rollover special
    04 may be a bit different, but that does indeed give me an idea
  8. Jan 18, 2020 at 6:04 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Are you sleep typing right now?:D
  9. Jan 18, 2020 at 6:29 AM
    Fred
    Hand Protectors
    Nice recco! Read the stats and the DOT5.1 seems like a huge % increase over both DOT3-4 in performance when comparing the DOT3-4 small difference change.
    I’ll be using this next time. Big Gurrl sells Motul for $10 per 16oz. bottle.
  10. Jan 18, 2020 at 6:44 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Reach out to this guy....
    https://www.tundras.com/threads/katzkin-leather-interior-offer.52217/
    And Katzkin will sell matching leather/vinyl to recover your doors...I've seen it on other sites.
    TX-TRD1stGEN and BubbaW like this.
  11. Jan 18, 2020 at 7:54 AM
    Reading my Mityvac manual today and it seems to like Dot5 but stresses that they cannot be mixed. So you'd have to get out all the Dot3 first.
    On another page it says silicone based fluid shouldn't be used on vehicles with ABS..
    mcharfauros likes this.
  12. Jan 18, 2020 at 8:09 AM
    Everytime I post at 430 in the morning I wake up to a "you have been banned" screen.
    :drunk:
  13. Jan 18, 2020 at 8:17 AM
    Fred
    Hand Protectors
    DOT5 does not equal DOT5.1
    Different fluids.
  14. Jan 18, 2020 at 8:18 AM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
  15. Jan 18, 2020 at 8:21 AM
    Fred
    Hand Protectors
  16. Jan 18, 2020 at 8:26 AM
    Well that just brings up questions I didn't know I wanted the answer to. What the hell is in dot5? Picky ass fluid...
    FirstGenVol and Darkness like this.
  17. Jan 18, 2020 at 8:28 AM
    I think this is a really good idea. Can we do something like this? @Pinay
    TX-TRD1stGEN and Pinay like this.
  18. Jan 18, 2020 at 8:31 AM
    Fred
    Hand Protectors
    I’m learning this DOT5 and DOT5.1 stuff on the fly today.
    DOT5 is a rare bird fluid, as per @empty_lord states.
    DOT5.1 is some super duper stuff I never knew existed! Compatible with DOT3&4. Check the chart above for details on boiling points. The difference between 3&4 are negligible. The difference in 5.1 over those 2 is yuuggee!
  19. Jan 18, 2020 at 8:34 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  20. Jan 18, 2020 at 8:35 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I’ll consult with the other mods about sticky’ing it.
    Let’s see how many pages you can get today!!
  21. Jan 18, 2020 at 8:35 AM
    Challenge accepted.
  22. Jan 18, 2020 at 8:36 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I found if you put a bag over the foam, the leather slides on much easier. Then you can pull the bag out, or just leave it in if it doesn't "crinkle".
  23. Jan 18, 2020 at 8:54 AM
    My bad! Didn't even catch the .1 earlier.
  24. Jan 18, 2020 at 8:56 AM
    Fred
    Hand Protectors
    Good reviews on this 5.1 stuff. Since you are getting ready for a brake flush are you considering this?
  25. Jan 18, 2020 at 8:59 AM
    Not this time. I just went to Advance 15 minutes ago(where I spotted the custom bumper) and didn't see any 5.1
    I got another bottle of the Valvoline.
  26. Jan 18, 2020 at 10:18 AM
    I've not been this frustrated in a while. This Mityvac is just not working. I'm able to build a vacuum and hold it, so I know I don't have any leaks. As soon as I crack open the bleeder valve all pressure is lost and no fluid comes out. I watched a video. I'm doing exactly what they say. I'm at a total loss.
    I didn't have this issue last time I used that cheap pos bleeder from Advance.
  27. Jan 18, 2020 at 10:29 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Yeah I was going to try the bag for the headrests because they are tight tight tight.
    Front seats are done and about to install now. Still need to do the headrests.
    @empty_lord look what I found in the bottom of the box! Looks like they included some remnant material that I'm assuming is intended for door trim. Looks like it's big enough to cover the fabric portion.
  28. Jan 18, 2020 at 10:32 AM
    KarmaKannon
    Utah
    Some junk
    Do you need to lubricate the little bleeder nipple so it makes a seal while still sliding over the bleeder screw while turning it with a wrench? My other idea is that maybe your wrench is otherwise disrupting the seal on the bleeder.
    TX-TRD1stGEN likes this.
  29. Jan 18, 2020 at 10:41 AM
    I'll try it. I'm putting the wrench on first, then applying the little hose to the bleeder and testing the connection. I'm about to throw the thing so I'm gonna stop before I regret my decisions. :D The entire point of this thing was to make this easier, not harder.
    NUDRAT and KarmaKannon[QUOTED] like this.
  30. Jan 18, 2020 at 10:49 AM
    Fred
    Hand Protectors
    I read that in some of the Mitty Vac reviews. Time for Plan B.
    Use my Widdy Wack method. Just poke a hole in the side of a plastic bottle and slide it up over the bleeder valve with your 10mm already on the nut first. Get the Little Honey to pump 5 times. Open bleeder on the second pump and close right at the 5th pump. The juice squirts out in satisfying bursts. Keep going until clear fluid at each valve.
    Order of Ops: Pass rear, RLSB Valve, Driver rear, Pass front, Driver front.
    Yeah it requires a second person, but it worked just fine. No air. No hoses. Works using the brakes own pressure. Save the earth with recyclables. KISS method.
